My Acer aspire 7740 won't power up. The issue just started a few days ago. The blue power light comes on, the fan starts and the CD and HD initialize. Any ideas how to fix this?
SOURCE: Averatec 2300
My 2300 started same problems in Dec 08 (almost 2 years old) Its an overheat problem! With black screen the two blue lights an bottom left are on. Leave powered up and in an hour or so will shut down on its on, then will start back up normally but shut down again in about an hour.Correction 1. pull off back cover, blow out the dust. 2.Go to set up (F2 on power up and run fan cal) 3. Take the back cover off you will feel how hot the CPU and hard drive are that is because vents are too small for an aging laptop. Now take the cover and drill a double line of holes on each side of the hard drive vents, Next over the CPU (where the fan blows in air, drill a triple line of new vent holes in the cover). A 5/32 drill will be about right. You may also wish to purchase an inexpensive Belkin laptop cooler. About $19 at Best Buy. This solved my problem as I do like this little one for travel
Glenn New Mexico
Posted on Mar 16, 2009
benwabnick
  • 2404 Answers
SOURCE: My Acer Aspire 5570Z laptop's power button issue
Underneath the power button that you see is a small board with a tiny tactile button. These tactile buttons because they get used alot tend to go bad. They will get worn out and then eventually won't work.
Best thing to do is to go to this page courtesy of Acer:
https://secure2.tx.acer.com/FixMyAcer3/FixMyAcer.aspx
There is a phone number there and they should be able to tell you if your laptop is under warranty. If its not, ask them the name of the board underneath the power button and its part number and you can search for it yourself on the internet to get the best price
Posted on Jun 25, 2009
durtopian
  • 408 Answers
SOURCE: Acer Aspire 3003LMi not posting anymore
Sound like a bad video card or its connection to the video inverter or screen.But mostly a bad video card and maybe high heat related failure.
Posted on Jul 28, 2009
benwabnick
  • 2404 Answers
SOURCE: Acer Aspire 5520 does not start up, power light blinking green
I think it might be the motherboard, if its not regulating the voltage properly then to much will go thru the motherboard and the fan won't be able to cool things down properly. Eventually then the motherboard will fail and then no video like your having now.
Try these steps anyway just to be sure:
only hook up the AC Adapter keep the battery disconnected. See if it turns on, if you still get a blinking green light then go ahead and turn the laptop off.
At this point, unseat and reseat the memory one stick at a time in each slot one at a time. Try turning on the laptop after each stick reinsertion.
If that doesn't do it then disconnect the hard drive and the dvd drive from the laptop.
Then try turning on the laptop, if you still can't get video then the motherboard is bad and would need to be replaced.
At this point at least you would know for sure.
Posted on Aug 19, 2009
SOURCE: I have an Acer Aspire 4520, Will not turn on.
IT COULD NVIDIA DISPLAY IC PROBLEM,GET IT REPLACED.
DHARMAKKAN
Posted on Mar 21, 2010
Acer aspire xc-603 wont start up
can be a dead CMOS battery or some Power supply issue.
the best thing is to contact the official Acer support service.
Jun 01, 2016 | Acer Aspire Xc-603 Compact Desktop/...
Acer aspire 5750 won't turn on
check you fan make sure its running,,some times if its not it wont let the laptop start.
Apr 16, 2014 | Acer Aspire Computers & Internet
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Feb 26, 2013 | Acer Aspire AM1100-B1410A Refurbished AMD...
My Acer 5552G won't turn on.
try a system reset see below link
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 20, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
I bought my acer aspire 7736z-4412 a little over yer ago. I don't do much on it other than check out facebook. It recently decided to shut down while I was online and now it won't start at all. I...
there are a few things that could cause this but here are the first two to look into before the last and worse case
your power adapter may have died. you need to have it checked. if it is ok then you porbably damaged the jack. if the jack is ok well then your motherboard has an issue. either the board is damaged or another problem exists.
Jun 29, 2011 | SIB 320GB 2.5 Inchs SATA HDD Hard Disk...
My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
Aug 05, 2010 | Acer Aspire L100 PC Desktop
My Acer Aspire 9300 laptop wont turn on......light indicators are on (motherboard light blinks once, light bulb and battery lights on) but no power to fans so no start up. have had this happen before but...
Very possible that something has short circuited on the motherboard. I would also try re-seating the memory located on the bottom of the laptop(which could be loose explaining the intermittent nature of the issue). On an IBM I once fixed that had the same issue I took out the CMOS battery and battery for one week and then re-installed and that fixed the issue. But good luck to you!
Sep 23, 2009 | Acer Aspire 5315 Notebook
We have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Aug 23, 2009 | Acer Aspire M1640 Refurbished Intel...
PC Will not start up at all!
Check the power supply. Maybe it's time for a repair shop.
Jun 09, 2008 | Acer Aspire T310 PC Desktop
Acer aspire 3680 - new out of box won't boot
NEED TO DEL PARTIONS MAKE NEW ONES FORMATT THE HD THEN INSTALL XP AGAIN AND UPDATE
Jan 22, 2008 | Acer Aspire 3680 Laptop
Open Questions:
VIPRE RENEWAL 18O0935-6318 INSTALLATIONS VIPRE TEC-H SUPPORT CARE VIPRE DAIL 1800-93S-6318 AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number.AVAST Tech support phone number. AVAST technical support phone number. AVAST customer support phone number. AVAST customer service phone number. AVAST Customer care phone number
Jul 17, 2018 | VIPRE Computers & Internet
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
