Like, i turn it on and it goes to the main screen and i try clicking on the different sections to go to my music for example, but it doesnt let me it jsut stays on the main menu. how do i fix it ?? its a polaroid pmp280-4
  • Computers & ... Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Posted on Mar 19, 2011
How do you add the music to the slide show?
Dear annettesamto
First do the photos. When you have finished that, click on the "Next" button at the bottom of the window. Now look for your music files by clicking on the "Select Audio Files" button in the "Soundtrack" section. For example, go to "My Documents" and then select the "My Music" folder and click on "Open". Select the music file you want and once again click on "Open". The track you have chosen should now appear in the white area in the "Soundtrack" section. Repeat this to choose more music tracks until you are satisfied with your selection. To delete any tracks from the list, select it in the "Soundtrack" section and then click on the little dustbin to the right and just above the white area where the names of the music tracks are.
Hint: Try to get the combined length of all your music tracks ("Total audio time") close to the "Duration of Slide Show". Then decide how long (in seconds) you want every photo to be displayed before the slide show moves on to the next photo. All your photos will be displayed for the same amount of seconds. In the "Duration" section, at "Set Duration", type in the amount of seconds you would roughly want your photos to be displayed for (for example 8 seconds). If the "Duration of Slide Show" and "Total audio time" is the same or very close, you can ignore the part where it says "Auto-Fit to Soundtrack". However, if the difference is several seconds or more, click on "Auto-Fit to Soundtrack". This will ensure that your slide show (photos) ends when the music ends. It means that your photos may now be displayed for slightly less or more seconds than the amount you indicated, but at least the soundtrack and the photos will end together.
When you are satisfied with your soundtrack, click on "Finish" at the bottom of the window. If the computer asks you if you want to replace an existing file, click on "Yes". The soundtrack window dissapears. Now click on "File" at the top left of the window and choose "Save Project".
You can listen to your soundtrack by clicking on tab 3 ("Produce") and then on the "Enter" button on the remote control.
You should be aware that some music files may not work with SlideShow Expressions, particularly some files that have been downloaded from the internet, for example through iTunes. This has to do with copy-protection and causes some tracks not to play properly. As a rule, though, mp3 files should work fine, as well as tracks ripped from CDs, like wma files. The User Guide gives a list of all the supported music files. The User Guide is on the install disc. To find it, insert your install disc and click on the relevant link that appears, or you can go to "My Computer", right-click on the CD/DVD drive and click on "Explore" to look for it on the install disc; it is a pdf file.
I hope this was helpful. The best of luck to you.
Hendrik Uys
Oct 07, 2012 | Individual SlideShow Expressions
Pmp4000 unit. can i designate different effects to different channels at the same time?
only 2 effects can be used at a time. you assign the effects in your lil digital section in the master part of the board by turning the black knobs so the lit up numbers change to the effect you want then push the black button to lock it in. at which 2 of your aux's ( the last 2 i think its 5 and 6 ) control the SEND to your EFFECTS and the fader below the selections control the amount of effects goes into the MIX.
Aug 31, 2011 | Behringer PMP4000/B1520 PRO Mains &...
My sharper image touch mp4 player has downloaded music that does not show up under the music icon, but it does show up under the files icon. I have to go into files and pick a song and it will play that...
you have to go to the music icon on the main screen. click it and then scroll down to "add to audio list" press "upward directory" the "music" pick the song you want click it, it will bring you to the name of the album. click that and it will show the song, click that. a little screen should pop up and say "sucess" it will then show up in your song list under the music section. you have to do this for every song.
May 15, 2010 | Audio Players & Recorders
Hi have 16gb touch when I hit the music button the
The best starting point to sort this is to got itunes and connect your ipod. Click on the listing for for your ipod and use the restore facility to return your player to its original settings. You will then have to synch the ipod with itunes to reload your music etc.
The apple home page trouble shooting section has clear instructions on how to use the restore facility and may also have other useful answers to your problem.
Jan 20, 2010 | Apple iPod touch
Blank screen for music and videos
is it when you enter music,photos or settings the screen is blank and it's like it's lagging? but after a short while it goes back to the main?
Jun 29, 2009 | Apple iPod touch
Change ring tone
Here's how to choose your phone's tones, alerts, vibration etc: 1. On the main standby screen, press the white menu button.
2. Select "Settings".
3. Select "Personal".
4. Select "Profiles".
5. Double-click on the profile you normally use (this will usually be "General").
6. Select "Personalise".
7. Click on whatever you want to alter (for example "Ringing Tone" to change the call ringtone). Note that there are different ringtones for ordinary and video calls, and different settings for keypads and touchscreens.
8. When you've finished altering the settings, press the red button to go back to the main standby screen.
To switch to a different profile, tap the standby screen's date and choose the profile you want.
How to choose a ringtone from the music player You can also select a ringtone from the 5800's music player, just go to the track you want to use and select "Options". One of the options will be "Use Tone", giving you the choice of using it as the ringtone for the current profile, or as the tone for a specific person.
Jun 24, 2009 | Nokia 5800 XpressMusic Smartphone
IPod Touch Automatically Reverts to Main Menu Screen
you need to restore your ipod touch by connecting it to your computer and clicking restore. make sure you have backed up your ipod touch before you do this or you will lose everything on your ipod touch.
Jun 16, 2009 | Apple iPod touch
I have just bought of ebay an ipod nano 8gb, problem is it i tunes doesnt recognise it, also the display sems to be very odd for example in music it will say initializing then root:/i'm alive celine dion ,...
after resetting it, does it say rockbox then go into some weard menu?
If so, try resetting your ipod and imediatly placing it on hold the second the screen goes black. it might have another operating system on it, and is probably dual boot. I have done this to mine and that is how you get into the Itunes side of it.
Jan 16, 2009 | Apple iPod MA446LL/A MP3 Player
LG CU500 Memory Car problem
try this.......
type 277634# * # (no spaces)
click port setting
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
and i think it only takes up to 1 gig
Jan 04, 2008 | LG CU500 Cellular Phone
Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Jun 05, 2007 | Denon AVR-2106 Receiver
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
