Question about RCA F36450 36" TV
Wont turn on
Thank you for your advice. If it was the tube, is that costly repair from a tv repair shop or should i just get a new tv? i would just like to weigh out my options. Thank you
  • 57 Answers
Very expensive. depends on what the tv cost. how old is the tv? 36 inch tubes are high, especially now that glass tvs of that size are becoming rare. I didn't check the specs on that tv, but if it is not hi-def you might as well upgrade. I like rca too, its my favourite, but they don't last forever.
However if it is merely the transformer, that could be less than $100. You may be able to get a free checkup for the tv/estimate or maybe one for under $50. those tvs weigh a ton though...
Posted on Aug 03, 2008
I need to have the screen replaced on my telly how much am i looking at
Not worth replacing the screen as the cost seems a huge factor . Also taking into consideration that you need to get this part delivered with insurance , along with the freight it might not be worth the RISK. Also after spending this much you still sont enjoy any warranty. I prefer that you scrap the TV ,might get some amount for the working bboards and go in for a new model with improved features.
Try for any exchange schemes from dealers.
Thank you for using fixya.
Sep 22, 2011 | LG 42PJ350 42 in. TV
RCA 35" tube tv buzzing
Its probably the power coil. It it's buzzing it wont be long before it goes. you can try degaussing it if the TV has that ability otherwise you would have to bring it into a shop no idea on the estimated repair cost.
Thanks
Dustin
Jan 22, 2011 | Televison & Video
Picture is a blue screen but the cable and sound still works. The picture briefly appears when we turn on the tv then it fades to blue. Its a Prima tube tv.
It sounds like the picture tube is shorting at the blue gun. Most of the time it is not cost effective to replace the tube. Have a repair shop check it out and see if that is the problem. Thanks
Oct 21, 2009 | Televison & Video
My tv flashes red or sometimes green and then turns off
If the TV only flashes red and green sporadically, it could simply be a loose connection inside the TV that connects to the picture tube. If the TV remains red or green, then the problem could be the tube or one of the circuits that control one (or more) of the colors.
Your best bet is to take it to a reputable TV repair shop. If it is simply a loose connection, it won't cost very much to have it fixed. If the problem is more advanced, at least the shop will be able to inform you.
At that point you can decide if the cost of repair compares favorably to getting a new TV.
I hope this helps.
Aug 19, 2009 | Sony KP-57WS500 57" Rear Projection...
Ive got a 29'' tube flatscreen that wont work no more
seems to be an issue with picture tube.Please try after changing picture tube
Jul 28, 2009 | Televison & Video
Sony KV-32S42 (See Description)
It may be a fruitless effort. The main reason this occurs is that the Picture Tube is drawing too much current and the AKB circuit will not let the video circuit diplay the picture. Outside
of replacing the Picture Tube there is no fix.
You can varify this by turning the screen control up. This is usaully located on the HV transformer and is marked. the other location it may be is on the CRT board. It also would be clearly marked. If you adjust this slightly and the picture appears, the Picture Tube is the problem. I'm betting 100% it's the Tube.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony KV-32S42 32" TV
AKAI PT5598HD won't turn on
take it to a repair shop and have then look at it. it may or may not be worth the cost of the repair. i dont know what the parts and labor would be on it
Nov 15, 2008 | Akai PT5598HD 55" Rear Projection...
Toshiba 27D46 27" TV Problem
Hi
It will not be the picture tube. Your set will have cracked solder joints in and about the vertical output stages. This is not a major repair, and will require re-soldering of that stage, and maybe a few capacitors replaced as a cursory repair as preventative maintenance. should cost between $50-80 depending on who you get to look at it. If you are quoted a price higher than this, I suggest ringing around repair guys in your area and be careful to explain exactly what you have described the fault as here.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
May 29, 2008 | Toshiba 27D46 27" TV
TV wont come on
the picture tube is most likely not out. but there is a problem in the high voltage transformer part of the set( this is what fires up the picture tube). a problem like that can be just as expensive as a new picture tube. if it's not still in warranty it would be cost prohibitive to repair.
May 02, 2008 | Televison & Video
No picture or sound
The most common cause for a bowed picture is the convergence power supply module. The module will fail and sometimes blow the fuse. Average cost of repair would be around $100, if you brought it to a tv shop, more for in home service.
Sep 08, 2007 | RCA P46920BL 46" Rear Projection...
RCA F36450 36" TV Logo
252 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
