Question about Teac MC-DX20B CD Shelf System
When I play a CD I get a buzzing sound. The sound starts as soon as I hit the play button (and before the CD is actually moving.) It gets louder once the CD starts playing. The sound is coming through the speakers. It's been getting louder over time. So loud now that the system is unusable.
    Brigadier General:
  • 8,546 Answers
Buzzing is usally AC line noise leaking into an un-shielded cable somewhere or a floating ground. If the AC plug is reversible, try that. Sometimes the buzz is from an attached device. Make sure all audio cables are plugged in tightly at each end and routed away from or at right angles to any power cords and away from other sources of strong magnetic fields like TV's. I've also seen variable track lights induce noise but it's usually minor.
Posted on Mar 19, 2011
Testimonial: "After moving the stereo away from TV, and figeting with wires, the noise disappeared! Later I unplugged the unit from the wall & it started again..."
  • robbie3 Mar 31, 2011
    Thank you very much for your help with this. I couldn't get rid of the noise after unplugging/replugging...and in the process seem to have damaged my speakers! No no sound at all. I guess it's time to send it to TEAC or something. Thank you again.
My TV takes about 15 minutes to start playing.
It sounds like you have a problem with your signal board. The signal board will need to be replaced.
you can get parts for this tv at www.interliquidparts.com
Feb 22, 2012 | Televison & Video
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
My 1999 Oldsmobile Alero is making some baaaad noises!
check theb power steering oil level you may have ruptured a pipe perhaps ?? also check brake fluid level get them fixed as soon as possible
Mar 14, 2009 | 1999 Oldsmobile Alero
User gets the above error on the actual printer " error 09.038.46:43938 "
Solution:
  • Turn off the printer. Turn on the printer.
  • As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
  • Release the buttons, it will now come up in the service mode.
  • Scroll down to the function menu, hit ok, scroll to clear isc fault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Mar 12, 2009 | Xerox Phaser 8500N Printer
Humming/buzzing sound
That could be either the ballast, or colorwheel. Does the sound get louder at the rear of the tv or louder in front. let me know I may be able to help you.
Apr 08, 2008 | Toshiba 46HM95 46" HDTV
Buzz from speakers or headphone when CD is played.
This is due to improper insulation of wires or improper isolation of power unit with the rest of the unit.
Thankyou
Feb 10, 2008 | Teac CD-X8 CD Shelf System
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Sep 14, 2007 | Sharper Image SI686 Clock Radio
Teac MC-DX20B CD Shelf System Logo
613 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
