Question about Electrolux Dishwashers
I need a drain filter for Dishlex Glendale.Series Eco Save Dishwasher, purchased 1996. Can you help with the correct model and part number.
SOURCE: dishlex global 300 flashing eco
i have a ge dishwasher that wont let water out like its supposed to. this morning i got up to water on the floor and water still in the bottom of the chamber what do i do to solve this problem
Posted on Aug 29, 2008
SOURCE: Dishlex dishwasher global 300. Dishwasher
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Posted on Nov 05, 2008
SOURCE: Dishlex global 300 dishwasher, eco
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Posted on Jan 09, 2009
  • 134 Answers
SOURCE: Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Posted on Feb 14, 2009
  • 574 Answers
SOURCE: Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Posted on Jan 25, 2010
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and...
The symptoms on a Dishlex Global 300 dishwasher:
  • eco light is flashing constantly;
  • noise on pump running continuously;
  • but the unit will not operate.
Possible corrective actions include:
  • water level - pls check incoming water pressure, filter, water level sensor, water valve;
  • base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
  • Air/dry/ventilate the unit/system for a couple of days;
  • reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 26, 2008 | Dishwashers
Hi there, we have had our dishlex 300 dishwasher switched off for a while and today I turned it on. I started a cycle and it stopped after a few minutes and then the Eco button started flashing. I opened...
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Dishwashers
My dishlex dishwasher 160 series has stopped
Have you disconnected the drain, fresh water, power and the 2 to 3 mounting bolts to the counter?
Mar 07, 2010 | Dishwashers
Dishlex dishwasher has flashing eco light and won't stop draining
you need to remove the bottom panel under the door, under the machine you will find a small cup on an arm attched to a micro switch this cup is for an over flow ie when the fill setting is incorrect or when the wrong detergent is used ie to many suds empty this cup, thsi should solve your problem
Sep 04, 2009 | Dishwashers
Dishlex global dishwasher, stuck on eco, eco light flashes and drain pump runs
Try turning the taps on harder, I read that someone else had the same problem and this fixed it for them.
Aug 18, 2008 | Dishwashers
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Jul 01, 2008 | Dishwashers
Dishwashers Logo
47 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
