Question about Dishwashers
Conia cdw0302 dishwasher When turned on error 004, comes on display panel. Can this be fixed?
2 Suggested Answers
SOURCE: conia dishwasher CDW0302 error 4
empty dishwasher clean drain in bottom, close door, check that drain pipe not kinked, tip forward to 45 degree, check pipe again when putting back down, you may have to tip it forward a couple of time if it does not work the first time
Posted on Nov 22, 2009
I need the instruction manual for a conia CDW0302 dishwasher as error message keeps coming up
https://ckquiverdri.cf/conia-dishwasher-cdw0305s-user-manual
- possible link to manual download
http://onewebglobal.com/dishwasher-error/conia-dishwasher-error-codes.php
- link to error codes tutorial
Jan 03, 2018 | Conia Televison & Video
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Error Code: 004
shut off power to the unit first or unplug it after 1 min turn back on this may solve the problem
Aug 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Conia dishwasher CDW0302 error 4
Jan 09, 2009 | Dishwashers
E4 error on new conia dishwasher
Had the same problem. First you will need to tilt dishwasher back 45 degrees and tip out all excess water. A couple of towels on the floor are a good idea.
Second check that the little nozzle on the elbow under your sink where your overflow attaches is drilled out.
This fixed my problem after fussing around for a day and I was starting to disconnect everything to take it back.
Sep 15, 2007 | Dishwashers
Danby ddw2406
Simple solution. DO NOT spend the money on a tech coming to the house.
This error code comes from getting too much water in your machine, either from a dish filled with water emptying, or perhaps a clog from the sink that prevents your machine from draining. It is meant to prevent overflows from too much water being in the tub. It is a simple fix though!
First of all you should at least shut the power off on your machine. For the effort of a couple of more steps, it wouldn't hurt to shut the breaker off at the fuse panel. You will have to unscrew the undercounter tabs that mount the dishwasher to the countertop. They are located just under the counter sticking out from the top of the dishwasher when the door is open. Then proceed to pull out the dishwasher from under the counter. You will only have to pull it out about half way and you will find the overflow valve. It is located on the right side of the dishwasher just under the insulation and level with the lower hinge on the door. (Right side when you are looking at the machine.)
There are two overflow valves. One looks like a small cup, the other looks like a cylinder with a float in it like your toilet. Both of them have black rubber covers near the bottom. Take these covers off and about a quarter cup of water will flow out of these overflow basins. Allow them to completely empty, then replace the rubber drain covers and then replace the unit under the counter.
Once you turn the power on, the error code should be cleared and you are ready to use the dishwasher again.
Jun 03, 2007 | Danby DDW2406 Stainless Steel Built-in...
Error message 004
Simple fix for me
Simply look at right side of machine get a flash light pull the insulation away from machine stick the light in look for the white little resovoir and the styrofoam float switch.
syphon the 1/2 cup collection this allows the float in the attached
cup to drop kicking the sensor out....
I dont suggest disconnection the sensor as im sure it will come back to haunt you. =)
worked for me takes 5 minutes
enjoy
Nov 12, 2006 | Danby DDW1805W Designer Series...
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
