Question about JVC HD-56G786 56" Rear Projection HDTV
I deed the schematics i opened it up becuase it was to dark from dust so i cleaned it up and put it back together except for one switch it has two leads coming of it one goes to the sensor over the lmp the other is the ground the switch itself just looks like a brake with a little blue needle like appendage could you tell me where it connects too. or show me the schematics?
    Problem Solver:
  • 11 Answers
Call the eletricians
Posted on Mar 19, 2011
How to open it to replace battery?
U need special miniature screw driver set to do the deed. The screws are located under the stickon tag that runs for the entire length of the unit on the bottom. (For Garmin GPS)
When you go to open the unit do so very slowly because on one side of the unit there is a ribbon connecting the front to the back of unit and if you open the wrong way you will break it. Carefully remove old battery, replace, and put back together.
Oct 08, 2015 | GPS
White knight 427wv
Hi... You would have disconnected the door switch. Kindly check the wires and reconnect if disconnected.
Jan 29, 2014 | Dryers
I need a repair manual to show assembly of the power switch
Not sure about the repair manual.. here is a link to the schematics I used:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/LS1013FL
For better view use the PDF version.
Jan 08, 2010 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Copier prints dark on lightest setting
this could be down to several thisngs lift the lid on the top and look at the glass area does the underside look clean or dirty? have a look at the scanner area to see if there is dust ont the mirrors you should see this when you do a test copy press the print button and look at the light unit and the mirrors as they move across the glass if you can see dust or dirt on the mirrors they may require cleaning.. if so turn the machine off take out the screws holding the glass in place lift the glass out carefully.. sometimes they stick down if they havent been cleaned lately so pull up.. take a clean dust cloth slide the scanner unit out for access and clean of the mirrors.. p[ut back together and test if no better open the fornt door and look at the units inside to see if you can take them out..give these a check to see if there are marks on the surfaces of the units.. if the copies are dark usually on a old copier its down to the dust..
Aug 04, 2009 | Office Equipment & Supplies
1997 ford taurus gl back passenger window stoped working except ever once in a wile whats wrong ?
The switch might be burnt or dirty, or the wires could have fused together from over-use and/or resistance when opening. This puts higher pressure on the window motor and causes wires and switches to get extremely hot and melt wires or burn the switch contacts, try cleaning the switch first, then if it's still not working open the door panel and trace the wire from the switch to the motor and from motor to control panel. Repair where neccesary.
Mar 09, 2009 | 1997 Ford Taurus
GE side by side by side,water drips from bottom freezer door
I have the same problem. Just talked to a friend that's a great appliance repairman. he said I have to remove the panel in the back inside of freezer and there is a drain that gets clogged up, a little hole or tube.
clean that and should work fine and stop leaking. I haven't had time yet, but this weekend I'll do the deed. Hopes this helps ya!
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Dec 09, 2008 | Lasko Ceramic Heater
PS2 TROUBLE SHOOTING/ POWER
Hi, I think what probaly happened was when you were cleaning it you pulled out a wire or cable. When you clean you have to be careful, you should always go onto a website check how it is done. The best thing to do is to take it to someone who can repair for you.(It does not cost much) Hope it works again.
Jul 04, 2007 | Sony PlayStation 2 (PS2) Console
JVC HD-56G786 56" Rear Projection HDTV Logo
53 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
