Computers & Internet Logo
Posted on Mar 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Steps of how to put a wep key on D-link router
Anonymous
Level 2:
Sniper:
  • Expert 69 Answers
  • Posted on Mar 19, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
69
Questions
Helped
19360
Points
244
Download the manual from here, then just follow the guide. It not hard :-)
How do I obtain the WEP Code for this Router? I'm trying to hook up my Internet capable LCD TV
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Click here if you cannot access the web-based configuration.
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
  • 64-bit encryption 10 characters
  • 128-bit encryption 26 characters
  • 256-bit encryption 58 characters (available on DI-614+ only)
  • The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
    Step 5 Click on the Apply button then click on the Continue button to save your settings.
    Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
    How do I enable encryption on my D-Link adapters?
    If you need more help come back.Post /thumbs / testimonial are welcome!
    tip
    How to set up WEP on Linksys Router
    Setting-Up 152-Bit WEP Wireless Security on a Linksys Dual-Band A+G Wireless Router
    Question
    How do I set up 152-Bit WEP on a Linksys Dual-Band A+G Wireless Router?
    Answer
    Wired Equivalent Privacy (WEP) can be a 64-bit key with 10 hexadecimal digits, a 128-bit WEP key with 26 hexadecimal digits or a 152-bit WEP key with 32 hexadecimal digits. This encryption will prevent other users from connecting to a wireless network using your own WEP key. It will also protect your wireless transmissions/communications from being accessed or received by other users.
    NOTE: Make sure to change the wireless settings of either Wireless-A or Wireless-G depending on the standard your network is using.
    152-bit WEP key only applies to 5GHz 802.11a Wireless enabled network.
    To setup WEP Wireless Security on your Linksys router follow the steps below.
    Setting-Up the Linksys Router to use WEP
    Step 1:
    Access the router’s web-based setup page. For instructions, click here.
    Step 2:
    When the router’s web-based setup page appears, click Wireless then click WirelessSecurity.
    Step 3:
    Look for SecurityMode and select WEP.
    For Wireless-A Settings:
    4439-001.pngFor Wireless-G Settings:
    4439-003.pngNOTE: If the screen on your router’s web-based setup page looks different, click here.
    Step 4:
    Look for the Encryption drop down menu and select 152 bits.
    Step 5:
    Look for Passphrase and type a wireless network password of your choice, then click Generate. In this example “MySecretKey” was used.
    NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 16 characters.
    Step 6:
    When you click Generate, the result will be a string of random characters.
    Step 7:
    Look for TXKey and select any number to determine which key you’ll be using. In this example, we selected 1.
    4439-005.pngStep 8:
    Copy Key1 since 1 was selected under TX Key.
    NOTE: Do not give this key to anyone. This will be your wireless network’s key.
    Step 9:
    Click 4058-005.jpg.
    © 2010 Cisco Systems, Inc. All rights reserved.
    on Feb 26, 2010 • Computers & Internet
    How do I secure my D-Link WBR-1310 wireless router?
    You can follow these steps in enabling wireless security on your router and do this steps using a computer wired to the router since once you save the settings your wireless network will be secure.<br /><br />1) Open the internet browser and type the address 192.168.0.1 to login to the router. The default username is "admin" and leave the password box empty.<br />2) Click "Wireless Settings" on the left side.<br />3) Select the Security Mode ,Enable WEP Security.<br />4) Select the Authentication ,Shared Key.<br />5) Select the WEP Encryption , either 64-bit or 128-bit.<br />6) Select the Key Type ,HEX (only A-F and 0-9 number allowed) or ASCII (all number and character allowed).<br />7) Enter a WEP key as your security password to login to your wireless later.<br />8) Press Save Settings to save all settings changed. Reboot the router.<br /><br />
    2answers
    I have a D-Link DIR 615 wireless router i am trying to connect my daughters DS to the wifi but it keeps asking me for a WEP KEY???? i dont know the wep key i put the serial number in and the password but...
    WEP KEY
    WPA KEY
    When you will make WEP key then you have to put this key on your pc first for connect to internet. It is very easy steps & your network will make secure.
    First check your network option also.
    Right click on your network then you see the property then go to security See dropdown menu If you have wep key then follow these steps if you did not see thi.
    WPA is same as WEP
    (WEP)
    You need to sign in your router first.
    1.open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1)
    http://192.168.0.1/
    2. Select "Admin" from the drop-down menu and then enter your password. Leave the password blank by default.
    Now you can see your D-LINK webpage where you find your wep key.
    Clik setup then wireless setting
    Now you see on this page
    1. Wireless Security mode then drop-down-menu Set Enable WEP
    2. Authentication - Choose Shared Key.
    3. WEP Encryption - 64 Bit.
    4. Key Type - HEX
    5. Default WEP Key - WEP Key 1
    6. Now Make a key( You can choose any password but remember only 10 charcters allowed)
    7. Now Save setting. then your router gonna boot up make sure let it boot. It connected after 5 minute.
    You should write your password in paper first then you will have to add this key into your pc. network.
    You can not connect internet because you have to put these Key(password) into your pc first.
    Go to your network connection in your pc Choose your network
    Or
    You see two computer( internet icon) on the desktop
    Right click then connect to network then you see so many network & your network ( Which you create).
    Right click on your network then you see the property then go to security choose wep key then put the password(KEY).
    WPA
    1. Wireless Security mode then drop-down-menu - EnableWPA
    2. Clipher type -TKIP
    3. Passpharse - create own password here( don't put any personal info there)
    Save setting
    Device restart.
    Now check Network status. Its working now.
    Follow youtube video
    1helpful
    I want to encrypt a wireless network with wep
    Question
    Answer
    Step 1:
    Step 2:
    Step 3:
    Step 4:
    Step 5:
    Step 6:
    Step 7:
    4439-005.pngStep 8:
    Step 9:
    Click 4058-005.jpg.
    1helpful
    2answers
    How do I put an encryption on my linksys router?
    Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
    • Enabling WEP or WPA on the Router
    • Enabling Wireless MAC filter on the Router
    • Disabling SSID Broadcast on the Router
    NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
    Enabling WEP on the Router
    Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
    a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
    b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
    Enabling WPA on the Router
    Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
    • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
    • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
    To enable WPA, click here.
    Enabling Wireless MAC Filter on the Router
    Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
    To permit wireless computers to connect to your wireless network, click here.
    To prevent wireless computers to connect to your wireless network, click here.
    Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
    1helpful
    Finding a Wep/Wpa Key
    You need to open the router's admin page by opening your Internet Explorer. On the address bar type http://192.168.0.1 it will prompt you for username and password. By default the username is admin and the password is blank (no password). You can see the WEP or WPA key on the WIRELESS tab. Goodluck!
    3helpful
    2answers
    Setup security
    To set up a network key (password to access the network), follow these steps:
    Open your browser and go to 192.168.0.1
    Depending on your router's model number, the username/password combination will be different. Try admin/(blank), admin/admin, or user/(blank), where (blank) is not putting in a password at all.
    If you look through the tabs and option pages, you will see a section for WEP or Network Key. A 64-bit WEP key is enough, you do not need a 128-WEP or a WPA key.
    Make sure you apply the settings before closing the page.
    WEP Encryption
    It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
    WEP Encryption
    Grand Canyon Tech
    Grand Canyon Tech
