Question about Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard
Machine boots gives a startup beep then blue dump which fades to black screeen.
  • Gigabyte Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Mar 19, 2011
Testimonial: "that is fast...!! Very good."
Copy machine screen fade
check the side of the screeen (left side) u will see a nub like a volume conrol nub , use it to adjust the screen density
Dec 27, 2013 | Ricoh 885400 Aficio 885400-C Black Toner...
Black screen blue box saying
some one must have put in a boot password to your laptop,
follow this:
When booting up, enter your BIOS setup (usually by pressing the F2 key at the appropriate time).
Locate the BIOS Password section and turn the ON STARTUP password to off. There is no standard setup for BIOS, so I can't give you exact instructions.
If this does not work, try:
remove cell & start your pc you will here beep...beep...beep...
then turn off your pc & restore your cell.Start your pc and
password is removed.
there is a battery on motherboard,a button cell,you can try removing that and start computer, then put it back, bios settings will be lost.
you can also try removing any hardware like ram,if you have two,when system is off,turn on , it will prompt for changes , enter bios and try remove password.
Dec 15, 2013 | Gateway LT2001u Netbook
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Asus Pundit P1-AH2 Barebones System not booting
Try this press ESC, if this did not work press F1 or F2 lastly F8. Accessing the bios depend on manufacture. Process press the key and power if on the pc and keep pressing the key till hearing the beep or bios screen will turn on. Hope the info will help you access the bios screen.
HH
Apr 23, 2009 | ASUS SOCKET AM2 AMD ATHLON 64 X2/64...
EVERY TIME I TRY TO TURN ON MY DELL COMPUTER IT ACTS LIKE IT IS ABOUT TO START UP BUT THEN GO TO A BLUE SCREEEN AND GIVE ME A ERROR MESSAGE AND WILL NOT GO ANY FURTHER
BSOD = Blue Screen of Death
You have a problem with Windows booting.
When you computer starts up and it has passed the bios check start pressing F8 until you get the Windows start up options, select safe mode and see if windows then boots normally.
If it does then search/run msconfig.exe, on the General tab select Diagnostic startup, click OK and reboot and see if windows now loads.
If it does then you have a program or driver installed that is conflicting in Windows, so remove any recently installed programs or hardware drivers
Go back into msconfig and select Normal startup and see if Windows boots again.
See how you get on with that
Apr 19, 2009 | Computers & Internet
Machine will not boot. Sdreen message "no input signal"
When you say the machine will not boot, do you mean that you do not even get the startup splash screen during the post? And when you say you tried reinstalling, Did you get the Vista DVD to boot? If the Vista DVD would not boot the system, then activation is not the problem. Your system should give you at least a single beep during startup. If you aren't getting this far, then your problem could be either the motherboard or the power supply.
Jan 20, 2009 | Computers & Internet
Won't pass startup bios / screen
Make a note of the number of beeps and whether they are long or short. Put the old video card back in the machine. Go online and do a search for "bios beep codes", check what you wrote down and see what the problem was. It was probably a video error. Perhaps you should install the video drivers for your new card before you install it, that way it might avoid the error on startup.
Jan 05, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Problem software not support motherboard
when the message say that incorrest boot divice means the boot order is wrong so go to bios by pressing the key F1 or F2 or F10 or DELETE when the computer try to boot up then go to boot order and change the order for the first your hard drive save it and restart the computer but if there is no operative system you have to re install it that message say it can not find the operative system on the boot order devices
Dec 31, 2007 | Intel Motherboard
Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard Logo
60 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
