Question about Cameras
I have a Panasonic fx150. The lens is stuck. It wont retract. How can i fix this problem.
  • 62 Answers
Hello
Unfortunately a lens error of this nature is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
You may find it more cost effective to purchase a new camera as opposed to the repair price on your current camera.
Posted on Mar 19, 2011
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
Lumix dmc-fx150 lens stuck
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Mar 15, 2011 | Panasonic Lumix DMC-FX150 Digital Camera
I have a polaroid i737 and the lens is stuck out and it wont turn on, any ideas how to fix this?
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 20, 2010 | Polaroid i737 Digital Camera
The lens is stuck
Dec 31, 2009 | Panasonic Lumix DMC-FX30 Digital Camera
The lens is stuck part-way out and the camera says turn off and back on. Off and on does not help.
Oct 30, 2009 | Panasonic Lumix DMC-LZ5 Digital Camera
Camera focus error
there is a small logic circuit that controls the motor that retracts the lens and a sensor that tells it the lens is retracted, it is a lens position sensor, one of these two components is most likely defective, the thing is there are no consumer service info provided by panasonic, they will not sell you parts either, the camera is a mystery to take apart and repair without the tech manual which u can't get, so u see the delima here, u must either have this camera fixed by a panasonic repair station or see if it qualifies for a upgrade exchange program for a newer model.
Aug 07, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Fix a lens on my dmc-fx9
It sounds like you have a gear problem in your lens. If you need some good used parts for your FX9 you may want to contact a guy in South Carolina who has lots of parts for all the Panasonic Cameras at reasonable prices. I think his email is gerald.ray@aa-ark.com
Nov 07, 2007 | Panasonic Lumix DMC-FX9 Digital Camera
Lens stuck
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 22, 2007 | Panasonic Lumix DMC-LC43 Digital Camera
Internal lens Cover
No fix -Panasonic may help on the customer support line
Apr 12, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Cameras Logo
19 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
