Question about APC APS BackUPS CS 650VA 400W 230V DB9 RS232USB (BK650EI) UPS System
When connected to power the green light is not showing and the battery light is is always on
  • 32,281 Answers
This indicates the battery is worn out and will not provide power in the event of a mains power failure.
To test the battery, connect a computer or some other device to the output on the UPS, and connect the UPS to the mains supply. Turn on the mains power to the UPS and power up the computer, then turn off the main power to the UPS and if the computer switch off in a short time.
This proves the battery is old and needs to be replaced.
Posted on Mar 19, 2011
My charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
Jul 29, 2012 | Razor E100 Electric Scooter
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
Pronto M6 chair will not work. When the power switch is turned on, the LED light flash Red followed by three Green. I can't find what this error code meas.... Pls Help thanks Phil
Phil the red means battery is low and the green is a speed limit code because of the low battery if you have charged your batteries and you still get the red then you need to check the charger after charging all night does the yellow light on the charger turn green? if when you first plug in the charger if the red light is on and the other light is green then there is a problem with the wiring or connection to the batteries from the charger and you aren't charging the batteries. if when you plug the charger in and you get a red and yellow light then the charger is working but you don't ever ge a green light and the battery level gauge is still showing red then you need to replace the batteries Hope this helps
Apr 12, 2011 | Invacare Supply Group Pronto M61 Standard...
Usually the red light is on to indacate the batteries are being charged,now the green is the only light that is on
The green light on the charger usually indicates that the batteries are fully charged and you are ready to go. Does the controller show the batteries are fully charged? Can you operate the power wheel chair for several hours? If so, you are good to go.
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced.
Dec 20, 2009 | NRS Hoveround MPV 5 - Used Power...
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
My 3200 will only run when plugged into charger, won't charge bat
Try dusting the connector pins on your laptop and connecting the battery back.
Jun 24, 2009 | Averatec 3200 Notebook
IBM X226 server
i have two x-series server but in one server with one power cords it is showing green light but in case of another server it is comming yellow light.
Nov 24, 2008 | IBM xSeries 226 Server
Will not turn on. Toshiba 2060cds
I am having a hard time finding the manual for this older laptop, but, there is always a power button somewhere on the laptop itself, on the side, front, top of the keyboard, push everything and anything till you find it. Just plugging it in will not turn it on.
Apr 06, 2008 | Toshiba Satellite 2060CDS Notebook
APC APS BackUPS CS 650VA 400W 230V DB9 RS232USB (BK650EI) UPS System Logo
179 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
