Question about Topeak Comp 140
How do i reset my topeak cycling computer....set the odometer back to zero
The distance, current speed, maximum speed, average speed and odometer are not correct on my rides. The wheel calibration is set correctly, as is the installation with the distance between the sensor
It sounds like your computer reset itself. This may be due to a sticky button, as most computers are installed at the same place where folks have their aero bottles. Some of the nice sticky glucose liquid runs onto the computer face when you drink, gumming up the buttons. Try wiping your computer face with a hot damp (not dripping wet) rag. If this is the problem, the hot water should remove the sticky stuff on your buttons and allow your computer to work properly.
Oct 10, 2014 | Topeak Panoram V12 Mini 12 Function Cycle...
Topeak comp 150 directions
If anyone still needs a Topeak Comp 150 manual, it's still available for download from here:
http://www.m.topeak.com/mediafiles/assets/177
They haven't made it easy though.
Apr 23, 2012 | Topeak Cycling
I just had a new battery installed yesterday and this morning there is a message appearing on my dash board >>> TRIP B 199999????????
There should be a peg or reset button next to the odometer. Pessimism and hold for 5 second or so. It should re.set to zero. Your car has two resettable odometers Trip A and Trip B. They can be used to measure the distance of a trip. I normally reset A each time I fill the gas tank and B each time I get an oil change. Nothing to worry about. You can cycle through the three odometers by pressing the reset peg for 1 second or less. The third odometer view is the total miles on the car and cannot be reset.
May 27, 2011 | 2006 Ford Focus
Setting clock in 12 hour format instead of 24hr
You can download the manual here: www.topeak.com/mediafiles/assets/341/file/1
By performing a reset and setup under section A. of the manual you can select 24 or 12hr time.
Jan 06, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
Same thing: TOPEAK Comp 140 - manuals not avail from manufacturer
Have you tried calling Topeak? Here is their contact info:
1(800)2134561
Mon-Fri 9am-5pm EST
Sep 06, 2009 | Cycling
Need to replace part 6 of Topeak bike computer (model Panoram)
Just call/contact Topeak. In many cases they will send you the part as a warranty item at no cost to you. If not they can sell you what you need.
Feb 08, 2009 | Topeak Panoram V12 Mini 12 Function Cycle...
I need setup instructions for my speedometer
Download the manual from Topeak's website:
http://www.topeak.com/Service_and_Tech/Downloads
Jan 07, 2009 | Topeak Panoram V12 Mini 12 Function Cycle...
Topeak Comp 140 Logo
187 people viewed this question
Top Topeak Cycling Experts
Michial Gueffroy
dante
jimmarmor_ma
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
