Question about Health & Beauty
Crate FXT120 footswitch not switching channels.
SOURCE: The footswitch for bugera 6262
Hi ! Check and make shure that the cord conections between the pc board on the backplate of the amp to the logic board are firmly pushed in there slots.
Good luck , Stefan from Sweden
Posted on Jan 05, 2009
  • 5603 Answers
SOURCE: I need an owner's manual
I could not find a manual for the footswitch... USUALLY the details are covered in the amp manual it is connected to... and the only issue is if the particular footswitch is compatible with a particular amp.
Posted on Sep 06, 2010
  • 59 Answers
SOURCE: my crate gtd 65 footswitch is not working
sounds to me like your din plug on your controller is messed up ? hope this helps !
Posted on Jun 03, 2011
  • 5603 Answers
SOURCE: Wiring a crate 2 button
Mixing brands on footswitches, even within the same brand but different series is NEVER a good idea. While many can be converted by elecvtronics competent techs, the effort is usually not worth it for anything other than the simplest footswitch.
Posted on Aug 26, 2011
  • 4 Answers
SOURCE: Three button crate footswitch wires
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Posted on Jul 06, 2012
I have a Crate g120 cxl guitar amp. it is switching between channels on it's own. (no footswitch)
Hello Jamie.
Your right, it is not rocket science, this is way bigger and funnier!
Now, that you took apart the chasis fron the cabinet, you may try testing if the channel switching occurs when you hit the Printed Circuit board with some tool like the handle of a screwdriver. you can try with light hits and different places of the PCB while watching what happens in the front panel light. also you can try bending the PCB with your hand to see what happens, if the switching occurs, maybe you have a cracked solder on the pedal jack or in any component related to the switching circuit, in this case, you will have to pull out the pcb, and re-solder those points that can be cracked. Using a magnifiying glass is very helpful in looking for those cracked solders.
Good luck and best wishes.
Nov 21, 2014 | Crate Music
Crate gt212 foot switch
What is your question about the footswitch?
Mar 30, 2014 | Crate Music
Got a Crate VTX 15 guitar amp, and wondering if I can use a footswitch with it?
sure, why not, the footswitch connects between the guitar and the amp, with your guitar into the footswitch, go rock that thing!
Mar 10, 2013 | Music
Crate flexwave 120 head effects malfunctioning
That is probably a momentary switch that is dirty and sticking. These onboard effects on guitar amps are usually nothing more than a computer sound card and I've found bad connections going to and from them as well. I do think that switch is dirty and sticking, though.
Feb 19, 2013 | Crate FlexWave FW120H Guitar Amp Head with...
I have a Marshall mg100hdfx Head & Cab - The clean channel is on but when i hit the footswitch it is not changing to overdrive channel - please help
Sounds like either your "front-panel" switches are not set for channel switching or the footswitch's mechanical "Channel" switch is defective. According to the OM the "Channel Select Switch" on the front becomes inactive with the footswitch plugged in.
If disconnecting the footswitch causes this front-panel switch to operate properly then it has to be your mechanical switch in the footswitch. Repair of these footswitches are pretty simple provided you find a replacement and have soldering abilities.
Oct 25, 2012 | Music
Three button crate footswitch wires need to be refastened. I need a wiring diagram.
Sep 16, 2011 | Crate Cfs3
I need an owner's manual for the crate cfs3 3 button footswitch
Sep 02, 2010 | Crate Cfs3
Health & Beauty Logo
54 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
