Question about Samsung Color Fixed Security Camera Sod-14c
Say the system has 50 ft cablesfo the camers, but u need naybe 15 ft more that can u do?
    Master:
  • 346 Answers
Hello - Samsung seems to want to keep the exact wiring of this cable a secret -- It uses standard RJ-11 (phone type connectors).
While not widely available you can find cable couplers and extension cables at specialty places like the one HERE.
Best regards and thank you for bringing your question to Fix Ya.
Mikeywaf
Posted on Mar 19, 2011
    Master:
  • 403 Answers
As long as its cable run, should not be a problem. I went from 50 to 75 for my shop, works fine.but throw some e-tape around the connections.
Need head bolt torque specs for 1999 Oldsmobile intrigue
Ian: According to Chuck on FixYa.com:
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
May 14, 2015 | Oldsmobile Cars & Trucks
Pulled front wheel and fender off my 2001 roadking need torques for all nutsand bolts to r-install
Hi Anonymous, front axle 50 ft lbs. right fork slider cap nuts 15 ft lbs. fender bolts 20 ft lbs. caliper mounting bolts 35 ft lbs. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 09, 2014 | 2005 Harley Davidson XL 1200 C Sportster...
Need torque specs for 2003 fxdwg front axle nut
Hi Anonymous,
1. Front axle nut 50-55 ft lbs.
2. Front fork cap nuts 11-15 ft lbs.
3. Rear axle nut 60-65 ft lbs.
Have nice day.
Oct 05, 2013 | Harley Davidson FXDWG Dyna Wide Glide...
Torque the cylinder head bolts for mitsubishi lancer 2002
Try this
I dont know which engine you have.
420a
1. Torque all center bolts to 25 ft-lbs, torque the 4 corner bolts to 25 ft-lbs
2. Torque all center bolts to 50 ft-lbs, torque the 4 corner bolts to 50 ft-lbs
3. Re-Torque all center bolts to 50 ft-lbs, re-torque the 4 corner bolts to 50 ft-lbs
4. Tighten all bolts in the sequence from #1-#10 an additional 1/4 turn.
7-Bolt 4G63
1. Torque all bolt to 58 ft-lbs in order
2. Loosen all bolts completely to 0 ft-lbs
3. Torque all bolts to 15 ft-lbs in order
4. Tighten all bolt 1/4 turn in order
5. Tighten all bolts an additional 1/4 turn in order.
ARP Head Studs
1. Tighten all bolts to 40 ft-lbs
2. Tighten in steps of 10 ft-lbs increments until the specified torque that you are looking for is reached. This can vary with the amount of boost you plan on running.
Jun 30, 2011 | 2002 Mitsubishi Lancer
Need torque specs on axle nuts for dana 50 rear axle
Dana 50 Front Axle
Observe the following torques;
* Left and Right drive axles-to-cross member: 120-150 ft. lbs. (163-203 Nm)
* Axle arm-to-radius arm: 180-240 ft. lbs. (244-325 Nm)
* Coil spring insulator: 30-70 ft. lbs. (41-95 Nm)
* Upper spring retainer: 13-18 ft. lbs. (18-24 Nm)
Dana 60 Front Axle
* Drive shaft-to-flange: 15-20 ft. lbs. (20-27 Nm)
* Track bar nut and bolt: 160-200 ft. lbs. (217-271 Nm)
* Stabilizer link nut: 20-30 ft. lbs. (27-41 Nm)
* Stabilizer barU-bolt: 50-65 ft. lbs. (68-88 Nm)
* Spindle connecting rod-to-knuckle: 70-100 ft. lbs. (95-136 Nm)
* Front spring U-bolt: 95-100 ft. lbs. (115-135)
Feb 19, 2011 | 1986 Ford F 250
Camshaft torque settings ford puma 1.4
Crankshaft Belt Pulley 85 ft.lb
Rear crankshaft oil seal carrier 15 ft.lb
Camshaft Timing Belt Pulleys 50 ft.lb
Same TIGHTENING Sequence for Single OHC
Nov 24, 2010 | 2000 Ford Focus
Need torque specs for front wheel cross pin and nut and bolt in fork on 2005 1200 custom
Front axle nut = 50-50 ft. lbs.
Front axle pinch bolt and nut = 21-27 ft. lbs.
Front brake caliper mounting bolts = 25-30 ft. lbs.
Handlebar clamp bolts = 12-15 ft. lbs.
Front Fork
Upper bracket pinch bolts = 30-35 ft. lbs.
Lower bracket pinch bolts = 30-35 ft. lbs.
Fork stem pinch bolt = 30-35 ft. lbs.
Front fender fasteners = 9-13 ft. lbs.
Mar 03, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
Head bolt torque specs needed for 96 tbird 3.8
  1. 50 Nm (37 lb-ft)
Long bolts:
Short Bolts:
Mar 19, 2009 | 1996 Ford Thunderbird LX
Filter for QCA Aruba xl
QCA has used 4 different sized filters in their tubs through the years.
  • c-4326 4-15/16" x 13-15/16" 25 sq ft
  • c-4950 4-15/16" x 13-15/16" 50 sq ft
  • c-4995 4-15/16" x 23-5/8" 95 sq ft
  • c-5397 5-5/16" x 17-13/16" 80 sq ft
you will need to measure the inside height and diameter of housing and see which one will fit best.
Jan 30, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Torque specs for the cylinder head
2004 ENGINE
Engine Mechanical - 1.6L (L91) - Aveo
SPECIFICATIONS
FASTENER TIGHTENING SPECIFICATIONS
Fastener Tightening Specifications
Application
Specification
Metric English
A/C Compressor Mounting Bolts 27 N.m 20 lb ft
A/C Compressor Mounting Bracket Bolts 50 N.m 37 lb ft
Air Filter Housing Bolts 12 N.m 106 lb in
Alternator Adjusting Bolt 20 N.m 15 lb ft
Alternator Adjusting Bracket Retaining Bolt 20 N.m 15 lb ft
Auxiliary Catalytic Converter-to-Exhaust Manifold
Nuts and Bracket Bolts
40 N.m 30 lb ft
Camshaft Cap Bolts 16 N.m 12 lb ft
Camshaft Gear Bolt 67.5 N.m 49 lb ft
Camshaft Pressure Plate Bolts 10 N.m 89 lb in
Connecting Rod Bearing Cap Bolts 25 N.m+30°+15° 18 lb ft+30°+15°
Coolant Pump Retaining Bolts 10 N.m 89 lb in
Coolant Temperature Sensor 20 N.m 15 lb ft
Crankshaft Bearing Cap Bolts 50 N.m+45°+15° 37 lb ft+45°+15°
Crankshaft Position Sensor Retaining Bolt 10 N.m 89 lb in
Crankshaft Pulley Bolt 95 N.m+30°+15° 70 lb ft+30°+15°
Cylinder Head Bolts - Camshaft Support Housing
and Cylinder Head Mounting Bolts
25 N.m+60°+60°
+60°+15°
18 lb ft+60°+60°
+60°+10°
Electronic Ignition System Ignition Coil Mounting
Bolts
10 N.m 89 lb in
Engine Mount Bracket Retaining Bolt 65 N.m 48 lb ft
Engine Mount Bracket-to-Engine Mount Retaining
Bolts
60 N.m 44 lb ft
Engine Mount Retaining Nuts 40 N.m 30 lb ft
Exhaust Flexible Pipe Bracket Bolts 40 N.m 30 lb ft
Exhaust Gas Recirculation Valve Adapter Bolts 25 N.m 18 lb ft
Exhaust Manifold Heat Shield Bolts 15 N.m 11 lb ft
Exhaust Manifold Nuts 25 N.m 18 lb ft
Flexible Plate Bolts 60 N.m 44 lb ft
Flexible Plate Inspection Cover Bolts 10 N.m 89 lb in
Flywheel Bolts 35 N.m+30°+15° 26 lb ft+30°+15°
Flywheel Inspection Cover Bolts 12 N.m 106 lb in
Front Muffler-to-Main Catalytic Converter Nuts 30 N.m 22 lb ft
Fuel Rail Retaining Bolts 25 N.m 18 lb ft
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 1 of 330
http://www.eautorepair.net/app/PrintItems.asp?S0=2097152&S1=0&SG=%7BEEDCF... 3/30/2009
ENGINE MECHANICAL SPECIFICATIONS
Engine Mechanical Specifications
Intake Manifold Retaining Nuts 25 N.m 18 lb ft
Intake Manifold Support Bracket Lower Bolt-to-
Engine Block 40 N.m 30 lb ft
Intake Manifold Support Bracket Upper Bolts 25 N.m 18 lb ft
Lower Timing Belt Cover Bolts 10 N.m 89 lb in
Oil Pan Retaining Bolts 10 N.m 89 lb in
Oil Pressure Switch 40 N.m 30 lb ft
Oil Pump Retaining Bolts 10 N.m 89 lb in
Oil Pump/Pickup Tube and Support Bracket Bolts 10 N.m 89 lb in
Oil Pump Safety Relief Valve Bolt 36 N.m 22 lb ft
Oil Pump Rear Cover Bolts 6 N.m 53 lb in
Power Steering Pump Mounting Bolts 25 N.m 18 lb ft
Power Steering Pump Pulley Bolts 25 N.m 18 lb ft
Rear Timing Belt Cover Bolts 10 N.m 89 lb in
Spark Plug Cover Bolts 3 N.m 27 lb in
Spark Plugs 25 N.m 18 lb ft
Thermostat Housing Mounting Bolts 20 N.m 15 lb ft
Throttle Cable Bracket Bolts 8 N.m 71 lb in
Timing Belt Automatic Tensioner Bolt 25 N.m 18 lb ft
Timing Belt Idler Pulley Bolt 40 N.m 30 lb in
Transaxle Bell Housing Bolts 75 N.m 55 lb ft
Transaxle Brace Bolts 40 N.m 30 lb ft
Transaxle Torque Converter Bolts 65 N.m 48 lb ft
Upper Timing Belt Cover Bolts 10 N.m 89 lb in
Valve Cover Bolts 10 N.m 89 lb in
Application
Specification
Metric English
General Data
 Engine Type 4 Cylinder - In-Line
 Displacement 1598 cm3 97.51 in3
 Bore Stroke 79.0x81.5 mm 3.1x3.21 in
 Compression Ratio 9.5:1
 Firing Order 1-3-4-2
 Maximum Power - At 6200 RPM 77 kw/103.3 hp
 Maximum Torque - At 3400 RPM 145 N.m 106.9 lb ft
Cylinder Bore
 Diameter 79 mm 3.1 in
 Out of Round - Maximum 0.0065 mm 0.00025 in
 Taper - Maximum 0.0065 mm 0.00025 in
Piston
MITCHELL 1 ARTICLE - 2004 ENGINE Engine Mechanical - 1.6L (L91) - Aveo Page 2 of 330
Jan 07, 2009 | 2004 Chevrolet Aveo
Samsung Color Fixed Security Camera Sod-14c Logo
206 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
