Question about Fujitsu Plasmavision PDS-4221 42 in. Television
I ahve a fujitsu model pds4222ws and i dont have the power cord i put another one in but it turns on for split second and then turns back off
  • 635 Answers
I doubt if its a power cord problem. Anyway you need a IEC 3 pin power cable. Try it.
Posted on Mar 19, 2011
A four year old Fujitsu split system works fine in all modes except the heat mode. Have turned off the main power source for 45 seconds, no change. Can you help please.
the heating function feeds power to the reversing valve to enable heating the valve coil should be electrically tested, pos opened circuit (burn out )
Sep 02, 2017 | Fujitsu Heating & Cooling
A four year old Fujitsu split system works fine in all modes except the heat mode. Have turned off the main power source for 45 seconds, no change. Can you help please. Model # AST30RBA-W
As stated, sounds like a reversing valve issue, likely need a technician. What exactly happens when in heating? Does it run, still cold, just warm not hot???
Fujitsu aou30clx compressor location detection error
You must turn off of the power for 10 minutes. Then open the front of the indoor unit and push the emergency button for 10 seconds. The compressor will unlocked.
Apr 18, 2013 | Fujitsu 30CLX HALCYON Wall Mounted Mini...
Laptop won't start up
I'm inclined to think that your power cord is bad and you have drained your battery.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Fujitsu Siemens Computers & Internet
I have a Fujitsu Inverter heat and cool model SET-ASTA12LCC - about 14 months old. when you turn it on it gives off a horrible chemical smell. any suggestions as to what it could be?
I ahve an ASTA12LCC model and was on constant for 3 months(21 degrees auto). When I tried to shut it off by remote it would not. I had to power down by control switch outside
I have used the remote on another unit and it transmits fine.
I have tried the other remote and it does not recieve either
May 03, 2011 | Fujitsu 18C1 Air Conditioner
Cannot power on only led light (num lock,scroll lock,cap lock) flashing Model: S6520
Welcome to fixya, This could be a number of issues.
It could be your ram chips need to be replaced, it could be your battery.
Try this to narrow it down.
Remove the power cord, and the battery.
Press and hold the power button for 30 seconds solid.
Then, do not put the battery back in, just the power cord.
Try to start the computer, if it starts, your battery is failing.
If it does not start, leave the battery out, remove the power cord.
Turn the laptop upside down and remove and reinsert the ram chips.
Then, plug the power cord back in and try and start it again.
If it starts, your ram chips may be failing and you should think about replacing them.
KittyTech..
Mar 09, 2011 | Fujitsu LifeBook S6520 Notebook
My lifebook s7010 won't startup. After put the on button the screen still remains black. The fujitsu logo will not appear on the screen.
Unplug the AC adapter from power cord, then remove the battery.Wait 30 min and put the battery back.Plug the AC in power cord and try again.If not start you need check AC adapter with voltmeter.If the AC working your computer need service.
Nov 10, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Fujitsu plasma tv won't turn on
you have a bad power supply. Bring your tv to repair shop.
Jul 28, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Fujitsu Plasmavision PDS-4221 42 in. Television Logo
78 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
