Question about Generac Power Systems Generac 0057500 75 kW 60Hz Model QP75G RV Gasoline Generator
Generator starts and runs for a few minutes and then shuts down.
  • 10,865 Answers
Hi 'Phil. the biggest problem with generators is that they sit with fuel in the carburator for long periods of time. This always gums up the carburator. From the sounds of yours, you can start by adding carb. cleaner to your fuel but in the end you may have to replace or rebuild your carburator. Joe
Thanks for choosing Fixya!
Posted on Mar 19, 2011
2 Suggested Answers
  • 116 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
try to unplug the device and then again plut it after some 5 minites and reset it.
Posted on Oct 09, 2008
I Have a Rural King Generator it starts Fine but only runs a few minutes and it shuts off
Make sure the gas is fresh. Also, take off the carb bowl and look for signs of gumming. If there is gooey stuff in the bowl, then the carb needs to be cleaned.
Oct 21, 2014 | Sigma Powers Inc Rural King 6,500 Watt...
Need wiring diagram,from alternator to plug-ins for briggs & Stratton (3500) Elite series Model # 030208-0
No wiring diagram available from Briggs. Try re-magnetizing the rotor. No AVR or Capacitor listed in the parts list.
Disconnect the wires to brushes ( pay attention to the order) and apply 12vdc to brushes. Positive goes to brush closest to the bearing. Start the generator and check for output. If output is normal run the unit a few minutes to ensure re-magnetization then shut down normally. After shut down disconnect the 12 vdc source and re-install the previous disconnected wires. Now re start the generator and test for output should be okay provide there is no problems with the alternator. If no output during the above re-magnetization then your rotor windings my burned out.
Oct 10, 2014 | Briggs & Stratton Gas Powered 3500-4375...
I have a Champion generator 6000 starting watts modle number 41115 starts and runs for a few minutes then shuts down , has fresh gas and new spark plug.
Is the oil level good, does the low-oil cutoff switch work properly? Try bypassing the aforementioned switch to see if it fixes your woe.
Nov 05, 2013 | Electrical Supplies
Coleman power ate 5000 generator, will start very easy, run for 1-2 minutes then shut down, what could be the problem?
Check oil level, and viscosity is correct 30W etc
Then check oil presure switch and wiring
Aug 28, 2012 | Coleman Electrical Supplies
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
My powermate 5000 with subaru engine will run anywhere from 30-60 minutes and shut down. One light pull to the pull start and it runs great for another 30-60 minutes. Never a problem to start it back up...
There is debri or dirt in gas tank and eventually it gets sucked up and clogs the screen filter on the end of gas line. Drain gas tank and flush out a few times. let dry and put new gas in it. check your gas can, if it is metal, it may have rust in the bottom of it and it goes in the gas tank and clogs screen, make sure you have a clean gas can that you use to fill the generator.
Aug 25, 2011 | Coleman Powermate Subaru 5000W Portable...
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Kohler 11rmy-q53 generator. Generator starts and runs a vew minutes and shutdowns. When dry weather it is ok. When it rains it doesn't run long before shutting down.
The first thing I would do is to clean and dry air filter. If it is a foam material you can use a warm water and a few drops of dish soap.Rinse thoroughly and let dry. I also would try a small amount of octane booster in my gas. Hope this helps you.
Nov 29, 2010 | Kohler Electrical Supplies
Coleman Powermate 10 HP Generator shuts down after a few minutes.
I have an HM100 on a 5500 watt gen with the same problem. This motor calls for a J17 spark plug, but I found using a J19 (hotter) plug solved the problem. I think the J17 doesn't get hot enough for a complete combustion burn so it act like fuel starvation thus resulting in the black sooty and wet plug.
Sep 24, 2009 | Coleman Powermate Premium Plus 6250W...
Generac Power Systems Generac 0057500 75 kW 60Hz Model QP75G RV Gasoline Generator Logo
643 people viewed this question
Top Generac Power Systems Electrical Supplies Experts
John Trevino
richie46
Bill Boyd
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
