Question about Kenwood Car Audio & Video
I bought my 2004 Intrepid used. When my radiator was replaced, the battery was disconnected. I don't know the security code, so now have no music. I tried 5227 and 3901? (sample #) and 1234. Please help. Thank you. Annabelle
    Genius:
  • 1,196 Answers
You will need to get the papers that came with your car, search all the documents that came with the car, the code to reset your car radio is written on one of the documents that came with your car. If you cannot get it, you will need to get the serial number on your radio and contact the dealer for the reset code, because, the dealers have the reset code, but you will need to tender prove of ownership before this can be done.
Posted on Mar 19, 2011
Where do you put antifreeze on 2002dodge intrepid
Terry, Add coolant to the reservoir located under hood, mounted by shock tower and fuse/relay center, fill to the full mark on side of coolant reservoir when cold, recheck after running and engine cold again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Add Coolant Dodge Intrepid 1998 2004 2000 Dodge Intrepid ES 2 7L V6
Auto Repair Replace Engine Coolant Radiator Overflow Bottle Dodge Intrepid...
How to Remove Dodge Intrepid Radiator eHow
Jun 26, 2016 | Cars & Trucks
How to replace water pump 99 2.7
Hope this helps you....
Instructions
  1. Prepare the Dodge Intrepid
    • 1 Lay out a drop cloth underneath the Dodge Intrepid to protect the floor from coolant spills. Designate an area to lay out each part alongside its bolts and connecting hoses and wires. Use a drop cloth here as well, some of the parts will have traces of grease and coolant.
    • 2 Disconnect the negative battery cable, using a screwdriver to unscrew the clamp that secures the cable to the negative (-) post. Pull the cable away from the battery post.
    • 3 Use a jack to elevate the Dodge Intrepid and jack stands to shore up the jack. Release the pressure in the radiator by removing the cap. Take out the drain plug located underneath the radiator. Catch the coolant in a resealable container
    • 4 Use a grease pencil to mark on the timing belt its position in each pulley before removal. This will save time when reinstalling. If needed, replace the timing belt and skip marking the old one.
    Remove the Damaged Pump
    • 5 Locate the water pump on the Dodge Intrepid. It's mounted on the front of the engine block and connected to the radiator and various other parts through a series of hoses. It's rotated by the timing belt. Study these parts, as you'll have to remove them.
    • 6 Disconnect or remove the parts in front of the water pump, using an adjustable wrench. In the most common Dodge Intrepid engine--the 2.7L--you'll find, in order: the upper radiator crossmember, fan module, accessory drive belts, crankshaft damper, timing cover, timing chain and guide wires.
    • 7 Unbolt the water pump from the engine block, using an adjustable wrench. You may have to use a chisel to gently break the seal between the mount and the pump. Discard both the pump and the bolts.
    • 8 Clean off the mounting area with a shop rag.
    Install the New Pump
    • 9 Inspect the new water pump to ensure it's identical to the old pump and free of any metal splinters or debris.
    • 10 Arrange the new water pump on the mount. You won't need sealant for the o-ring on a Dodge Intrepid. Hold the water pump and o-ring in place as you secure it with the new bolts. Tighten them with a torque wrench to 105 inch pounds torque in any order.
    • 11 Install the timing belt and wires, using the grease pencil marks to guide you in installation. Install the rest of the parts in the order removed. The camshaft must be reconnected with a torque wrench at 125 foot pounds torque.
    • 12 Replace the radiator's drain plug and refill the radiator with the amount and type of coolant specified in your owner's manual. Release the jack and jack stands.
    • 13 Attach the negative battery cable to the post and tighten the screw on the clamp. Crank the Dodge Intrepid's engine and check for leaks. Then, close the hood.
Read more: How to Install a Water Pump in a Dodge Intrepid ' eHow.com http://www.ehow.com/how_4508707_install-water-pump-dodge-intrepid.html#ixzz29Q1ZC1uZ
Oct 15, 2012 | 1999 Dodge Intrepid
Removal of alternator on 2000 dodge intrepid 3.2
  • Very easy one hour job for most DIY's
    .Disconnect the negative (black) cable from the battery, then remove the positive (red). Unbolt and remove the upper support rail for the radiator.
  • Loosen the lower mounting bolt and pivot bolt on the alternator, but do not remove it. This relieves tension from the belt. Remove the belt.
  • Disconnect the electrical connectors. The battery line is connected with a nut.
  • Unbolt and remove the alternator. Install the replacement using the reverse procedure. Torque the battery cable nut to 85 in-lbs. (7 ft-lbs.) and the mounting and pivot bolts to 40 ft-lbs.
  • Aug 28, 2012 | 2000 Dodge Intrepid
    2006 dodge intrepid code reads P164
    I THINK it is a transaxle problem.
    The book states the code is for the 1-4 upshift lamp control circuit.
    I don't know what the "lamp" part means. Normally it would mean a bulb such as the light for the shifter or the wipers, etc.
    Jul 03, 2012 | 2004 Dodge Intrepid
    Car bucks and going over 40mph and has the following codes P0016, P0344, P0700, P0841, P1776
    hello, Clear the codes by disconnecting battery for 10 mins then reconnect then re check for codes. Let me know, Lee
    Sep 16, 2010 | 2004 Dodge Intrepid
    Need instructions on how to replace the cooling
    Removal & Installation To Remove:
    1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    2. Remove or disconnect the following:
      • Radiator upper crossmember
      • Fan motor electrical connector
    3. Drain cooling system below the level of the upper radiator hose.
    4. Remove or disconnect the following:
      • Upper radiator hose from radiator
      • Radiator fan fasteners and upper clip
      • Fan assembly by lifting upward to clear radiator
    To Install:
    1. Install or connect the following:
      • Radiator fan assembly
      • Upper clip and fasteners
      • Upper radiator hose to radiator
    2. Fill cooling system.
    Jul 17, 2010 | 2004 Dodge Intrepid
    The thermostat on my 2004 Dodge Intrepid was changed because it was overheating on me..and it is still doing the same thing. What could it be now?
    If the thermostat was changed and you seem to still be overheating - the problem most likely lies within the radiator! Small holes in the radiator can become plugged - either from OLD OLD coolant or the sometimes unfriendly "barsleak" which is used sometimes after an intake gasket replacement and/or most commonly a leaky radiator! Radiator is the only other solution
    Jun 21, 2010 | 2004 Dodge Intrepid
    HOW TO CHANGE WATERPUMP 1999 INTREPID 2.7
    1. Step 1 Lay out a drop cloth underneath the Dodge2_bing.gif Intrepid to protect the floor from coolant spills. Designate an area to lay out each part alongside its bolts and connecting hoses and wires. Use a drop cloth here as well, some of the parts will have traces of grease and coolant.
    2. Step 2 Disconnect the negative battery cable, using a screwdriver to unscrew the clamp that secures the cable to the negative (-) post. Pull the cable away from the battery post.
    3. Step 3 Use a jack to elevate the Dodge Intrepid and jack stands to shore up the jack. Release the pressure in the radiator by removing the cap. Take out the drain plug located underneath the radiator. Catch the coolant in a resealable container
    4. Step 4 Use a grease pencil to mark on the timing belt2_bing.gif its position in each pulley before removal. This will save time when reinstalling. If needed, replace the timing belt and skip marking the old one.
    5. Step 1 Locate the water pump on the Dodge Intrepid. It's mounted on the front of the engine block and connected to the radiator and various other parts through a series of hoses. It's rotated by the timing belt. Study these parts, as you'll have to remove them.
    6. Step 2 Disconnect or remove the parts in front of the water pump, using an adjustable wrench. In the most common Dodge Intrepid engine--the 2.7L--you'll find, in order: the upper radiator crossmember, fan module, accessory drive belts, crankshaft damper, timing cover, timing chain and guide wires.
    7. Step 3 Unbolt the water pump from the engine block, using an adjustable wrench. You may have to use a chisel to gently break the seal between the mount and the pump. Discard both the pump and the bolts.
    8. Step 4 Clean off the mounting area with a shop rag.
    9. Step 1 Inspect the new water pump to ensure it's identical to the old pump and free of any metal splinters or debris.
    10. Step 2 Arrange the new water pump on the mount. You won't need sealant for the o-ring on a Dodge Intrepid. Hold the water pump and o-ring in place as you secure it with the new bolts. Tighten them with a torque wrench to 105 inch pounds torque in any order.
    11. Step 3 Install the timing belt and wires, using the grease pencil marks to guide you in installation. Install the rest of the parts in the order removed. The camshaft must be reconnected with a torque wrench at 125 foot pounds torque.
    12. Step 4 Replace the radiator's drain plug and refill the radiator with the amount and type of coolant specified in your owner's manual. Release the jack and jack stands.
    13. Step 5 Attach the negative battery cable to the post and tighten the screw on the clamp. Crank the Dodge Intrepid's engine and check for leaks. Then, close the hood.
    Apr 04, 2010 | 1999 Dodge Intrepid
    Bought used car. radio does not work. need code.
    for a stock radio you can only get the security code from a Honda dealer.you will need to show proof of ownership and ID then they will usually give you the code with no problems.Good luck.
    Jan 01, 2010 | 2004 Honda Accord
    Is there any way to reset the check engine (obd)light on a 2002 dodge intrepid?
    Two ways: 1. Disconnect the negative battery cable, then try to start - that will reset the light, but also reset the radio, clock, etc. 2. Go to an Autozone store. They will reset it for free and will even tell you the code that caused it.
    Jul 27, 2009 | 2002 Dodge Intrepid
    Car Audio & Video Logo
    Top Kenwood Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
