Question about Sony Handycam DCR-TRV265E Digital Camcorder
I can't seem to view my videos from the camcorder on my PC.
  • 604 Answers
You need to have the proper connections on your PC "firewire" is one and the othere requires that you purchase an adapter (about 50 dollars US) that plugs into the USB port. this converts analog signals to digital which the pc can recognize. Camcorders like the one you have do not use USB directly.
Posted on Mar 19, 2011
Everthing seems to work, except the camera will not record.
Assume you have Sony DCR-HC20 camcorder and it does not show you live view to record, I hope camcorder is playing back old recorded tapes perfectly with good quality picture on its LCD.
If it is true then your camcorder has ccd imager chip failure and ccd imager needs to be replace to get live view in LCD monitor.
Qualified camera tech will replace ccd imager chip.
Thanks.
Oct 01, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
When I try to record, I am told that my Flip camcorder is full. When i try to view the videos existing on the camcorder, I am told the camcorder is empty! I can't record, and I can't view any videos.
Try this.
Connect to your PC.
Go to MY COMPUTER.
Right click on the Flip Video Drive
Select PROPERTIES from the pop up menu.
Press the DISK CLEANUP button
When the Disk Cleanup window appears press OK
Sep 27, 2009 | Flip Video MinoHD 4 GB Camcorder
Problems with LCD and view lens
Is it Sony DCR-TRV460E camcorder or some other model. Seems it is bad CCD Imager problem in your camcorder.
Jun 15, 2009 | Sony Handycam DCR-TRV460E Digital...
Sony camcorder copy tape to pc problem
Hi, You need to connect to PC using a 4 pin firewire cable. and then switch on the cam. Import the video using Windows Movie Maker.
Dec 27, 2008 | JVC Cybercam GR-D200US Mini DV Digital...
Problems viewing Hi8 tapes
Seems video head of your handy-cam is dirty or clogged. Use good quality video head cleaning tape to clean video head.
Oct 21, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Transferring footage to pc
First plug in your USB cord to the comp and you'll see the options play on pc, pc connection, etc. Select CREATE DVD! (You won't be able to see or select any of the files you are going to import, oh well.) You should see the regular screen pop up that says import, create, view pictures. Click IMPORT PICTURES. It will automatically import both pictures and video. For file name write something you can easily locate, ex: AAAAAAAAAAAAAA (you can change it later) Then open MOVIE MAKER. Click on IMPORT on the upper left hand corner and you'll see their demo video listed. Click on picture and video files on the bottom right hand corner and select ALL FILES. You should see what was downloaded!!! YAY!! I haven't burn a DVD yet but the files are there and the program should do it from there!
Sep 28, 2008 | JVC Everio GZ-MG21 Camcorder
Panasonic mini dv camcorder cannot get it to view video on my pc
I solved the problem on my own. On the panasonic.com site I searched and found my mini dv camcorder and then I found the software I would need to make it work on the computer. I found everything I needed and I will not need to join the premium plan you offer, sometimes if we just take time you can find it yourself without paying so much for something are there any sites that just help people instead of wanting your money....
kwazegirl
Jun 13, 2008 | Panasonic PV-GS31 Mini DV Digital...
Pv-L750 camcorder
I have a Panasonic camcorder PV-L750D-K
You will need to purchase Pinnacle Video Transfer.
http://www.pinnaclesys.com/images/redesign/PVT/comp1.html?KeepThis=true&TB_iframe=true&height=400&width=650
It's expensive, but it's the most convenient way to transfer analog video (via a USB flash stick or external hard drive) to view and edit on a PC.
I have used this device with my Panasonic PV-L750D-K Palmcorder (camcorder) with success.
A few things to keep in mind:
a.) The Pinnacle Video Transfer converts the the video into MPEG 4 format - so you will need the Apple QuickTime viewer to view the videos on your PC.
b.) You will need to purchase a USB flash stick, a min of 4GB (I use an 8 GB flash stick), unless you have one already.
c.) Your flash stick should be formatted to FAT 32
d.) You will need the Audio/Video cable that came with your Panasonic camcoder (the supplied A/V cables that come with the Pinnacle Video Transfer are incompatible with the Panasonic camcorder).
e.) You will need to update the Pinnacle Video Transfer with the latest firmware update (available from the Pinnacle Support Site) before you hook everything up.
The rest is a no brainer. Just follow the instructions in the booklet, or view the tutorial videos on the pinnacle web site for more info.
Have fun.
~appaloosa
Jan 01, 2008 | Panasonic PV-L750 Camcorder
No playback on JVC GR-D72
It souunds like the problem is in the Vid-PC connection. I suggest you start by downloading the latest version of whatever software you have used to capture and view.
Also - uninstall any hardware in the PC that is used to capture (just remove from system device list) and then restart the PC and let it detect and re-install.
If you don't know how to do these steps, then you'll need geek help.
Oct 28, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Sony Handycam DCR-TRV265E Digital Camcorder Logo
26 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
