Spare part for twin tub washing marchine i need a new drain hose
    Brigadier General:
  • 6,277 Answers
Sorry but this forum does not supply parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C
Posted on Mar 19, 2011
How to drain water from 5.5kg twin tub
Get a rooter and clean the drainer hose...
Get electricity to the drain pump and make it work , only one control is broken on it , the drain pump is still good... find and replace the faulty switch , probably the one that stops machine when lid is lifted... that switch is 1st to go and so easy to Unscrew Unplug and replace...
Jan 07, 2018 | Washing Machines
Ned a new drainage hosed for a centrex twin tub washing machine. Any help?
yes go to the manufactures website and request the spares department for the part from them eric
Jan 01, 2018 | Washing Machines
How do I fix water not staying in the wash tub of Twin tub, LG WP 750R?
If your drain is not high enough the water will siphon out while filling. Check your owner's manual for correct height, usually about 39 inches from ground
Jun 20, 2014 | LG Washing Machines
GOOD DAY I would like to know if this machine can run without the drain pump motor? Its a LG WP9916PT twin tub washing machine. Or where can i find a new pump?
I doubt that any washer will continue unless the drain motor is able to drain water. Many machines will not even go to spin or release the door lock if there is any water still left inside.
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
May 10, 2011 | LG Washing Machines
Spin dryer on my twin tub washing machine does not drain properly. There is water at the bottom of the tub
I 've got twin tub w/machine service is not spinning and draining, can you pls tell me how to solve the problem?
Thanks
Oct 06, 2010 | Samsung Washing Machines
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
ARE SPARES STILL AVAILABLE FOR TWIN TUB HOTPOINTMODEL NO 9404H NO61191982 IT APPEARS TO BE LEAKING UNDER THE AGITATOR NOT A HOSE PROBLEM
The part you require for your washer is still available.
It is called the wash spigot gearbox tripod bellows seal
If you have trouble getting hold of one, I can get one for you, if you want, they cost around £20.00 or so + p/p.
Jan 09, 2010 | Hotpoint Washing Machines
When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Jul 16, 2009 | Haier XQBM22-C Top Load Washer
Need to drain water in washer as the washer is not draining by itself.. Thanks
Attached a hose or insert a smaller hose to the drain hose on the back, than lower the hose below the level of the washing machine tub. Gravity will drain the tub. Have something to catch the water. If that doesn't work, your pump is plugged up and you will have to take the hose loose between the tub outlet to pump inlet.
Nov 06, 2008 | Washing Machines
Kenmore 44072 Front Load Washer Drain Hose Cleaning
Try this link for step-by-step instructions. More than likely you will have to clean the drain pump as well.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are having trouble draining the water from the wash tub, and cannot get it to drain with a shop vac, you can drain it directly from the tub. If you don't own a shop vac, you may have to bail. If your drain pump does not have a clean out trap, remove the inlet and outlet hoses to access the inside of the drain pump. Inspect the pump impeller for obstructions and/or damage. If the water will not drain when you try to pull a vacuum on the drain line, you may have to disconnect the drain hose from the bottom of the wash tub. In some front loaders, there is a ball valve in the drain hose from the bottom of the wash tub to the drain pump. This ball can act as a collection pint from lint and debris. You will need to remove the hoses from the bottom of the wash tub to clean this area. I would recommend doing this as a LAST resort. Often, it can be difficult to reconnect this hose to the tub and get it to seal correctly. I hope this helps you. Please post back if you need further assistance.
May 28, 2008 | Kenmore 44072 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
