Question about Puzzle Toys
Clue is last in a long series 3&6........... n?h ?e?r?e
Nth degree
Posted on Mar 20, 2011
  • maggiOB Mar 21, 2011
    DOH!!....Yes thank you so much, obviously keithwillis50 and I are doing the same Waikato Times crossword and were stumped with this last clue: cheers!
  • RyanNZ Mar 21, 2011
    The one I was doing was in The Daily News (New Plymouth). I wonder if the entire crossword was the same.
I wabt to know the titles of Inspector morse books in order
Episode # Prod # Air Date Episode Title _____ _______ _________ ___________ ______________________________________________ 1st Series 1987 1. 1- 1 6 Jan 87 The Dead of Jericho 2. 1- 2 13 Jan 87 The Silent World of Nicholas Quinn 3. 1- 3 20 Jan 87 Service of All the Dead 2nd Series 1988 4. 2- 1 25 Dec 87 The Wolvercote Tongue 5. 2- 2 8 Mar 88 Last Seen Wearing 6. 2- 3 15 Mar 88 The Settling of the Sun 7. 2- 4 22 Mar 88 Last Bus to Woodstock 3rd Series 1989 8. 3- 1 4 Jan 89 Ghost in the Machine 9. 3- 2 11 Jan 89 The Last Enemy 10. 3- 3 18 Jan 89 Deceived by Flight 11. 3- 4 25 Jan 89 The Secret of Bay 5B 4th Series 1990 12. 4- 1 3 Jan 90 The Infernal Serpent 13. 4- 2 10 Jan 90 The Sins of the Fathers 14. 4- 3 17 Jan 90 Driven to Distraction 15. 4- 4 24 Jan 90 Masonic Mysteries 5th Series 1991 16. 5- 1 20 Feb 91 Second Time Around 17. 5- 2 27 Feb 91 Fat Chance 18. 5- 3 13 Mar 91 Who Killed Harry Field? 19. 5- 4 20 Mar 91 Greeks Bearing Gifts 20. 5- 5 27 Mar 91 Promised Land, aka Inspector Morse in Australia 6th Series 1992 21. 6- 1 26 Feb 92 Dead on Time 22. 6- 2 11 Mar 92 Happy Families 23. 6- 3 25 Mar 92 The ***** of the Self 24. 6- 4 8 Apr 92 Absolute Conviction 25. 6- 5 15 Apr 92 Cherubim and Seraphim 7th Series 1993 26. 7- 1 6 Jan 93 Deadly Slumber 27. 7- 2 13 Jan 93 The Day of the Devil 28. 7- 3 20 Jan 93 Twilight of the Gods Specials 1995-2000 29. S- 1 29 Nov 95 The Way Through the Woods 30. S- 2 27 Nov 96 The Daughters of Cain 31. S- 3 19 Nov 97 ***** Is Now My Neighbour 32. S- 4 11 Nov 98 The Wench Is Dead 33. S- 5 15 Nov 00 The Remorseful Day
May 07, 2015 | Miscellaneous
I need to know the spark plug wiring order for a 2000 grand prix 3.1
. You're not going to believe this but the firing order is actually 1-2-3-4-5-6. Your particular vehicle uses coilpacks. Cylinders 1 & 4 share the same coil, 2 & 5 also share the same coil. And lastly, 3 & 6 share the third coil. Hope this helps.
Mar 31, 2012 | 2000 Pontiac Grand Prix
How to remove the water pump on a 5 series bmw
Goto pelicanparts dot com for technical writeup with photos. Similar procedure for all 6 cyl BMW 3 & 5 series from 91-03 (M50/M52 engine).
Jun 07, 2010 | 1995 BMW 5 Series
How to run wires is series fof 3 subs
If they are single voice coil speakers (1 positive and 1 negative terminal on each speaker) then connect from amps' Positive output terminal to spkr. 1 positive terminal, THEN spkr. 1 neg. terminal to spkr. 2 positive terminal, THEN spkr. 2 negative terminal to spkr. 3 positive terminal, THEN spkr. 3 negative terminal to amps' negative output terminal.
That is 3 speakers wired in series. if each spkr is 2ohms, then you will have a total 6 ohm load. If 4 ohm spkrs., then a total 12 ohm load, if 8 ohm spkr., then a total 24 ohm load.
Be careful because amps do not like these odd ohm load totals. You might get away with a 6 ohm total load. Depends on the amp.
Mar 27, 2010 | Jl Audio 10W6v2 Car Subwoofer
34122 45200 56300 67428 785630 what is the next line ? explain the pattern
We can solve this problem by taking digit by digit.
First and second digit,both are increased by 1,respectively
34…,45…,56…,67…,78…,89…
Third and fourth are the multiplication of first and second digit
3 x 4 = 12
4 x 5 = 20
5 x 6 = 30
6 x 7 = 42
7 x 8 = 56
8 x 9 = 72
so now the series become
3412.,4520.,5630.,6742.,7856.,8972.
Last digit equivalent multiplying the third and fourth digit:
1 x 2 = 2
2 x 0 = 0
3 x 0 = 0
4 x 2 = 8
5 x 6 = 30
7 x 2 = 14
34122,45200,56300,67428,785630,897214
Mar 05, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
How 2 wire 3 jl audio w6 v2
Hello mikey4569mky,
Unless your amp is stable below 1 ohm, there's really only one wiring solution. And that is to series the voice coils making each sub 8 ohms, then parallel all 3 subs to the amp for a 2.67 ohm load. If you parallel the voice coils and then parallel the subs, the impedance will be 0.67 ohms, much too low for most amps.
You could parallel the voice coils and then series the subs for a 6 ohm load, but the amp won't put as many watts into a 6 ohm load. Most are optimized for 4 ohms or 2 ohms. And it's not good to run subs in series anyway.
Here's the wiring diagram.
Hope this helps.
Sep 13, 2009 | Jl Audio 12W3 Car Subwoofer
Genius graphics pad 1812 series
1. Go to: http://www.geniusnet.com/2. Click on "Service & Support"3. Click on "User's Manual"4. Click on the tab labelled "Tablet"5. Find your tablet model on the page.6. Click on the appropriate language listed opposite to your tablet's model. The download of your tablet's user manual will start.
Dec 19, 2008 | Genius NewSketch 1212HR (K9436401)
Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
May 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
Toys Logo
242 people viewed this question
Top Puzzle Toys Experts
Nikki  Mclean
Nikki Mclean
Gary Nitowski
Ron Baird
Are you a Puzzle Toy Expert? Answer questions, earn points and help others
