Question about Mitsubishi WS-65807 65" Rear Projection Television
I have a Wd-65737 mistubishi dlp and i have sound and no picture. It cuts off also after being on for about 3 minutes with no picture. I have tgried the reset option by holding down the power button and i have unplugged all connections and unplugged tv from surge protector still nothing. This TV is only over 1 1/2 years old .. please help i didnt opt for the warranty option .
  • Mitsubishi Master
  • 1,229 Answers
By now this aging TV has many, many bad solder grounds. The first place to start, is to pull the convergence board out. You will see an STK-393-110 that has rings around the pins. This is bad grounding. Please resolder this, and do not use excess solder or you will short the pins together. Then you should inspect the board for any and all ICs attached to heat sinks and resolder the pins to the board. Look for bad grounds on power resistors, transistors, diodes and capacitors. Also resolder areas where the board meets the other board. These are jumper jack connections. These can be a problem, solder as necessary. The second board to inspect is the power supply. It is the one with the flyback transformer. The first thing to find is the vertical IC. This is usually the reason you have no video. Please resolder the pins of the vertical IC.Do not to use excess solder or you will short the IC. Resolder the flyback transformer,horizontal transformer,power resistors, capacitors, transistors attached to heat sinks etc. Resolder the jumper jack connections that connect the boards etc. I cannot say enough, you must really inspect to find these bad grounds.I do not believe you need to replace any parts now. Just resolder and reinstall. This will take great patience and skill. Thanks for asking and show a few hands of support!
Posted on Mar 19, 2011
I have a mistubishi tv model wd-65737 with bad picture. I replaced the video chip and color wheel but that didn't work....is it possibly that dmd board?..thx
Hi, can you tell me what you see on the screen? It could be a bad cable. Are you using an HDMI cable or the color cables (RCA cables)?
Jul 28, 2016 | Mitsubishi WD65737 65" DLP TV
I have a WD-73642 tv has no picture but has sound
I had this problem with a laptop of mine it's the led just replace the screen
Mar 21, 2016 | Mitsubishi Digital Television Mitsubishi...
What can I do about my Mitsubishi WD-65737 having a dark screen and cutting itself off? We have already replaced the bulb and ballast.
Can you link a picture of the issue? If the picture is bright in some areas and not in others then it could be anything from the lamp lens, light tunnel, or any other mirrors or lenses. If the picture cuts off sharply, it may be something else. A ballast wouldn't cause that but a lamp could. Make sure the bulb is an Osram brand or Philips. Any knocks offs are not to be trusted regardless of how good they say it is. Without a picture or video of the problem, its hard to determine where the problem lies.
Jun 05, 2015 | Mitsubishi WD-65737 65"" rear projection...
Why does my Mitsubishi WD-65737 TV go black for 4 or 5 seconds then picture comes on again with the top left corner says "Cable Box".
Replace service cords, as they might be getting worn and loose. It does sound like that to me. Bad coaxial cables
Apr 10, 2015 | Mitsubishi WD-65737 65"" rear projection...
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
230 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
