Question about Nintendo Wii Console
Wii fit board
I have had this board for a few months and had no problem at all. Went to turn it on the other day and the blue light just flashed for a few seconds then went off. Changed the batteries, still the same, pressed the home button and did a check, seems fine on there, tried to synch the board with the console again, still no joy, the board itself just wont switch on, any ideas welcome!!!!
  • 2 more comments
  • kiascott Aug 06, 2008
    I turn my Wii board on and the blue light flashes for a few seconds then it turns off. The board just wont turn on. I have tried new battereis and unplugging the whole machine, but still nothing. Any ideas welcome.
  • woodles Sep 27, 2008
    I have exactly the same problem - the light flashes but does not sync with the wii - as a result cant use it HELP PLEASE
  • Merry Johnson
    Merry Johnson Oct 24, 2008
    I have the same problem. Board only about 2 months old and blue light will not stay lit. Tried changing batteries, syncing, unplugging all, with no luck. What is the problem??????
  • Anonymous Oct 25, 2008
    I have the same problem. When turning Wii board on the light flashes a fwe times then goes off. Have replaced batteries and still nothing works. Has anyone got theirs working again or will I have to replace the Wii Board?
  • 28 Answers
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
147
Posted on Mar 22, 2009
  • 32 Answers
This is really very frustrating when you face such kind of problems. You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Posted on Mar 04, 2009
    Problem Solver:
  • 5 Answers
Have you unplugged everything...let the Wii "get a break" and after a few minutes tried setting it up again? I haven't had that problem yet with my board but try it...no harm....good luck!
Posted on Aug 02, 2008
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
Wii board
Make sure that you have synced the board to the wii (similar to a controller). You have to take the battery cover off the board and push the sync button. The blue light will start flashing. From there you need to open the front cover of your wii under the power button.
From there you start up wii fit and it will prompt you to turn on your board. You should get a solid blue light. If you don't, you may need to try syncing again.
Jan 04, 2010 | Nintendo Wii Fit for Wii
Board power flashes then turns off
i have put in new batteries in my wii board and the lights turn off please help
Jan 02, 2010 | Nintendo Wii Fit - Balance Board + Game...
Board won't turn on
This seems to be something that I can't understand. My best suggestion is to ensure that your product is registered and contact Nintendo via their website's customer service link.
Feb 20, 2009 | Nintendo Wii Fit for Wii
Canot use Wii fit balance board
Ensure batteries are fresh. Ensure that Wii Fit (or other Balance Board game) is started up completely before pressing the power button.
Jan 04, 2009 | Nintendo Wii Fit for Wii
You need to sync the balance board with the console. Instructions are in the manual. Sync button for board is in battery compartment and sync button for console is in panel under reset button.
Took a few tries for me, be carefule not to hold sync button on console down for longer than 10 seconds because it will deregister all wii remotes.
Sep 09, 2008 | Nintendo Wii Console
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
236 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
