Question about Maytag Washing Machines
WHAT DOES INT CODE MESSAGE MEAN ON MY MAYTAG WASHER
2 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
Posted on May 21, 2012
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
My maytag bravos washer is flashing DL, what does this mean, its not spinning!
The "dL" error code appears when an item inside the washer prevents the lid from locking properly. Open the washer and readjust any items that may be hitting the lid. The error code should go away once you properly close the lid
May 03, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does a 3E error code mean? i have a maytag
Trouble shooting guild for this machine indicates this means Motor Failure. Over current is detected
Feb 08, 2010 | Maytag MAH8700A Front Load Washer
Washing Machines Logo
349 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
