Question about Texas Instruments TI-30XA Calculator
Dms to decimal degrees
How to enter is the questions
  • 43 Answers
Page 7 of user guide, aval here:
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=18#27
Posted on Dec 31, 2008
3 Suggested Answers
supportthe85
  • 35 Answers
SOURCE: Degrees, minutes, seconds converted to decimal degrees
No DMS button
1degree 22.25 minutes
2nd Math F3 1 F1 22 f3 15 f3 enter
Posted on Nov 25, 2008
  • 7993 Answers
SOURCE: if a textbook problem is given in DMS notation,
On this family of calculators, you do as follows
Enter the first number (degrees), ex:15
Press [2nd][APPS] (ANGLE) to access the Angle functions
Select [1: degree symbol] [ENTER]
Main screen shows 15 deg
Enter the minutes, ex 25
Press [2nd] [APPS](ANGLE) to access Angle functions
Select [2:' apostrophe] [ENTER]
Screen echoes 15 deg 25'
Enter the seconds number, ex 32
Press [2nd][+] (") to access the double quotation mark
Screen echoes 15 deg 25' 32"
Press [ENTER]
Calculator converts this in decimal degrees 15.42555556
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
Posted on Jan 06, 2010
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
I can't figure out how to use the degree, minutes, and seconds button to get to a decimal number.
Enter the number of degrees, press DMS, enter the number of minutes, press DMS, enter the number of seconds, press DMS. Press S--D. If you get a fraction, press S--D again.
DMS is the degrees-minutes-seconds button located above the ENG button, S--D is the symbolic--decimal button located above the DEL button.
Feb 01, 2011 | Casio FX-115MS Plus Calculator
How do I convert DMS to DD with a ti84 plus?
To enter an angle in DMS format, enter the number of degrees, 2ND [ANGLE] 1 to indicate degrees, enter the number of minutes, 2ND [ANGLE] 2 to indicate minutes, enter the number of seconds, ALPHA ["], then ENTER.
ANGLE is on the APPS key, " is on the + key.
You can convert an angle from decimal to DMS with the ->DMS command, 2ND [ANGLE] 4
Jan 10, 2011 | Office Equipment & Supplies
How to switch from the decimal degree to degrees, minutes, seconds
Keys 1. I displays the following menu that lets you change the angle mode setting to DEG, RAD, and GRD without affecting the value in the display. DEG Sets degree mode. RAD Sets radian mode. GRD Sets gradient mode. The default setting is DEG. 2. = displays a menu that lets you specify the unit of an angle. º Specifies degrees. å Specifies minutes. æ Specifies seconds. r Specifies radians. g Specifies gradients. DMS Lets you convert an angle from decimal degrees to DMS notation. Notes · The examples on the transparency masters assume all default settings. · Angles with a trig function ignore the angle mode setting and display results in the original unit. Otherwise, angles (without a trig function) are converted and displayed according to the angle mode setting. · You enter decimal-degree angles the same as you would any other number. · For decimal/DMS conversions, the calculator interprets all values as degrees, regardless of the angle-unit setting. · DMS angles are entered as º (degrees), ´ (minutes), and ´´ (seconds You watched 2 videos that were 2:05 (2 hours and 5 minutes) and 1:46 (1 hour and 46 minutes) in length. How long did you watch videos? = Press Display 2 = ¡ å æ r g & - DEG < 2¡ DEG 5 =" ¡ å æ r g & - DEG <T 1 = < 2¡ 5å + 1¡ DEG 46=" << 2¡ 5å + 1¡ 46å ' 3.85 DEG =! % ¾DMS ---- DEG << Ans ¾ DMS ' 3¡ 51å 0æ DEG Degrees, Minutes, and Seconds to Decimal © 1999 TEXAS INSTRUMENTS INCORPORATED TI-30X ùS: A Guide for Teachers 96 How much is 2/3 of an hour in hours, minutes, and seconds? = Press Display 2 N 3 2®3 DEG =! % ¾DMS ---- DEG << 2®3 ¾ DMS ' 0¡ 40å 0æ DEG
Aug 19, 2010 | Texas Instruments TI-30 XIIS Calculator
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
Time problems
Sorry to say it but the DMS key is to convert between Degrees, minutes, seconds and decimal degrees (angle units). This cleared here is how to use the DMS key on this calculator.
Label of key [deg symbol ' "]. It is between [(-)] and [hyp]
To enter a value in decimal degrees
12.58 [deg ' "] [=] Screen displays 12.58 deg on top line and 12 deg 34' 48" on bottom line.
Pressing the [deg ' "] key while this value is displayed will show 12.58
To enter a DMS value:
Press the [deg ' "] key after each number even if one of the numbers D,M,S is nill (0).
Exemple Enter 25 deg 0 ' 48"
25 [deg ' "] 0 [deg ' "] 48 [deg ' "] [=]
Screen displays 25 deg 0' 48" on bottom line
Pressing the [deg ' "] key converts this result to decimal degrees 25.013
Jan 14, 2010 | Casio FX-115ES Scientific Calculator
If a textbook problem is given in DMS notation, how do I enter the DMS notation into the TI84 to get decimal degrees?
Press [ENTER]
Jan 06, 2010 | Texas Instruments TI-85 Calculator
Convert degrees and minutes to decimal degrees
In the main menu screen press the Action menu, then Transformation submenu. At the bottom of the drop down list you have dms an toDMS.
If you enter toDMS(18.58) you get dms(18,34,48). Then if you use dms( on the calculated result: dms(ans) you get 18.58
So if you have a result in deg, min, sec you convert it to decimal degrees by making use of the dms( command.
Hope it helps.
Jul 13, 2009 | Casio ClassPad 300 Calculator
No DMS button
Sep 05, 2008 | Texas Instruments TI-85 Calculator
Texas Instruments TI-30XA Calculator Logo
259 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
