Question about Vacuums
Select cooking mode than press start nothing happens
    Master:
  • 403 Answers
Are you really going to serve food from your vacuum ? type in your real problem, and be specific.
Posted on Mar 19, 2011
Why won't my Roomba start when I press a green "clean" button?
Bad PC board. Throw it away. Robot vacs are nothing more than novelties ( expensive toys ) They may do what you want them to do at first but they never last very long and other than brush replacements they are not repairable. If it is within the warranty period you can get a replacement with that.
Jul 01, 2017 | Roomba iRobot 630 Vacuum Cleaning Robot
Changing the language on roomba pet series
You need to post a model numbers before I can help you.
Now, a three second search of the roomba help section on the roomba website turned up this:
All Roomba 700 Series and select 500/600 Series can provide troubleshooting messages in either English, French, German, Spanish, Italian, Dutch, Danish, Swedish, Norwegian, Finnish, Polish, Russian, Portuguese, Japanese, Korean, or Chinese.
Roomba's default language is English.
700 Series: Instructions for Setting the Language
  1. Turn ON your Roomba by pressing CLEAN.
  2. Press and hold DOCK until it beeps and says the current language.
  3. Release DOCK. Roomba is now in Language Selection Mode.
  4. Now press CLEAN repeatedly until you hear the language you want.
  5. Press and hold CLEAN to turn off your Roomba and confirm language choice.
500/600 Series: Instructions for Setting the Language
  1. Turn OFF Roomba. (Press and hold CLEAN until Roomba's lights turn off.)
  2. Press and hold CLEAN until Roomba beeps and says the currently selected language.
  3. Release CLEAN. Roomba is now in Language Selection Mode.
  4. Press CLEAN repeatedly until you hear the desired language.
  5. Press and hold CLEAN to turn OFF Roomba and confirm the language choice.
Jan 25, 2014 | iRobot Roomba 550 Vacuum
My slow cooker doesn't heat enough. My recipes say to cook on low... but after 10 hours the vegetables are not cooked. Is there a problem with this model? Thanks
Most slow cookers have several settings ... maybe yours is one ... I suggest you select a higher setting.
Thanks for visiting today.
Jan 28, 2011 | Vacuums
I have a Uni-com wireless doorbell, model 55075/SC352R. I would like instructions as I'm not finding it easy to reset things and have inadvertantly set the alarm and don't know how to turn it off!
With the display in normal mode showing the time, date and temperature and with the double dots flashing each second, press the MODE button. The first press will give you the option for setting 12 or 24 hours on the time display. The second press should bring up the setting for the alarm time. Press the SET button once and it flashes the hour for the alarm. Press it again and the minutes for the alarm will show. Pressing the SET button a third time lets you set the number for each musical tone choices for the alarm. A fourth press will ' set' the alarm so the alarm time will show, plus the number representing the ring tone you selected below the alarm time. Normally what you would do next is press MODE again 3 times to return to the ordinary time display. But if you want the alarm off, instead of doing this, press SET a fifth time and this will set the alarm time to 'off' and the display for the alarm will show '-:--' now press MODE 3 times or until you see the ordinary time display with the double dots flashing. You can check the alarm is off by pressing the ALARM button - it should still show '-:--'. The ALARM button is only for showing the alarm time which has been set, not for actually doing the setting. A quicker way, starting from the normal display with the seconds flashing on the time, is to just press the ALARM button once, then press SET 5 times then MODE 3 times.
Aug 27, 2010 | Vacuums
4210 Starts for a second and then stops
This will be one of, or both of, the following.
Bad battery will not take a charge and cause this condition.
NOW... Why will it not take a charge. either the battery is bad, and CAN'T take the charge the machine is giving. OR the charging circuit is fired on the main board. Sometimes a bad charging circuit will also cook your battery causing both to be screwed.
But it is a common problem with the board going bad. Some people purchase an external charger for the battery and then swap it into the roomba when charged. But this kinda defeats the automated controls. The fried charging circuit also will drain the battery when it isn't turned on. I have repaired a number of charging circuits on these units
Jul 05, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Windows xp boots but the desktop will not come on
well there is a couple of thing you could try 1) power on your computer press F8 rapidly and select "last known good configuration" 2) power on your computer press F8 rapidly and select safe mode login with your account and press yes to restore you computer to an earlier time select a date tah the computer worked ok and click on restore
try it and please if you have any problem please comment
Apr 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Won't start
It is most likely your cord winder. They are a little tricky to fix yourself. A repair shop will probably charge about $50. To fix it. The contacts where the cord winder plugs into the motor need to be cleaned and adjusted. Just don't let your repairman tell you that you need a new cord winder.
Jan 22, 2009 | Vacuums
Simplicity vacuum
Could be a bad cord or a switch problem. Could also be a problem with the motor. Will have to checked to find the right problem.
Oct 27, 2007 | Vacuums
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
