Question about Haier HLP21E Top Load Washer
My Haier HLP21E washer makes a loud grinding and clicking sound when it is in the wash cycle and rinse cycle, regardless of which water level I have selected. It is quiet on the spin cycle though. I opened the back panel yesterday when it was on the wash cycle and noted that the bottom bracket was touching the bottom panel and making the noise. I got a wooden block and put it under the middle of the washer and it worked to reduce the noise. However, my solution with the wooden block doesn't work today. What can be causing the problem?
    Top Expert:
  • Haier Master
  • 81,400 Answers
The washer tub bearing is defective.
Posted on May 05, 2017
SOURCE: Spin cycles doesn't work, tub full of water
Did you install the bottom plate yourself? They are tricky and the instructions are a bit unclear - you want the bump side out so that bump goes towards the floor. If you install it with the bump going up toward the dryer, it gets all buggered up. Hope that helps!
Posted on Dec 06, 2008
  • 4 Answers
SOURCE: Haier HLP21E 6.6-Lb How do I remove lint filter?
You grab the plastic top and bottom of the filter and kind of pinch it so it pops out.  It's held in by small pegs on both ends.
Posted on Jan 22, 2009
SOURCE: Can't find Haier lint filter for HLP21E
http://www.repairclinic.com/SSPartDetail.aspx?s=b198i1226155&PartID=1226155
My washer did not come with the Lint Filter. I contacted Haier Customer Service and sent them all the info they requested such as copy of receipt and etc. That was several weeks ago and Haier still says that they have yet to receive that letter. Or they say that due to high volume of warranty letters they receive, they have yet to process it. Anyways, I got fed up with the customer service or lack of, I started surfing the web for the lint filter and found the above site. The filter is very inexpensive and I got it in several days.
Posted on May 06, 2009
cmcurrie2
SOURCE: Haier HLP21E 6.6-Lb: How do I remove the lint
Grasp the top of the plastic filter frame with your thumb on top and first finger below, push down gently as you tip the frame out toward the middle of the bin -- the frame will flex slightly, and pop out.
Returning, make sure the you have 'up' up and 'down' down, seat the plastic pin on the bottom into its cradle, and push the top of the filter frame toward the bin wall. It will pop in.
After you do it a few times, it will become much easier. The frame seems to be fairly sturdy, I was a bit worried I would break it initially -- but it has lasted several years and many, many removals.
Posted on Dec 08, 2009
Testimonial: "Clear instructions. Thank you."
muffteck
  • 202 Answers
SOURCE: Haier HLP21E belt broke. My machine was
put new belt on big pulley first then roll in over on smaller one
Posted on Mar 29, 2010
I have an haier washing machine that gets stuck at the rinse cycle. What could it be? Plus it makes loud grinding noise.
are u saying its putting water in the draining over an over? or not rinsing at all? if no water coming in check water inlet valve. if its draining over and over>? check ur drainage and water pump
Jun 15, 2015 | Haier Washing Machines
Why will Haier HLP21E drain following wash cycle, but not drain following rinse cycle/before spin cycle?
Hello Michael;
My name is Peter. I am a retired field service appliance technician.
It sounds like your system just needs a good cleaning. Soap film will build up on the draining system components. You need to clean your float and insure it moves freely and makes contact with the float switch which turns on the pump. You may also need to disassemble your pump for cleaning.
There are products available for cleaning clothes washers, but these need to be used on a regular bases. I do not think they can clean enough to solve your current problem. Use after you have cleaned.
Dec 03, 2014 | Haier HLP21E Top Load Washer
Why doesn't Washer drain water in spin cycle.
If it drains OK during wash and rinse cycles, then the controller is not turning the pump on for some reason.
Aug 05, 2014 | Haier HLP21E Top Load Washer
Washer tub does not move to spin or wash
You either have a bad solenoid, timer, loose belt, or water level sensor.
Dec 15, 2013 | Haier HLP21E Top Load Washer
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
Haier model HLP21E. The wash cycle doesn't seem to do anything but the rinse cycle and spin cycle work well.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Click this link: Inlet valve
Jun 25, 2012 | Haier HLP21E Top Load Washer
HLP21E Haier Portable washing machine will not spin and drain water
Jul 08, 2008 | Haier HLP21E Top Load Washer
My friend has this washing machine and has to turn the water off and on
Need more info not sure i understand but sounds like a pressure switch or water valve problem
Aug 25, 2007 | Haier HLP21E Top Load Washer
Haier HLP21E Top Load Washer Logo
367 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
