Question about Samsung Galaxy S GTI9000 Smartphone
Why everytime i take a picture it rotates to one side no matter the orietation
  • 118 Answers
Maybe it's set to that really. Somethings are meant to be like that.
Posted on Mar 19, 2011
What does portrait orientation lock mean?
If you lock the orientation, your screen will not turn when you turn your phone. If its unlocked, the screen will turn when you turn your phone. Some apps will not allow the orientation to change no matter how you have it set.
Feb 24, 2015 | Apple iPhone 5
I need a diagram for the timing belt on my castel garden 20/122
pauly46_0.gifpauly46_1.gif hi there winger1886
pauly46 here
with 20/122 the blade timming must with one blade vertical and one blade horizontal
doesnt matter which one but as long as there is 90 degrees between blade as the rotate
in the picture the r/h blade rotates anticlockwise and the l/h blade rotates clockwise
the picture for belt / blade timming is straight forward - loosen tensioner rod and back it off completely , loosen 2 x bolts under the two toothed pulleys and remove the 2 belt guide/ stoppers from the l/h side - place both blades in the rqd position ( you may need someone to hold other blade in rqd position - fit the belt onto pulleys as in the diagram- continually check while fitting that timming has not moved from where you placed them ( they have to be 90 degrees from each other ) and then tighten the tensioner rod to hold position - rotate by hand recheck timming - if good loosly fit guide the 2 guide stoppers to l/h side and place 3.5 kg of tension at the middle point of the longest run of timmed belt ( belt should only deflect 10 mm with 3.5 kg of tension )
once tensioned tighten the 2 bolts under the toothed pulleys and tighten loc nut on adjuster
tighten the 2 stopper / guide nuts
in the picture the left hand blade is a l/h thread undo it right and tighten it left
the blade on the right is a normal thread left loose - righty -tighty
cheers hope it helps
May 23, 2011 | Garden
When I rotate pics I don't have the option to rotAte 45 degrees, it rotates 90
Correct. The camera lets you put the picture on its right side, on its left side, upside-down, or right-side up. It will NOT let you tilt the picture on a diagonal.
Dec 20, 2010 | Fuji FinePix F10 Digital Camera
I was taking lots of scenery pictures this weekend and usually turn my camera on its side to get longer/narrower shots. Well, I decided to take a video and turned that on its side. When I dropped the...
Well, if nothing else, you've learned a valuable lesson. Always shoot videos horizontally. There are some expensive editing programs that can rotate the video but with severe loss of quality.
Sep 27, 2010 | Sony Cyber-Shot DSC-W1 Digital Camera
I have asus built in webcam, and it's called LifeFrame. Everytime I take pictures and try to move it to my "picture folder" I can never find my pictures. How do I find them? Or how can I get them back?
im having the exact same problem.
i right clicked the photo when on lifeframe, it gave me the option to save in my picture which i did, and now they arent in that folder, or anywhere else on my system for that matter.
Sep 11, 2010 | Computers & Internet
Blurry Picture
Hi there the camera lend guide pin is damaged so dislocked. Lend not focusing properly. So i suggest you service the lens guide pin & then your problem will solve. Thanks.
Mar 17, 2010 | Cameras
I cant send pictures because "Memory Full" shows up
Maybe the phone memory is full, please delete files on the recycle bin. or connect the phone to the pc and run disk cleaner or empty the recycled bin.
else you have to consult the vendor about your phone.
melnavz
Nov 28, 2008 | Samsung SCH-U470 Juke Cellular Phone
My camera is blurry every time i open up a video chat
Try adjusting the camera lens by rotating it from Left to Right. Hope this helps. Bud
Nov 23, 2008 | Logitech QuickCam Express Web Camera
My Olympus P400 Printer comes out with streak on the left side
If a hard reset of printer electronics does not restore proper operation there may be an inherent defect in the unit causing this.
Sep 05, 2017 | Office Equipment & Supplies
Macromedia Flash
I am wrting in regards to my Sony Handycam DCR-HC36. I am having problems with the Picture Package software when I try to load my video. When I try to transfer my videos (from my Handycam) to my Pesonal Computer, the picture package(software) menu does not appear on my PC(The picture package software is already installed).
Everytime I try to click on the Picture Package Icon on my desktop, there is a pop-up that says I "must install Macromedia Flash Player for Application to continue".
I went ahead and installed the Adobe (Macromedia) Flash Player and it still doesn't work when I try to click on the Picture Package Icon. The pop-up still comes up. I also, re-installed some of the requirements for the for the camera to work such as Direct X and Windows Media Player.
I also enabled my Javascript(active Script).
The problem is most likely within my PC(maybe I'm missing another type of software???), what do you think are my options in resolving this matter?
Please help me out
Anindya
Apr 20, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Samsung Galaxy S GTI9000 Smartphone Logo
18 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
