Question about Logitech X-230 Computer Speakers
I bought this unit over 1 year ago, lately tried playing music but no sound came out of the unit, although power is on. No elctronic shop nearby to get assistance.
  • Logitech Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 19, 2011
I have a sony ta-fe370 amplifier. I bought it 5 years ago. 4 years ago it stopped working. I would now like to repair it. The problem is that it turns on and the power light comes on and so does the...
The problem is hard to track down, but fixable. You need to determine if the pre-amp has failed or the power amp. To determine which try this: Connect a device which plays music and turn the volume control fully up! You can sometimes hear the sound better via a pair of headphones. If you can hear any signal or music breaking through, then the pre-amp section is OK. If you can't it might not be. If you can hear faint music then it will be the main power amp to blame. Now because you have lost both channels you must only investigate devices (such as IC's) which have both channels running to them. Some amps have one big power amp IC that does the work. So if that goes it takes the sound with it. Have a look at whatever is on the big heat sink first, that will determine a lot of your future actions.
Jul 06, 2011 | Sony TA-FE370 2-Channel Amplifier
I have a 2.1 altec lansing speaker system i got 3 years ago. a couple of moths ago they started humming. the humming is now so loud i have to turn the power off when i go to sleep (i can even hear the hum...
If there is a router or you leave your phone near the speakers that is what is most likely causing the problem. Check to see if anything that gives off a wireless signal (eg. microwaves, cell phones, cordless phones) are nearby, and try to see if moving one of those things fixes your problem.
Feb 28, 2011 | Altec Lansing VS2421 2.1 Speakers
Hi Bought a Russel Hobbs Microwave about 10 months ago, the turn table just simply stopped turning ? It must be the mechanism...........Is there any troubleshooting tips.....Please assist ? Lindie
Sounds like the turntable motor has packed up, you would need to fit a new motor, although I would advise return to shop since you will have 1 year warranty...
Feb 24, 2011 | Microwave Ovens
A year ago I bought a Stanton C.324 and now I have a big problem: The player suddenly stops and repeats short segments on currently track. I realized that the ANTI SHOCK AN BUFFER INICATOR is empty and The...
Dust and dirt could cause this by getting in the gear rack that moves the read head.
Make sure no one has smoked cigarettes around this as that is devastating to the optics in the unit.
An internal cleaning is probably in order and there are very fragile elements within the unit. I would recommend taking it to a shop specializing in CD repairs unless you are really capable.
I assume you have verified that the power is good to the unit.
Feb 01, 2010 | Stanton C314 Tabletop CD and Mp3 Player
Ps2 doesnt play any game
try this. hope this helps :p
go here and go to the very end
www.powerfulguides.com/ps2
Jul 09, 2009 | Sony PlayStation 2 (PS2) Console
Pionner cd-iu200v plays video from Iphone, no picture on avh4100
Check the initial settings menu (you will probably have to reset the system to get it to reappear) and set the aux 1 to IPOD. This will let the ipod video play via the aux 1 just like it is supposed to. This solution is buried in the manual but is really hard to pull together.
May 11, 2009 | Pioneer AVH-5700DVD DVD AV HEADUNIT...
Humming sound
I think it's time for you to upgrade to a new system. If not, try to see if you can get someone that's great with fixing electronics to repair it or return it to the manufacturer for a replacement.
May 15, 2017 | Bose Lifestyle 12 System
Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
May 09, 2008 | Audio Players & Recorders
No Sound
Maybe the speakers have gone and you should try replace tem you need to ask your friend if he has had any other problams with the speakers...
Jan 21, 2008 | Sony PlayStation Portable (PSP) Console
Sing along cd wont play
These are funny little things.
Sometimes the door fails, so make sure it's fully & properly closed. It will not play CD-RWs (rewritable discs) & might not play CD-Rs either so make sure:
1. The batteries are fresh (high power alkaline), or better still, you are connected to the mains.
2. You are using a pre-recorded (shop bought CD)
3. Your unit isn't being moved or rocked. Although this looks like a "portable unit" it does not have any anti-shock or bufferring so moving the device around while trying to play a CD won't give great results.
Let me know how you get on.
Jan 04, 2008 | Audio Players & Recorders
Logitech X-230 Computer Speakers Logo
29 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
