Question about Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag MDE5500AY dryer and it was in the middle of drying with 10 min to finish when it shut off and now wont turn back on. Does anyone have an idea what has happened? Thanks, Matt
    President:
  • 3,074 Answers
Disconnect the vent hose run the dryer, as it sounds from what you described as a restricted vent tube. Tim
Posted on Mar 19, 2011
How do I fix my maytag dryer
sounds like its hung in a loop unplug wait a few min. plug back in
Dec 14, 2015 | Maytag Neptune MDE5500AY Electric Dryer
My dryer is not very hot when I turn on. Also, it take more than 2 hours dryer, and it is not dry. Please let's me know.
check the vent, make sure the vent is clear. If the vent is clear and unit is still taking long to dry, let me know ad we go to step 2. But 8 times out of 10 its the vent.
Mar 17, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The senser for Moisture only reads less go's through shuts down in about 5 min.
may have a clogged vent or dirty sensor, first disconnect vent tube run dry, if it works normal then clean vent tube, if not clean sensor which is located underneath lint trap. Good Luck Tim
Mar 06, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I start time dry for 60 mins. It will run for
The heater element is not heating, they are fragile easy to get to at the back of the dryer. Check the thermal or overheat switch too, but would bet its the heater element.
Nov 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer MDE 6700AZW Stops working
try a simple test before you try to gain axcess to the console parts unplug the power cord 1 min plug back in and put in time dry not auto or it will time out quickly without wet cloths see how it does and if this not solve you problem repost with model #
Aug 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag intellidry dryer and when finished with drying, clothes or whatever are still damp
Check the ventilation for lint. You may need to replace the duct vents if you have any. The lint tends to build up and prevent the dryer igniter from staying on thus the clothes do not dry all the way.
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
All electronic working but dryer will not turn on to dry
if you think you here the motor come on real lightly you have probly broken a belt the motor is turning but not turn the drum because the belt is broken
May 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Wont start up.
Sounds like the motor is failing. The main cause of failure is overheating due to clooged venting. Is the dryer taking more than 60 mins to dry?? If so then the vent is clogged. Its likely too that the motor is covered with lint and not being able to properly dissipate its own heat, you could clean it and see if it helps but usually once they are shutting down overheated (the burning smell is the motors' internal windings being very hot) they need replacement.
Nov 19, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
