Question about Astar LTV-2701 27 in. HD-Ready LCD Television
Only getting a blue screen
Can you tell me how to set this tv for air vs cable. we don't seem to be able to figure that out so all we get is a blue screen and it does not change channels. We got it used so we don't have the user manual and can't find one online
Your remote should have a menu button, four arrow buttons, and a enter button. I you press the menu button it should give you a screen with a number of images across the top. The left and right buttons should move you to different areas. There should be one option that gives you the TV move. Use up and down to select the line which allows you to change from cable to broadcast.
Posted on Feb 10, 2009
Removed TV from cable,connected a antenna.Changed setting to antenna.All I get is a Blue screen like no signal is coming through.Connections are good. It seems like a setting is missing. Help
Hi, is the tv set to analogue broadcast, should it not be set to digital. I have a Grundig that does the same thing on analogue.If your tv is and/digi this might be the issue.
Jun 16, 2015 | Apex Digital Apex At2002 Color Tvs
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Mitsibishi 50707
Replace vertical output IC and check capacitors in vertical
power supply....requires chassis pull and above average skill....
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Troubleshooting for maxent mx-42hpt51
hello!
Blue screen(bright blue) indicates an absence of signal. If you have "on screen" display characters: menu, channel ##, volume bar, etc, your set might be configured for digital antenna settings, or DTV, "air" mode. Then, you won't be able to get cable channels through. If your "blue screen" is dim and there is no any characters, then your Y-sustain module is bad. Especially, if you have encountered loud "pop" shortly before "blue screen" appeared. Then, it's a major repair with board(s?) replacement. If you can handle that, get back to me in a next session. I will guide yourself "how to".
Thanks,
Alex.
Feb 16, 2012 | Maxent MX-42HPT51 42 in. Plasma TV
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Blue screen help!
The TV is fine. You need to fined the original remote. Be sure you have a cable connection on the anttenna A RF connector. Push menu and find the input. Or maybe input menu...experiment and you will find and correct this. Seen this problem years ago, can't remember exactly what the remote reads. But it should not be serious.
Dec 24, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Red and Blue convergence
you may need a new convergence board only a tv shop can tell you for sure
Nov 03, 2008 | Televison & Video
Help me
Go tu SET UP menu and change de option of SCREEN SAVER to off position and try again
Mar 18, 2008 | Mitsubishi VS-50705 50" Rear Projection...
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
53 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
