Question about Singer 14SH654
The hand wheel & the overlock machine 14SH654 cannot move
  • Singer Master
  • 1,133 Answers
So nothing is moving at all either by pressing the pedal or turning the hand wheel? Can you hear the engine humming or is the light working okay?
If yes, then this could be a gear failure inside the machine and not something easily fixed. Is this a oldish machine that has either had a lot of work or been sitting for a while? Has it been serviced at all in the past?
My Bernina 334D failed and it was a nylon gear in the main drive area which I had replaced but the dealer wasn't keen to do it, they wanted to sell me a new one. However, I checked with Bernina themselves that the part was available and how much, then talked to a local repair guy and he did the job for me. About 1/3 the cost of a new one though.
I'd suggest you take it to a Singer dealer and ask for a quote and find out if this is what has happened to your machine.
Posted on Apr 10, 2011
Brother 3034d overlocker, handwheel is very stiff. I have oiled it and nothing happened. How do I fix it please?
If it is a mechanical machine, you can perform more oiling than recommended in the manual. I remove the base of my Bernina overlocker and oil the other moving joints. Even applying heat from a hairdryer may help. Below is the process I use for sewing machines, but it would work on a serger too:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwinkayZg5TYAhVbImMKHd5GCG8QFggpMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2FSupport-manuals%2FHobbylock-_787_788-manual-EN.PDF&
Dec 17, 2017 | Brother Sewing Machines
How do I make my looper move again
Do you oil it regularly? Is it clogged with lint, dirt, and thread?
Feb 24, 2016 | Sewing Machines
The wheel on my Singer overlock is hard to turn and its making a lot of noise.
when a machine starts making noise then the machine needs to be check to see why
May 21, 2012 | Singer 14SH654
I am doing some sashes for a wedding and i want to know on my serger 14SH654 ultralock how to do a rolled hem
A rolled hem on any overlocker is formed by using the right hand needle only, and the two loopers to form a narrow three thread seam. You also need to retract the seam width finger as Trial2962 said. This is a little finger that sits on the stitching plate and the loopers form the stitching over it. By retracting it, the looper threads can form a narrow seam and in fact, roll the fabric inside the seam. You need to move the cutting blade as far right as it will go so you are trimming as wide as possible from the needle, turn the tension on the top looper rigth down to 2 so it is very loose and this thread wraps around to the underside. And tighten the lower looper tension to about 7 so it hardly shows and sits right up against the needle thread. Adjust and test until you get the seam looking like this, then turn the stitch length dial (on the right side by flywheel) down to 0.5 to close the seam right up tight. Lastly, if you can source it in the right colour, buy woolly overlock thread and run this through the upper looper only, this thread is fluffy and when not under tension, relaxes and "fills" out so the seam appears like a continuous coverage over the fabric.
You will need to practice a few runs and go slowly on corners, a curve is obviously much easier to serge than a right hand cover so if you can, cut the fabric with curved ends, much easier to get a great finish. When you chain off at the end, you need to unravel the tail threads and pull them inside the seam for a few mm with a needle to get a smooth finish, then trim the tail and seal with a drop of Fray Stop.9_26_2011_11_26_51_pm.jpg
Sep 04, 2011 | Singer 14SH654
Where can i get a manual on this overlocker
Go to this page
http://www.singerco.com/accessories/instruction-manuals/search
type in 14SH654 and click "search" to bring up the instruction manual list, you can down load a pdf file for free.
Jul 21, 2011 | Singer 14SH654
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
I have a Singer 14SH654 (overlock) and broke the foot piece that is attached to the shaft. I can't find a diagram to identify the part number so I can order a replacement.
Call Singer at 1-800-4singer and they can advise you. They have a website at www.singerco.com and you can download your manual manual for free, kind of nice to have a back up on your computer, plus have the luxury of enlarging the diagrams.Another tip, go to www.sewingpartsonline.com and you can see what your part should cost approximately, plus identify what your part is called. Good luck
Jan 07, 2011 | Singer 14SH654
The LOWER LOOPER of my SINGER OVERLOCKER 14SH654 is damaged, and I would like to know WHERE [preferably online] I can purchase a replacement part, as soon as possible. I would be grateful for a reply.
Why not call Singer at 1-800-4singer and order one. That way you know that you will get the right part, plus if you have any questions they can help you. Good luck
Dec 21, 2010 | Singer 14SH654
How do I sew a hem with the singer overlock machine. I just want to hem a t-shirt.
You need to look in your manual and see how to turn your cutter off . It's different for each type of machine.
Nov 05, 2009 | Singer 14SH654
Singer Overlocker 14u134
You can order a new manual on the Singer website:
http://www.singerco.com/accessories/manuals.html
Dec 31, 2007 | Singer 14SH654
Singer 14SH654 Logo
82 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
