Can it be done without a switch - Computers & Internet
  • Pat Koger
    Pat Koger Mar 19, 2011
    Part of my question got lost.
    I wish to connect 2 CPUs to one monitor,
    and want to know if there are other
    ways to do that.
  • 43 Answers
What can?
Posted on Mar 19, 2011
How can I stop the high beam lights from coming on without me turning them on?
Without knowing your make and model of vehicle, I will give you a basic answer. Most cars and trucks these days the high beams are activated via a switch on the steering column that you either push or pull. Most likely this switch is malfunctioning and needs to be replaced. Usually called a multifunction switch. To do this yourself usually requires taking apart your steering wheel to some degree to remove and replace. Depending on your vehicle type and brand to have this fixed can be moderate to expensive to have done for you.
Apr 01, 2017 | Cars & Trucks
The buzzer wont stop when the cycle is done, it runs with the door open, and runs without pushing the start button.
"Tested start switch and it appears to be working normally". You need to be absolutely sure if the start switch is working and isn't sticking, which it sounds like. Isolate the start switch completely and then check it again with your DVOM. Make sure the switch moves easily without sticking.
Dec 08, 2014 | Whirlpool Dryers
How to release fuel pressure without gauge
Locate the inertial safety switch (usually in the trunk, check your Owner's Manual) and disconnect the electrical plug connector from it. Once you have disconnected the plug from the inertial safety switch, attempt to start the car. It may run momentarily, then will stall out and not restart. When this happens, pressure has been released from your fuel system.
After you are done with whatever you are doing and want to re-pressurize the system, replace the plug in the inertial safety switch, turn the key switch to ON (not START), count to five, then return the switch to OFF, count five, then do the same thing again two more times. After you have cycled the ignition switch three times, the car should start with no problem
Apr 09, 2014 | 1998 Oldsmobile Intrigue
Air blower switch
the blower switch only works on high, what can be done without installing a blower
Aug 07, 2011 | 2003 Kia Spectra
Where is the turnsingle flasher located on 2004
Technically --you dont have a flasher.....The 4 way button on the dash is a combination turn/ hazard flasher control "MODULE"...
This is a common problem with these switches. I have replaced several of them over the last few months. The switch can be replaced without all of the disassembly that is recommended. I have done it. There is a screw holding the switch into the dash behind the bezels, but it is possible that it can be done without spending hours on it. The Grand Am/Prix cars were all the same, just a slightly different design.
Hope this helps.
Apr 28, 2010 | 2004 Chevrolet Malibu
Buzzer will not shut off when load is done
If your dryer also starts without pressing the start switch, then the push to start switch
contacts are stuck in the closed position. Sometimes you can press the button on-off-on-off
quickly to unjam the contacts, otherwise replace switch.
Jan 12, 2009 | Maytag Dryers
Lost keys & need to remove ignition switch
it is kind a hard some drilling must to be done but try to call and shop arrownd for a lock smith guy sometimes they will do a copy for a fair price without taking the ignition out
May 25, 2008 | 1987 Ford Ranger
How to fit the power switch
you have to (obviously) open it up and solder in a new one. I've done it, but it's not trivial. I have lots of experience soldering and it went well, but I would not anticipate that someone without lots of time spent with a soldering iron will be able to do it without burning or lifting traces off the circuit board. The switch is available from many places. I bought mine here: http://www.powergamingparts.com/nintendo-ds-and-nds-lite-on--off-power-switch.html
Apr 04, 2008 | Nintendo DS Console
Nokia 3100
with out switch , can i on my 3100 mobile
Nov 20, 2007 | Nokia 3100
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
