Question about KWorld TV BOX KWORLD|KW-SA220 1080I RTL TV Input
Screen display is only on the center. how can i view it in full scren?
  • 52 Answers
Adjust it from your monitor
Posted on Mar 19, 2011
  • KWorld Master
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
LN46B610A5FXZA Gray Horizontal across full Screen with color vertical lines in lt corner and center of screen
Sounds like a panel defect. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 26, 2012 | Samsung LN46B650 46/49.5 in. LCD HDTV
Ipod gen 2 touch scren 16gb stuck on screen with
you should put your iPod to DFU mode and restore it..
use this web address for the instruction on how to do that: http://www.fixya.com/support/r4083816-put_iphone_dfu_mode_restore_3_1_2
Feb 10, 2010 | Apple iPod touch
My camera turns on however the screen is black it takes pictures i just have to point and shoot but i cannot see on the screen exactly what i am taking. I then have to go onto my computer and put them on...
if your screen does not display any figures , numbers or icons then the LCD screen is dead. If you look closely at the LCD scren and fine cracks or lines on it then i advise ou to take it to arepair shop for replacement.
rgds
Luwangula
Sep 12, 2009 | Nikon Coolpix S50 Digital Camera
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Vivitar 7100 damaged lcd scren
Yes. You can get them (to fit yourself) from the manufacture or you can simply take it in to an outlet (like curries etc) or a repair center and they will fix it or have it sent away.
However, it may be cheaper to buy a new camera than to have the screen fixed. You can also get an older broken 7100 with a working screen and remove it and replace your broken one...tho if you are not up to doing that I would take it to a repair center.
Sep 05, 2008 | Vivitar ViviCam 5100 Digital Camera
Nokia N95
you can do it simply you
if you save photos from your pc
you go to your photos where you save in the folder
the open a folder open the pic or walpaper
the go to eddit
here you can slect the option set clip for scren saver
and you can edditet the walpaper
if you need more help pleze contect me at
basharatazad@gmail.com
Jan 11, 2008 | Nokia N95 Cellular Phone
Cracked screen
send it for service to samsung. try to do this:
-go to samsungcamerausa.com
-click on customer service
on the upper right portion of website
-provide product code and e-mail address
-provide all other necessary information
in registration process
-take note of service center address
-read all shipping reminders
-send camera to service center address provided
they will be the one to replace the scren for your camera and if your camera is unrepairable, they will be sending you a new camera for replacemnt, but that is if your camera is still under their warranty. had tried that option and my camera is now working perfectly fine.
Oct 14, 2007 | Samsung Digimax S500 Digital Camera
Part of web site cut off
there are some sites that cannot have there web page resized, and sometimes it appears that some of the page is missing because the sit was suitable to be viewed in a highr scren resolution, try changing the screen resolution of your pc to a higher one than 800 x 600, something like 1024 x 768 and you should see all the page.
Sep 02, 2007 | E-Machines T3990 (RBT3990) PC Desktop
KWorld TV BOX KWORLD|KW-SA220 1080I RTL TV Input Logo
78 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Alun Cox
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
