Question about Apple iPod touch
Ipod touch freezes on startup!
Plz help my ipod touch keeps freezing on the start-up menu. It just come up with a little circle and that is it ive tried everything restoring it: doesn't work, reseting it:doesn't work, letting the battery go down then turning on: STILL DOESN'T WORK!!! PLEASE HELP!
if any1 could tell me a solution i would be so grateful!
thnx
alex
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
I) Hold “Power” button for 2 seconds
ii)Then while holding the Power button, you will now have to hold Home button too for 10 seconds.
iii)Then release Power button but keep holding Home button for about 30 seconds
it should take you to Restore mode .. now connect yo
Posted on Sep 02, 2009
  • Rajagopal Venkatesh
    Rajagopal Venkatesh Sep 02, 2009
    i) Hold “Power” button for 2 seconds
    It will take you to restore mode , now restore with your Firmware file from itunes
Have u gotten a solution yet from anyone?
Posted on Oct 05, 2009
Ipod 4th gen freezes even on the restart screen.
Describe your How to reset apple ipod Model- A1285 model Security lock Number Reset Problem
Jan 12, 2010 | Apple iPod nano
My ipod is locked and i cant restore it
go on your itunes , and plug in your ipod , then your ipod will come up , so then clikc on it then it will say update and restore , click on restore and btw wen ur ipod comes back on take it out because it freezes if you dont :D xx
Hope ive helped , Love you tonesss :Dxx
Oct 04, 2009 | Apple iPod touch
Keeps freezing on me, especially when I forward to
Your best bet would be to do a soft reset of the ipod:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If this does not work then you may have to re-format the ipod in itunes. If you click on the ipod in itunes you should see a RESTORE option on the main page.
Jun 24, 2009 | Apple iPod Photo MP3 Player
My ipod touch keeps freezing
restart it by holding down power and home button
Jan 07, 2009 | Apple iPod touch
Ipod nano
my ipod is dubleket ipod drives is is missed plz
Jul 07, 2008 | Apple iPod nano
Ipod nano keeps freezing
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
www.apple.com/support/ipod/five_rs/
let me know if you need more assistance.
Apr 24, 2008 | Apple iPod 4th Generation MP3 Player
Ipod Touch Freezes
What You have to do is hold the top button and the power button at same time for more than 25 second this will lead to recovery mode, on recovery mode you connect to your pc and then restore it , if is taking longer to get into recovery mode plug it in the power adapter and then put in recovery mode. once you have it restore it.
This happen to me, it got stuck on the apple screen and it was restarting on and off and i could connect it because it recognize it when it turn on and few a second later it turn off.
so just put it in recovery mode first and then restore it.
Feb 28, 2008 | Apple iPod touch
Ipod not turning on/not recharging
Have you tried holding down the menu button and the middle circle button?
first place your ipos somewhere flat and press down the circle button and the menu button,make sure your not touching any other part of the click wheel.hold them down for about 5 seconds untill the apple logo appears.then let go,and it should be back to normal.you can use this procedure any time that it freezes or stops working.Hope fully that should fix your problem.if not i suggest you get it repaired under your warrenty.
Good Luck.
Regards.
Sophie
Feb 13, 2008 | Apple iPod nano 3rd Generation
My mini ipod freezing, showing charger sign i could not turn it to menu
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 14, 2007 | Apple iPod mini M9160LL/A MP3 Player
Apple iPod touch Logo
2,239 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
