Question about RCA F27650 27" TV
We replaced the transformer for our RCA F27650. It was sparking and now it is not, but now the screen won't turn on. It is just black. We hookd all the wires up like they were. we can hear sound, but no picture. Can you help?
    Top Expert:
  • RCA Master
  • 75,311 Answers
Hello
Along with the flyback transofrmer, its horizontal output transistor also must be replaced. I don't know whether you have replaced it or not. If not, replace it too. It can be located very near to the flyback transformer, a three terminal component, black in colour, usually screwed to a metal heatsink. Then switch on the TV and measure the video output voltage at the video output card pluged directly to the picture tube neck. The collector of the video aoutput transistors must come around 145VDC. If it also is there, advance the screen control on the flyback transformer to get a raster. If that voltage is not there, it means that the flyback transformer is not working, and horizontal oscillator stage should be checked for oscillation, check the lined drive transformer for its primary winding open, Check the entire horizontal oscillator section. The collector point of the line drive transistor, the transistor that drives the line drive transformer, a small transformer soldered diretly to the printed circuit board; should be checked with frequency meter. The frequency at that point should come around 15525HZ approx: OK.
Posted on Mar 19, 2011
Where is the flybac located in a rca hd52w59
Hello
Flyback transformer other wise called Line output transformer {LOT} is actually a step up transformer, which supplies extra high tension voltages to the guns. It can be locatee on the main printed circuit board. 2_7_2012_5_19_59_pm.jpgJust see the different views of the main board of your RCA TV. You can see the flyback transformer at the left top corner, look like a large black componen; with a ferrite "U" type core goes though it. It is the LOT. Line Output Transformer, otheriwse called as Flyback Transofrmer. OK.
Feb 07, 2012 | RCA Televison & Video
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
RCA F27650 32" TV Problem
Hello ddw7321,
This sounds like it could be a malfunction in the High Voltage section of the TV. The shutdown circuit is switching on and preventing the TV from turning on. This might be due to an excessive amount of current flow possibly caused by a shorted turn in the Integrated High Voltage Transformer (IHVT), or a shorted Horizontal Output Transistor (HOT). To test this you will have to unplug the TV set, and with a multimeter set to resistance, measure the resistance from the collector of the HOT to ground, If it reads 0 ohms then that is the problem (a shorted HOT). The next test which is of the IHVT is a little difficult because it requires removing the IHVT and doing a ring test. At this point I would like to suggest that you take the TV to a repair shop, because these next test might be difficult for someone who does not know electronics, and if you have no knowledge of electronics you may do more damage then good.
With that being said:
Remove the HV anode of the IHVT connected to the CRT by first using a large flathead screwdriver connected with a clip lead to the ground of the TV, by sliding the screwdriver under the rubber cap and releasing the clips. Then unsolder the pins on the bottom of the IHVT using a soldering iron and a suction type desoldering pump. when the solder is removed , pull the IHVT from the circuit board. locating the main primary winding connect it to the device that you are using to perform your ring test (I use a Sencore LC-102), when it is connected do the ring test and it should have at least 10 rings to be considered good, any less then 10 and the IHVT is to be considered as bad.
I hope this helps.
Thank you,
Shuttle83
Oct 04, 2008 | RCA F27650 27" TV
Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
RCA RT2360 System won t Turn on what to do
its probably the transformer in the unit has blown out
you will need to try and find a replacement
Oct 25, 2007 | RCA RT2360 System
Tv turns black and white
No, the tube is not bad. There are a couple of very small surface mount components mounted by the main microprocessor that could be causing what you are seeing. They are very small and quite hard to unsolder and replace without losing them. The set should be serviced by a qualified tech familiar with the new RCA chassis.
Aug 21, 2007 | RCA F27650 27" TV
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
Rca f27650 27"tv w/vport
The hdmi port is for high definition multimedia interface. You should be able to send standard video through the Vport to your set. (RCA phono jack and plug) Stargazer
Apr 21, 2007 | RCA F27650 27" TV
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
TV won't turn on
Is a good thing you have an indication of power,it means some volts supplies are working ,your set might have a shorted output transistor and he is the responsible for lighting up the picture tube and energize a transformer that also provides voltage supplies,if the transistor is bad it has likely open the safety resistor that gives him the power to operate.If you are familiar with tv service you can check this part to start but if you are not too familar with tv service be safe and call for the assistance of a servicer.
Oct 09, 2006 | RCA F27650 27" TV
Open Questions:
Letterboxing: The top and bottom of the screen are cut off I originally obtained this TV from my Bro who passed away from cancer at age 31 a few years ago & I was never able to find out what he did with the manual. However, I was able to find a manual online but after viewing it, I still wasn't able to find the info. that I am trying to obtain for the correct settings to get rid of these black margins at the top & bottom of the screen. I am trying to find out what video output format is supported by this TV model, as far as the resolution and output format, specifically for a Cisco or AKA Scientific Atlanta 500GB HD-DVR through Cox cable? My available settings with Cox cable & the DVR I have( Cisco or Scientific Atlanta 500GB model)are the following-Resolution:480i, with output format of either:Zoom 16:9 Pic or Letterbox 16:9 Resolution:480p standard, with output format of either:Zoom 16:9 Pic. or Letterbox 16:9 Resolution:480wide, with either output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic Resolution:720p wide, with output format of:Stretch 4:3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic and finally, resolution:1080i wide with output format of:Stretch 4.3 Pic, Preserve 4:3 Pic or Sidebar 4:3 Pic? Everything worked fine with the screen size when I had a 160GB Motorola HD-DVR with Cox under the video output settings of:resolution:480i and video output of:Zoom 16:9 Pic until, I grew tired of constantly running out of space & had them switch me to a 500GB HD-DVR. They were supposed to install another Motorola HD-DVR but just with 500GB version but when the Cox maintenance employee showed up to swap them out and install the 500GD HD-DVR, he only had a Cisco/Scientific Atlanta 500GB available on his truck, which is I guess what they use for the Contour service but he attached a filter to the back of the coxial cable to make it a regular HD-DVR without Contour(even though they tried charging me extra for contour for 3 months before I finally got that straightened out since the maintenance workers & billing dept. are often not on the same page as I found out at Cox. I have tried calling Cox for support & they say that I need to find out & know my TV's video output settings. I explained to them that it worked perfectly fine just weeks ago with 480i resolution and output format of Zoom 16.9 Pic before they switched to the Cisco/Scientific Atlanta HD-DVR from the Motorola DVR and that I didn't have the manual and I stated why and they basically said, too bad, figure it out yourself. Can someone please help me out? I have the TV set up for the correct zip code, cable box-Yes, the cable box output channel-video 1/Aux (since that is what the TV manual I read online said to use if you are using the 3-color coded cables instead of the coxial cables to plug in from the TV to the HD-DVR) & I have the Cable box remote control code set to code 008 (Scientific Atlanta) that I verified to be correct by checking it through the TV's automated code search. The serial # for the TV is:C306B2084 and the Chassis # is:ATC113BB1 and its the 27" RCA Entertainment Series Guide Plus Gold Gemstar that is X-Box ready. Thanks so much, Todd
Feb 26, 2017 | RCA F27650 27" TV
RCA F27650 27" TV Logo
138 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
