Question about Sharp UX-B800H Fax
UX-B800SE Fax My Fax MAchine is flashine MEMORY FULL. I need to clear memory without printing pages since I use it direct to my desk top. Please help! Thank you! the memory is full, how can I delete all without printing it?
  • rosewater144 Nov 14, 2008
    i have the same problem with the uxa460
I had the same "Full Memory" problem & called Sharp. You need to unplug the fax, then hold (press down) on both the "Start/Memory" & the "Stop" buttons at the same time. While holding them down, plug the fax back in. After it's plugged in, you may need to press the start button again. That should clear it.
Posted on Jun 05, 2009
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
How can i calibrate print head of pagewriter trim 1
It would help if you stated the manif. example. Phillips, HP, hewlett Packard. ect.
You should be able to find service information on the bottom of unit.
May 08, 2014 | Office Equipment & Supplies
Prinnter not printing but showing 'put custom in manual tray'
There is still a print job in the queue. Place a sheet so it prints or kill the job.
Open Printers and Faxes. Open printer. Highlight jobs and Right click > Cancel, or Documents > Cancel.
For those stubborn jobs, Right click My Computer > Manage. Choose Services and Applications > Services > Print Spooler. Right click and stop. Then start. This may have to be done from the Print Server if it's network printer. Contact IT to kill.
Nov 09, 2012 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Sharp UX-B800H Fax Logo
762 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
