C3200 error IN FS 1118 MFP problem FREE SOLUTION
4 Suggested Answers
n25an
  • 622 Answers
SOURCE: HOW CAN I RESOLVE ERROR c6000 in fs 1118
This might take some doing reseting the fs 1118 but it can be done if the fuser only got hit by a powersurge or overheated due to paperjam by the fuser...
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
press enter
enter 163 and then restart the copier...
sometimes you wont even be able to get to the service mode...
open the front of the copier and then execute the steps... the front meaning the area where you the toner is located...
trying keeping it open and do the steps...
if that fails then open it take out the toner drum cartridge and then put it back in...
then do the steps...
if it still doesn't take try it a couple more times...
if it still doesn't take.. buy a new fuser...
but it should take... it just takes a little experimentation...
Posted on Dec 10, 2009
  • 66 Answers
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
  • 167 Answers
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Posted on Dec 13, 2011
KYOCERA FS 1118 MFP SHOW ERROR CODE C6000 WHAT B I CAN DO
replace the fuser will fix that. Or if you want to stip it down check the lamps and if their ok change the thermistor and thermostat. But your better off just replacing the whole unit
May 04, 2014 | Kyocera FS-1118 Printer
Error c3200
It means the exposure lamp is not turned on. Either a connector has come loose or the exposure lamp and/or the inverter pwb and/or the control pwb must be replaced
Feb 07, 2014 | Kyocera FS-1118 Printer
Fs-1118 mfp printer error code c3200 for solustion
UNLOCK THE SCANNER LOCK SWITCH ON THE PRINTER WORKING.
Mar 17, 2012 | Kyocera FS-1118MFP Laser Printer
C6020
my copier kyocera fs-1118 mfp display error code C6020 please help me the solution.
Mar 10, 2012 | Kyocera Copystar CS-1820 Black and White...
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Error code c6400 on fs-1118 mfp
fuser temperature over /under u need service engineer to reset it
Oct 26, 2010 | Kyocera Copystar CS-1820 Black and White...
Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
Jan 23, 2009 | Kyocera FS-1118 Printer
I have a FS-1118 MFP Kyocera printer it has refused to print and the error message is that the waste toner is full how can i empty the waste toner?
Jan 21, 2009 | Kyocera FS-1118MFP Laser Printer
60 people viewed this question
k24674
jasbo
jasbo
