Question about Magellan GPS
When I turn on my Magellan RoadMate 1430 a white screen opens up and the screen reads, " No NK Image Resident in Flash " also say's " Please insert a valid SD card ". That is all it does. nothing else. Oh yea. in the bottom right hand cornner it reades, "E Boot ver 01.03.00.691 ".
  • 3 Answers
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Posted on Jan 26, 2008
montecarlo
  • 50 Answers
SOURCE: Unit will not boot past Magellan splash screen
try to press the reset button on the left side next to the usb port with a small paper clip or toothpick and see what happens and see if it did is firmware update,if not do it over and the unit plugged in with powersupply and the usb and leave it alone and let it reset a few times until it says to unplug from the usb .for the sd card make sure is a flash sd card.i have a mastreo 4000 with a 2gb sd flashcard and it has no problem.theses units has unlimited amount of any size of gb sd flash card.let me know what happens.
Posted on Mar 02, 2008
SOURCE: Magellan Roadmate 360 reset
I called Magellan and they told me that the previous destinations hold only 20 addresses and the new ones will override the old ones. I have more then 20 previous destinations and it just keeps adding new ones to the list.
Posted on Sep 20, 2008
SOURCE: magellan roadmate 3000t not working properly...
map file will not boot. push the RESET button with the bent end of a paperclip located on the right side of the unit next to the power supply input.
Posted on Oct 18, 2008
SOURCE: magellan roadmate 1412
Try the reset button on the side above the plug in.
Posted on Jan 30, 2009
Change my magellan roadmate from canada to usa
This model does not have map coverage of Canada. This model was designed for us only in the US. The models in that series with Canada maps were the RoadMate 1212, 1412, and 1430.
Oct 12, 2014 | Magellan Roadmate 1200 Car GPS Receiver
Ask maggie
check their web site please, search for your model #
or download Magellan content manager to your computer & it will let you know as well
May 07, 2014 | Magellan RoadMate 1430 GPS Receiver
Cracked screennot working
That is unfortunate. You will have to replace it. You can probably get a new screen on eBay for a lot less than a new GPS. If you can not replace it yourself, ask around, you may have a friend who likes to replace screens in phones and it is about the same amount of work.
Sep 28, 2012 | Magellan RoadMate 1430 GPS Receiver
The power won't come back on
there is a fuse in the tip of the plug that goes into the socket. unscrew the end of the plug to gain access to the fuse.
Mar 31, 2010 | Magellan RoadMate 1430 GPS Receiver
Can you download an update for a magellan roadmate 1430?
Yes you can: Enter your info here http://www.magellangps.com/support/
English Manual: http://docs.google.com/viewer?url=http%3A%2F%2Fwww.magellangps.com%2Fassets%2Fmanuals%2Froadmate_1430_manual_en.pdf
Magellan® RoadMate® 1430 Software Update Version 3.12: http://www.magellangps.com/support/chooser.asp?prodid=2056&supportid=806
2009 Spring Map Update: http://www.magellangps.com/products/map.asp?tab=0&PRODID=2194
As for connecting it to the computer, you'll need the usb cable that came with it. Then you'll want to do this:
Follow these steps to connect your Magellan RoadMate to your PC.
  1. Turn ON your Magellan RoadMate.
  2. Touch "Map" to display the map screen.
  3. Connect your GPS to your PC using the USB cable.
Oct 19, 2009 | GPS
My computer not reading device1430 magellan
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
Aug 09, 2009 | Magellan RoadMate 1430 GPS Receiver
Magellan roadmate 1430 no sat signal
replace the or recharge the battery to capacity and see if that helps usually low battery, incorrecty baud rate or port out cause no satellite connection, unless you are under a thick concrete or tin roof. take it outside and show it some sky and see if that help
Jul 23, 2009 | GPS
Magellan roadmate 1430 calibration is wrong
try a hard reset again using a paper clip, insert it in the little pin hole on the side to reset the unit. if that fails, get the 3.12 update (if you havent already) off the magellan site..you must register the unit with magellan before you can download the update.
Jul 02, 2009 | Magellan RoadMate 1430 GPS Receiver
Roadmate 800 has a white screen with no image
i opened the unit up, removed the covers and disconnected the ribbon that goes from the main board to the lcd screen, cleaned it and then reinstalled it. i then put the unit back together and it has been working fine for about 2 months. let me know if it works for you too!! good luck. dave
Jul 02, 2008 | Magellan RoadMate 800 GPS Receiver
MRM 700 won't start; screen flashes white . . . help.
stonelinton, It's not your LCD, otherwise you would have heard the sound of buttons being pushed. If your units first screen is white and there is no logo screen or any legible images, then it's your NAND flash on your main board. The first image produced upon boot is the blue magellan screen. This is produced from the NAND flash and will show it no matter if a hard drive is present or not. After the Magellan screen it pulls images from the hard drive. So, it is the mainboard and the only way to fix it is to send it to Magellan repair and they will have to put in a new mainboard then reprogram your serial number, etc.
Jun 07, 2007 | Magellan RoadMate 700 GPS Receiver
GPS Logo
75 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
