Question about Creative Labs ZEN V Plus MP3 Player
Hi, I plugged my Creative Zen into the charger and then it just died. It is completely dead. It won't turn on. I even tried to turn it on using the reset button. I have only had it for a month. I am so sad because I love it. I hope you can help me find a way to get it to start up. Thanks Wendy Hanson
  • 1,555 Answers
Can you kindly let me know what was the ratings of the charger which you used your phone is made to be charged with 5V DC and 1.5Amps. In case you used a 12V DC adapter then most probably you could have just damaged the charging circuit. and your phone went to self secured mode. My suggestion at present is to remove the battery for a minimum of 15 minutes from the phone alongwith sim and then try to charge it with a proper adapter for a minimum of 8 hrs before trying to switch on the phone.
Thankyou for using fixya free utility.
Posted on Mar 19, 2011
  • hanson_wendy Mar 19, 2011
    It isn't a phone. It is a Creative Zen MP3 Player. Can I find a way to remove the battery from it?
  • Aruna Singh
    Aruna Singh Mar 19, 2011
    sorry for the bother but you should have let me know the info about the adapter. Anyways, here is what your repair manual says.
    Press and hold the "Power" button located on the left side of the Creative Zen Touch until the LCD screen turns on. Pressing and releasing the button quickly will not turn on the player.
    Move the "Lock" switch located on the top of the Creative Zen Touch to the left to unlock the player. All of the buttons are disabled when the lock is in place.
    Charge the battery by connecting the small end of the power adapter into the power adapter connector on the MP3 player and plugging the larger end of the power adapter into an electrical outlet. You can also charge the Creative Zen Touch by plugging the USB cord into the USB port on the MP3 player and connecting it to a USB port on your computer. The onscreen battery indicator will show when the battery is fully charged.
    Push the "Reset" button, located on the left side of the player by inserting a paperclip into the small hole. Turn on the MP3 player as normal after removing the paperclip.
My creative zen is completely dead it doesn't power on at all also it doesn't charge there is no power what so ever please help me Zen Stone Plus won't turn on. I've downloaded upgrades and Creative Media...
please use a different cable to charge the unit
if it does not help then it is a serious internal fault and you will have to take it back to the creative for further repair.
Jul 30, 2008 | Creative Labs Zen Stone Plus MP3 Player
Dead Creative Zen M
Check first the battery... it could be there.
Mar 23, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen v plus has died and i can't get it to reboot. It doesn't respond to any buttons and the computer doesn't register it when hooked up. What should i do?
Hi
this is hardware issues maybe you have shorted capacitor or defective crystal oscillation, this unit needs to diagnose to find the problem..
Thanks!
Jul 08, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Jun 10, 2009 | Creative Labs Zen Stone Plus MP3 Player
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
Zen wont work on battery
The battery is bad or the charging circuit is flaking out. Try plugging it in and from the wall side of the charger, unplug and plug it in several times. Sometimes on the Zen players that will shock it back into charging. I have seen that same charging issue on several models of Creative players.
Cheers
Jan 04, 2009 | Creative Labs ZEN Vision:M Digital Media...
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
CREATIVE ZEN VISION MZEN VISION M TECHNICAL SUPPORT
read this:
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 12, 2007 | Creative Labs ZEN Vision:M Digital Media...
Player will not power up
I think this is more a Microsoft problem than a Creative problem. Seems WMP10 has issues w/ Zen. Considering MS is competing with this device, they may be lacking on it's support. What does MS care if your CREATIVE product doesn't work? They'd say just buy Zune to ensure compatibility.... and now you see the problem of a monopoly for PC OS.
Apr 15, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN V Plus MP3 Player Logo
307 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
