Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Hi, my robinair 34700Z dispays "Low Pressure system" when I try to recover and when I continue by pressing start, it displays "equalizing hose" and doesn't continue on the recovery process. need your expert advice regarding this matter. thanks
    President:
  • 180 Answers
You can try the following:1# Check (In main manifold assy.) recovery solenoid (No-1) and make sure coil is not burne or may need to rebuild. If so,replace new coil or rebuild solenoid flunger.2# Check (In small manifold back side of the machine) Inlet low & high side solenoids (small solenoid's No-10/11, and No-13/14) is receiveng power & opening properly.
Also you may need to calibrate pressure transducer or replace new one.
Hope this will help you. Good luck!
Posted on Mar 31, 2011
Machine won't recover, it gets stuck on "clearing in progress" Also won't vacuum, it says that "pressure exist press any key to continue" Your help would be greatly appreciated
I had a similar problem with a Robinair 17800b. The machine got stuck in Clr or (Clearing) while changing from R-12 to R-134a. If the tank (R-12 or R134a) does not have at least 10 pounds of refrigerant in the tank before you change to another refrigerant, the machine will stay in the clearing process. I called tech support and they walked me through a process that resets the machine. The reset involves entering a code while in r-12 mode, then removing all hoses and switching the switch to R-134a mode and entering another code. The call to the tech line took about 5 mins. The number I called 1-800-822-5561.
Aug 18, 2015 | Robinair Cool Tech 34700Z Recovery,...
Robinair model 34288 will not stop recovering
what is the pressure reading on your guages? if it is below 0 if so the vacuum pump should kick on. if the vacuum pump keeps turning on and off check the software version on the machine if it is not 3.09 or 3.11 the software needs updated contact your local robinair service center. if it is not the software then the recovery solenoid may be sticking closed and will need replaced.
Jul 07, 2012 | Robinair Cool Tech 34700Z Recovery,...
Machine says pressure exist unable to vacuum system down
It's not clear that you machine is doing recover or not! If the machine is doing recover theh follow the bellow steps.This is a common problem of Robinair 34700Z / 347002k
Sep 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
I HAVE A 34700Z UNIT AND I WAS RECOVERING AND AFTER A BIT IT STOPPED AND SAID HIGH PRESSURE UNIT DISABLED WHAT COULD BE THE PROBLEM.
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution
Aug 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi, My robinair model 34700Z wont recover refridgerant from a vehicle or lines. It goe through a vacuum cycle and charge cycle fine. It also wont transfer from my source tank or Recycle . It has 61 hours...
It is clear to me you need to Replace the Compressor! But if you want to make sure yourself, please do the following: Press recover & fix a vacuum gauge on your machin Compressor suction port & monito the gauge is going up to13"HG suction,if not then you need to replace the compressor.
I wish this will help you to solve the the problem. if so, pls vote for it. Good luck!
Aug 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
How to charge
Which model of Robinair machine you are using ? If it's 34700Z then follow as: After Recover & Vacuum, Press "CHARGE" button on contro panel & add the amoun you want to charge then press ''YES" button.
Jun 16, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34700z displays toggle input, input 0
You can try 1# With power on press and hold for 4/5 sec. up & down arrow key at the same time
2#With the power on press YES/START & NO/STOP key at the same time
Jun 02, 2010 | Robinair Cool Tech 34700Z Recovery,...
My 34700Z is not discharge low side existing pressure, wen i select vaccum the low side hose have pressure and stop to make vaccum
Please Check the following 1# Check ISV tank may overfill,if so manually discharge extra pressure from the tank.2#Check High & Low side small recover solenoid (in small manifole assy.) it's may neet to rebuild.3# Check Recover/Vacuum/charging (in main manifold assy.)solenoid,rebuild if need.4# Check ISV tank liquid hose is connected properly & make sure it's not too much tight OR loss.5# Check high side coupler is opening properly.Hope this will help you to solve the problem.
Apr 13, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair model 34700Z / There is power on the system , Fan is working , both circuit breakers tested okay but THERE IS NO DISPLAY ON CONTROL MODULE.
Please check harness continuity between the 15 Amp circuit breaker connector (P11) on the back of the control module.If continuity checks good,replace the Control Module.Hope this will solve your problem.
Dec 10, 2009 | Robinair Cool Tech 34700Z Recovery,...
Machine will not clear existing pressure
Please check your unit compressor also & make sure compressoe haveing minimum 13''Hg suction.
Jul 03, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
395 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
