Question about Altec Lansing ADA 885 Computer Speakers
Altec lansing ADA885 transformer output voltages
SOURCE: Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
Posted on Jun 22, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
  • 77 Answers
SOURCE: Connect Altec Lansing ADA745 to HD TV RCA output for home theater
hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
SOURCE: Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Posted on May 01, 2009
  • 3 Answers
SOURCE: Subwoofer fuse 'holder' missing.
tape or solder a piece of metal across where the fuze and holder would go.
OR
go to radio shack, pick up a small cartridge style fuze holder and an appropriate replacement fuze. (if you dont have the original fuze, dont bother with this method) Open the box or case to gain access to the circuit board. solder a new holder to the contacts.
Be aware that I have no clue what the fuze holder on that particular model looks like.
Posted on May 27, 2009
I have Altec Lansing ada 885 I only have sub woofer can anyone tell me how to power on with out other speakers . Because I have no switch to turn on with no other speakers and also the name of he plug on...
Throw it away, they are garbage speakers. I ordered one and ended up giving it away as it was so dire. It hissed when turned off, it drove me mad! The part you are missing is the amplifier which is in a small box unit in the right hand front speaker. Power goes into it and the input audio is amplified and goes to the Sub Woofer and the two satellite front speakers.
It will work on a stereo amplifier, but not as it is.
Manual
Using the Speaker System Altec Lansing ADA885 User Guide
Set up
Setup Altec Lansing ADA885 User Guide
Mar 10, 2018 | Altec Lansing Audio Players & Recorders
Power trafo altec lansing atp3
Is the label missing? All the information is printed on a label or stamped into the plastic housing. Have you opened it? Many have an internal fuse you can replace.
Jul 15, 2014 | Audio Players & Recorders
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through Amazon.com and other vendors. One vendor is http://www.emtcompany.com/altec-lansing-4815090r3cac-power-supply-charger-adapter/1010666.html .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Just need advice regarding connection to a speaker system, ( altec-lansing ADA885).
a portable DVD player usually doesn't have speaker or line outputs, if yours does just those (red and white) and connect to audio in of the altec lasnings. if no audio output connectors, use the earphone jack with an adaper (1/8 stereo male to stereo pair rca male.
Mar 17, 2011 | Zenith DVP615 Portable DVD Player
Altec lansing ada885 took a dose of 240V, burned fuse in place, replaced fuse, worked for about 2 hours, now nothing
Well is the new fuse still good or out again. if its good, then you probably fried the main board on the amplifier. These computer speakers do not handel big power serge's.
Mar 12, 2011 | Altec Lansing ADA 885 Computer Speakers
Hello. I have the altec Lansing acs40speakers but no power supply. What voltage do these need?
Class 2 transformer
Model: 4815090r3ct
Input 120vAC
Output: 15 vDC, 900mA
Center is positive, outer is negative.
Dec 04, 2010 | Altec Lansing Multimedia Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing ADA 885 Computer Speakers Logo
77 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
