Takes long hours to open a program - Computers & Internet
  • 9 Answers
What OS is it that you are operating on? You might have too many system utilities running that is bogging down your computer.
Posted on Mar 19, 2011
Honeywell thermostat "In Recovery" Message?
In recovery only shows on programmable stats. It refers to the adaptive recovery when using the programming. Over time the stat will learn how long it takes to cool or heat to the programmed set point. For example, if during the day the programming is set to 80?, and at 4:30 the programming drops to 76?, if it takes 2 hours for the temperature to reach 76?, it will learn that it takes 2 hours and eventually it will start turning on at 2:30 so that at 4:30 the temperature is satisfied instead of at 6:30, at which point it is no longer in recovery
Aug 05, 2014 | Honeywell Heating & Cooling
Westek Indoor 1 Outlet Digital Timer TEO2DHB instructions
Question is unclear:
Do you want instruction manual, or want somebody to read the instruction manual and explain it?
1) Open following link for instruction manual:
http://waterheatertimer.org/pdf/TE02DHB-manual.pdf
2) For explanation of instructions:
-add a comment and ask specific question saying what part of instruction is confusing. For example 12 hour or 24 hour format is letting you choose 12 hour am-pm format or 24-hour 'military time' format where hours of the day and night are numbered 1 through 24.
-and you can also take advantage of fixya live support, and expert can speak with you over phone while you program timer.
Sep 25, 2011 | Hardware & Accessories
I got a package with 2 timers. I had no problem setting the first, but on the second, I want to use a 12-hour clock. Seems it came programmed for a 24-hour clock, and I can't figure out how to change...
Westek TE22 two-pack offers choice between 12 hour am-pm display or 24-hour 'military time' display.
Open following link for typical manual
http://waterheatertimer.org/pdf/TE22DHB-manual.pdf
Look at step 7 in manual under Clock Time Setting.
Step 7 says, "press - button for 3 seconds to choose display"
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Hardware & Accessories
I have intermatic TN311 MODEL TIMER IDK HOW 2 WORK I WANT IT TO COME ON AND OFF FOR 15 MIN EVERY HOUR FOR 12 ORS A DAY IS THAT POSSIBLE AND HOW
Open following link to identify TM311 timer:
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
1) First of all, you would need more turquoise 107TN222 ON and red 107TN221 OFF trippers.
2) BUT big problem is that TN311 time dial is divided into half-hour segments, so minimum on-off is probably 1 hour since it takes 2 trippers for on-off cycle, and width of 2 trippers is same width as 1 hour.
3) Open following link for plug-in timers with 15 minute segments shows Woods 49664 & Stanley 31192 & Sylvania SA110
http://waterheatertimer.org/Woods-timers-and-manuals.html#49664
4) Notice the 49664 dial, that each hour is represented by 4 segments. This says timer on-off period is 15 minutes.
To set this timer, you would pull up all segments around the dial, and then push down 1 segment for each hour that you want timer to turn on for 15 minutes.
5) TN311 has 3 prong grounded outlet, Woods 49664 has 2-prong outlet.
6) Stanley 31192 timer and Sylvania SA110 have 3-prong grounded outlets and 15 minute intervals.
7) You cannot accomplish 15 minutes intervals for 12 periods a day with programmable digital timer.
Most digital timers allow 1 minute program times, but are limited to 6 or 7 programs, and not the 12 separate on-off periods needed for your project.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Mar 18, 2011 | Hardware & Accessories
How to set it to 12 hours on 12 hours off
You posted under Woods 59377 timer.
Open following page to identify timer for sure:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Manual appears below
http://waterheatertimer.org/pdf/Woods-59377.pdf
1) When programming, you can set 8 programs with choices of different blocks of days.
In your case, you want 1 program (Prog1) for all days of the week: So when selecting days, you want MON, TUES, WED, THURS, FRI, SAT, SU to display
2) When programming, you first set Prog1 ON, and then select all days as shown above, then set hour for 12am, and then set minute for 00.
3) Secondly you set Prog2 OFF, and then select all days as shown above, then set hour for 12pm, and then set minute for 00.
4) If 12am and 12pm do not display for some reason, then set times for 11:59am and 11:59pm.
5) Programming steps:
-Press PROG button until 1 and ON display. This is Prog1 ON.
-Press DAY button to select days
-Press Hour button to set hour
-Press MIN button to set minute
-Prog1 ON is set
-Press PROG button until 1 and OFF display. This is Prog1 OFF.
-Press PROG button to validate settings
-Prog1 OFF is set
-Press CLOCK button to return to current time
6) Manual shows other features
7) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 18, 2011 | Woods Industries 59377 Indoor Digital...
How to set on/off time?
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI032.pdf
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
Oct 11, 2010 | Aube Technologies Aube 7-Day 40-500w Light...
Verifying fol data when open my computer.
did you tried reinstallation...i think your problem will solve by a reinstallation with a new disc..i experienced a problem before somthing like this..
Feb 22, 2010 | Microsoft Windows Vista Home Premium with...
Display problem
Try restoring the computer to a working stage or disable startups through msconfig.
Instructions : start > run > msconfig > startup tab > diable all programs >
Otherwise Disable automatic updates > in control panel > windows updates
Try using ccleaner .. > available in softpedia.com
Feb 15, 2010 | Dell Latitude D600 Notebook
PaperPort will not open when i try to open it
Microsoft's Groove Folder ruins Paperport.
If you have included Groove Folder when you installed Microsoft Office Ultimate 2007, you will need to remove it ASAP.
Start/ Control Panel/ Add or Remove Programs/ Microsoft Office Ultimate 2007,
then deselect the Grove Folder component to make it a red "X", and let windows do it's thing.
It will take about an hour (!) for windows to unhook this VERY bad software - but Paperport will run again when you are done.
Be sure to set a new restore point for your system after you reboot and test Paperport.
Jan 27, 2009 | ScanSoft PaperPort Deluxe 9...
Power on bios password
To reset the BIOS password you must take out the BIOS battery on the motherboard of the computer.
On most desktops this is not a hard thing. Simply take off the side of the case, then take out the quarter sized battery on the motherboard, wait 60 seconds then reinstall.
On a laptop the same thing must be done but I must recommend you take it to a local Tech as this is not an easy thing to do if you have never opened up your laptop.
Mar 14, 2008 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
