I am having problems trying to connect my celestial tv PT4252HD to a receiver (amplifier) - tried HDMI = no go. Marian
  • Televison & ... Master
  • 5,418 Answers
You need to find the audio output on the TV that matches an audio input of the receiver. The HDMI of the TV is an input only, not an output. For this tv, there is an A/V out and digital (optical) audio out. You will need the appropriate cable.
Some receivers have HDMI in (for a connection to a Blu-Ray player or other set-top box) and then an HDMI out that goes to the TV.
I hope this helps.
Posted on Mar 19, 2011
Why is HDMI LED blinking and there is no power to the amplifier?
I assume that you are connecting your amp to a hi-def TV. Can you try out the TV stand-alone and see if it works? Perhaps there is a problem with the TV. The blinking light tells me that there is a HDMI related problem. What is connected to the HDMI? Check the cable and make sure both ends are connected properly. Disconnect the HDMI cable and see if the amp will turn on. Does it work? Do the lights on the amp come on? Give us some more details. Try the above and report back.
Jul 21, 2015 | Audio Players & Recorders
What causes the sound to cut for a few seconds?
Hi i just would to know if you did try to connect your TV by HDMI to test if your optical output of your reciever/amplifier have some problem. In second time yes maybe you can have an overheating problem, just take a look at your grid and maybe a clean-up will be necessary. I don't think your amplifier have a fan.
Don't hesitate to contact me here in this post. have a nice day.
Nov 10, 2014 | Technics SA-DX750 Receiver
I have a denon avr-1611 and can get sound playback through my connected speakers (not tv speakers) but no video output from hdmi. I have the receiver connected to a samsung tv. Is there any fix for th
You should check your Denon manual to be sure that the receiver has been set up correctly. My 1913 has many set up options including associating a particular HDMI out connection with a particular source like CBL/SAT or DVD. The fact that you hear sound indicates the HDMI cable connecting the cable box or DVD player to the receiver is working ( at least the sound portion of the HDMI in cable.)
Next, is the HDMI connection you are using to the TV the one selected in the source listing on the TV ? The sound and video circuitry on a receiver are separated and you can hear sound but see no video if the TV isn't selecting the correct source. For example if the TV is set to HDMI1 but you are plugged into HDMI 2. If this doesn't solve your problem try this:
At this point you don't know if the problem is the receiver HDMI connections or TV HDMI connections or a bad HDMI cable. The first thing to try is a new HDMI Cable. If that doesn't solve the problem then do the following.
If the TV has more than one HDMI connection try another HDMI port. Be sure to switch the source on the TV to the new HDMI port ie. HDMI1,HDMI2 or whatever.
If this fixes the problem you are done. If not then Try the same thing with the HDMI out ports on the receiver. Try each one not forgetting to set the receiver to use the HDMI port you are testing.
each time.
Since this can get confusing I would write down what you are testing each time so you don't get lost or confused.
If none of this works then you can try hooking up another TV to the HDMI cable, if you have one. If you do this and you still have a problem it points to the receiver as being the culprit.
The most likely problem is you have misconfigured the system so that is where I started. Each test is dependent on the fact that your system is correctly configured to begin with.
Sep 04, 2014 | Denon AVR-1611 A/V Receiver - 3D - 75 W...
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
you have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Feb 28, 2009 | Onkyo TX-SR606 Receiver
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
