MITSUMI 4 wire M49SP-2K 7.5 deg STEP Circuit Diagram Need the circuit for forward running reverse running and stop
SOURCE: Schematic and/or wiring diagram - Magnavox TV Mod 20ms233s
the problem in my tv is the sound no have
Posted on Jul 04, 2008
SOURCE: circuit diagram
i need circuit diagram of 107e61/94 model.
Posted on Nov 18, 2008
  • 14 Answers
SOURCE: Ignition wiring circuit - 1987 Suzuki Samurai
http://www.acksfaq.com/faqsearchresults-.php
Posted on Apr 23, 2009
SOURCE: Circuit diagram of 4 way traffic control system
digram of traffice control
Posted on Sep 29, 2010
  • 1779 Answers
SOURCE: Mine has 7 red blinks and wont come on. i pulled
No, your done. Now replace the Y-Main, that's the large one you found the fuse blown on and replace the two buffer boards that the Y plugs into. Those are the two at the far left. The part numbers are on the boards. So that's 3 boards you will need. sometimes they sell the buffers together as a pair which is cheaper. DO NOT buy from second hand resellers. Always buy new when it comes to plasma sets.
Posted on Nov 30, 2010
2004 chevy impala brake light isses switch has been replaced and so have fuses and bulbs still no lights
Do you know how to test using a DVOM - digital volt ohm meter ? Is there B+ voltage going into the brake light switch ? An coming out when the brake pedal is pressed ? What fuse's ? There is only one fuse for the brake lights !
The BRAKE SW fuse in the RH I/P fuse block supplies battery positive voltage to the normally-open stop lamp switch. When you press the brake pedal the switch contacts close and battery positive voltage is supplied to the left and right stop lamp assemblies and to the center high mounted stop lamp (CHMSL). The left and right stop lamp along with the CHMSL are grounded at G302.
Do you know about the right insturment panel fuse box ?
Stop Lamps Inoperative
Step
Action
Yes
No
Schematic Reference: Exterior Lights Schematics
Did you perform the Lighting System Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Press the brake pedal.
Do all of the stop lamps illuminate?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Are all the stop lamps inoperative?
YES - Go to Step 4
NO - Go to Step 7
Inspect the BRK SW fuse.
Is the fuse open?
YES - Go to Step 14
NO - Go to Step 5
5
Disconnect the stop lamp switch.
Using a test lamp connected to ground, probe the battery supply voltage circuit of the stop lamp switch connector.
Does the test lamp illuminate?
YES - Go to Step 6
NO - Go to Step 13
6
Install a fused jumper between the battery supply voltage circuit and the stop lamp switch signal circuit of the stop lamp switch connector.
Do the stop lamps illuminate?
YES - Go to Step 12
NO - Go to Step 17
7
Determine if the center high mounted stop lamp is inoperative or the stop/turn lamps are inoperative.
Are the stop/turn lamps inoperative?
YES - Go to Step 8
NO - Go to Step 9
8
Do the turn lamps operate normally?
YES - Go to Step 17
NO - Go to Turn Signal Lamps and/or Indicators Inoperative
9
Disconnect the center high mounted stop lamp.
Using a test lamp connected to ground, probe the stop lamp switch signal circuit of the center high mounted stop lamp at the harness connector.
YES - Go to Step 10
NO - Go to Step 15
10
Using a test lamp, probe between the stop lamp switch signal circuit and the ground circuit of the center high mounted stop lamp with a test lamp.
Go to Step 11
Go to Step 16
11
Inspect for poor connections at the harness connector of the center high mounted stop lamp. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 20
Go to Step 19
12
Inspect for poor connections at the harness connector of the stop lamp switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 20
Go to Step 18
13
Repair a open or high resistance in the battery supply voltage circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 20
14
Repair a short to ground in one of the following circuits:
• The battery supply voltage circuit of the stop lamp switch
• The stop lamp switch signal circuit of the stop lamp switch
Go to Step 20
15
Repair a open or high resistance in the stop lamp switch signal circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
16
Repair an open or high resistance in the ground circuit of the center high mounted stop lamp. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
17
Repair an open or high resistance in the stop lamp switch signal circuit of the stop lamp switch. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
18
Verify the stop lamp switch adjustment. Refer to Stop Lamp Switch Adjustment . If OK, replace the stop lamp switch. Refer to Stop Lamp Switch Replacement .
Go to Step 20
19
Replace the center high mounted stop lamps. Refer to High Mount Stop Lamp Replacement .
Go to Step 20
20
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Jun 23, 2017 | Cars & Trucks
03 cadilliac deville brake lights won't come on
test brake light switch --underdash on bracket attached to brake pedal
Jun 06, 2017 | Cars & Trucks
2004 Deville: I am getting code B 1390 - Device Voltage Reference Input Circuit Malfunction - what do I do?
DTC B1390 -The DIM has an internal battery voltage sensor and a reference voltage. The DIM compares these two voltages via the two battery positive voltage circuits every 300 milliseconds. Do you know what the DIM is ?
Conditions for Setting the DTC
This code shall be set after 10 consecutive readings that the two battery positive voltages differ by 1 volt or greater.
Turn OFF the ignition.
Disconnect the dash integration module (DIM).
Turn ON the ignition, with the engine OFF.
Measure and record the voltage from both battery positive voltage circuits of the DIM to both ground circuits of the DIM.
Compare the two recorded DIM battery positive voltage circuit voltages.
Is the voltage difference less than the specified value?
1 V
YES - Go to Step 5
NO - Go to Step 3
Test both DIM battery positive voltage circuits for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 7
NO - Go to Step 4
Test both DIM ground circuits for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 7
NO - Go to Step 5
5
Inspect for poor connections at the harness connector of the DIM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
YES - Go to Step 7
NO - Go to Step 6
Important:: After replacement of the DIM perform the set up procedure for the DIM. Refer to Body Control Module (BCM) Programming/RPO Configuration .
Replace the DIM. Refer to Dash Integration Module Replacement .
Did you complete the replacement?
YES - Go to Step 7
7
Use the scan tool in order to clear the DTCs.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Do you know what there saying here ? Do you know where The DIM is located . Do you know where to find a wiring diagram so you know what your testing ?
free wiring diagrams at
http://www.bbbind.com/free_tsb.html Enter vehicle info year , make , model ,engine . under system click on body & accessories, then under sub system click on body controls . Hit the search button a blue link will pop up . click on that .
Dash Integration Module (DIM)
The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules. Good luck !
Mar 08, 2017 | 2004 Cadillac Deville
2007 Silverado Classic 4x4 crew cab after parking the vehicle the headlights turn off but not the brake and back up lights How do I repair this problem?
DTC B2550
When the body control module (BCM) receives a signal requesting to illuminate the backup lamps, battery voltage is sent directly from the BCM through the backup lamp supply voltage circuit to the backup lamps.
Voltage for the backup lamp supply voltage circuit as well as the courtesy lamp supply voltage circuit is from the left instrument panel fuse block TBC 2B 15-amp fuse directly through the BCM to these circuits.
Brake lights or do you mean tail lights ?
Stop Lamps Always On
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle
Depress the brake pedal.
Does the system operate normally?
YES - Go to Testing for Electrical Intermittents
No - Go to Step 3
Do the brake lamps go out?
YES - Go to Step 6
No - Go to Step 4
Remove the CHMSL fuse.
Yes - Go to Step 7
NO - Go to Step 5
5
Remove the STOP fuse.
YES - Go to Step 8
NO - Go to Step 9
6
Inspect for poor connections at the harness connector of the switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs.
YES - Go to Step 11
NO - Go to Step 10
7
Repair the short to voltage in the CHMSL supply voltage circuit. Refer to Wiring Repairs.
YES - Go to Step 11
8
Repair the short to voltage in the stop lamp switch signal circuit. Refer to Wiring Repairs.
Go to Step 11
9
Repair the short to voltage in the stop lamp supply voltage circuit. Refer to Wiring Repairs.
Go to Step 11
10
Replace the stop lamp switch. Refer to Stop Lamp Switch Replacement.
Go to Step 11
11
System OK
Go to Step 3
Dec 09, 2016 | Chevrolet Silverado Cars & Trucks
What does LD code mean on my whirlpool cabrio washer mean?
Ld flashes when the water level does not change after the drain pump is on.
Is the drain hose or the drain pump clogged?
Is the drain hose height greater than 96? ?
Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation
Perform the following checks if washer fails to drain or recirculate.
1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5.
5. Tilt machine forward to access the bottom of the machine and the pumps. See Figure 1, page 6-13.
6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump.
7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test.
8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Aug 20, 2014 | Whirlpool Washing Machines
2003 altima dash fuse blows when i put in reverse and alternator stops working
It is electrical, could be initiated by mechanical (shift lever mechanics are pinching a wire in reverse) or a shorted wire or solenoid in the reverse light system or transmission solenoid circuit. Need a detailed wiring diagram to determine path of circuit for that fuse. That is where you need to start. Try your local library or dealer for a service manual. Look Online also.
Nov 02, 2013 | Cars & Trucks
Proform 831 threadmill
Dear Sir:
You have a serious problem:
Do the following step:
1) Test the power from outlet wall.
2) Test it for ground in the outlet wall.
3)power cord test for loose cable.
4) Reset c.breaker from the treadmill
5)test the transformer for voltage input and output(primary and secondary ).
6)Power supply see if there are some component burn or loose wire or melt.
7)See if there are +5 Vdc for digital circuit(main motor board.(
8) Run the calibration software under the Hood motor is the instruction. for diagnose.
attached the block diagram.
sincerely.
ernesto cuadra
managua, nicaragua c.a.
Feb 13, 2012 | Proform Exercise & Fitness
Chevy cavalier - rear brake lights don't work. The center rear brake light does work as well as all other lights. Replaced the bulbs and fuse - no luck. From what I have been told, the turn signal...
Stop Lamp Circuit Description
The STOP HAZ fuse in the IP junction block supplies battery positive voltage to the normally open stop lamp switch. When the driver presses the brake pedal, the switch contacts close and battery positive voltage is supplied to the center mounted stop lamp (CHMSL) and both left and right stop lamp assemblies. The left stop lamp is grounded at G304 and the right stop lamp is grounded at G304.
Check the ground ! Testing an not guessing is the way to find the problem . Do you know how to test automotive electrical systems an circuits using a DVOM - digital volt ohm meter ? How to use an read a wiring diagram to pin point testing areas in a wiring harness ?
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Step
Action
Yes
No
Inspect the 20 Amp STOP HAZ fuse.
Is the STOP HAZ fuse open?
YES - Go to Step 11
NO - Go to Step 3
Use a test lamp in order to backprobe connector C1 of the brake switch connector between terminal A and ground. Refer to Circuit Testing in Wiring Systems.
Does the test lamp light?
YES - Go to Step 4
NO - Go to Step 5
With the brake switch closed, Test for positive battery voltage at terminal B of connector C1. Refer to Circuit Testing in Wiring Systems.
Is voltage present?
YES - Go to Step 6
NO - Go to Step 7
5
Repair the open or short to ground in the Fuse Output-Battery between the fuse block and the brake switch. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
YES - System OK
6
Use a test lamp in order to backprobe the turn/hazard headlamp switch assembly connector C2 terminal A and ground.
YES - Go to Step 8
NO - Go to Step 9
7
Inspect the adjustment of the brake switch. If the adjustment is correct, replace the brake switch.
YES - System OK
8
Replace the turn/hazard headlamp switch assembly.
System OK
9
Repair the open in Stop Lamp Switch Output between the brake switch and the turn/hazard headlamp switch assembly. Refer to Wiring Repairs in Wiring Systems.
System OK
10
With brake switch open test terminal A of the brake switch for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
YES - Go to Step 11
NO - Go to Step 12
11
Repair short to ground in Fuse Output-Battery Circuit. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
12
Test the Stop Lamp Switch Output Circuit for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
YES - Go to Step 13
NO - Go to Step 14
13
Repair short to ground in the Stop Lamp Switch Output Circuit. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
14
Test terminals F,G,B and C on the Hazard Warning Switch for continuity to ground. Refer to Circuit Testing in Wiring Systems.
Is ground present?
Go to Step 15
15
Repair short to ground in suspect CKT. Refer to Wiring Repairs in Wiring Systems.
Is repair complete?
System OK
Jul 03, 2017 | 2000 Chevrolet Cavalier
Kenmore oasis he top loader shows LD error code. got back panel off, now what?
Long Drain Ld flashes when the water level does not change after the drain pump is on. • Is the drain hose or the drain pump clogged? • Is the drain hose height greater than 96˝ ? • Is the pump running? If not, see TEST #7.
TEST #7 Drain/Recirculation Perform the following checks if washer fails to drain or recirculate. 1. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies. 3. Visually check that the P4 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1. 4. Remove connector P4 from the machine/ motor control and check resistance values of pump motor windings. Resistance values should match those shown in wiring diagram, page 7-1. If resistance values are good, go to step 7. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, a problem exists in the motor winding or in the connection between the machine/motor control and the motor. Go to step 5. 5. Tilt machine forward to access the bottom of the machine and the pumps 6. Check the resistance at the pump motor. Remove the connector at the motor and take measurements across pump terminals. Measurements should be as shown in the wiring diagram. If winding measurements are much higher (tens of ohms to infinity) than shown in wiring diagram, replace the pump motor. If the resistance at the pump motor is correct, there is an open circuit in the wiring between the motor and the machine/ motor control. Repair or replace the lower wiring harness. If the pump motor windings and machine/ motor control check OK, repair or replace the pump. Be sure to check the pump and tub sump for foreign objects before replacing pump. 7. See Activation of Manual Diagnostic Test Mode, and perform the Manual: Pumps test. 8. If the Manual: Pumps test failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Manual: Pump test.
Jun 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
350 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
