Question about Fisher and Paykel Fisher & Paykel Washer
My fisher paykal washing machine is continuously beeping and won't go to the next cycle. it is showing lights two and seven. what could the problem be.
    Brigadier General:
  • 6,277 Answers
(no promises but try this!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 19, 2011
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykal MW512 turns on multiple beeps then turns off
This kind of problem is usually related to a faulty display module, or faulty motor control module (Computer isnide of control panel compartment)
Without spares to change and test with, you wont be able to diagnose 100%
Usually when there is a problem, a series of lights go solid on the control panel and the machine beeps to alert you to a problem and this is a fault code, but if nothing is showing at all, then I have to lean towards the display module underneath the touchpad. Especially considering it wont illuminate.
Nov 22, 2012 | Fisher and Paykel Fisher & Paykel Washer
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Hae we have a fisher and paykal washing machine but it wll not start spinning can u help
Run a diagnostic test for the spin cycle. The paper to show you how to run these test is located under the control panel normally two screws on the back of the control panel. By running the diagnostics, it will code if there is a problem and you will know what to check. You can also drain your machine with these diagnostics.
Does your machine beep (because there is a problem) during the drain process but doesn't get to the spin cycle? More than likely your drain hose is clogged. It is very easy to check this. I had the same problem because my machine could not drain properly and would not get to the spin cycle. There was a penny in my drain hose. There is a video on youtube that shows you how to do this (very informative).
Jan 19, 2009 | Fisher Paykel EcoSmart GWL15
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykal washing machine, Mod:GHL10US
if you want to find out for sure post your email here and i will send you the service manual
Jan 15, 2008 | Fisher Paykel EcoSmart GWL15
Fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Sep 02, 2007 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
