Question about Refrigerators
I AM USING A DAEWOO REFRIGERATOR. THE UPPER CHAMBER OR THE FREEZER IS VERY COLD BUT THE LOWER CHAMBER IS NOT COOLING . WHY IS THAT SO?
    Guru:
  • 257 Answers
Hello Nickel129,
I understand that you are having a problem with the refrigerator. The freezer is cooling just fine however, the fridge is not cooling enough or at all.
1. Check to see if you here the fan in the back of your freezer compartment turning.
a. if you do not here the fan then you need to replace it.
1. Unplug unit (fridge)
2. Remove the screws holding the bottom (if any) and the back cover.
3. Locate the fan and remove the wires
4. unbolt the fan and remove the fan blade (some new motors do not come with the blade)
5. Purchase a new motor at a local hardware/appliance store
2. If the motor is running you need to check the air tunnels (pasages in the frezzer)
a. Remove the covers in the freezer as above. There will be one, two or three holes that go thru the bottom and into the fridge. If these holes are full of ice defrost (w/water, hair dryer, etc.) so that air can pass thru the holes.
The above should help you to fix your refrigerator.
Thank you for choosing Fixya.com for your questions
Justin
Posted on Mar 19, 2011
My refrigerator upper is cool but lower is not cool, how fix it?
Check to make sure the the fan that either sucks the cold air from the freezer is working and not blocked. In some refrigerators the fan is in the freezer and some is in the refrigerator compartment.
Make sure it is operating AND that it isn't blocked.
Jun 07, 2011 | Refrigerators
No ice setting in upper chamber of freezer lower chamber working
Cold air goes down and especially hangs right around the area where the heat is removed (cold is generated). A fan exists which continually moves the air around in the chamber so that there will be no warm spots. Opening the door allows a spring loaded switch to move toward the opening which shuts the air circulating fan off so that cold air will not be blown out of the fridge or freezer while the door is open.
Depress the switch. Does it click? Some switches do not make an audible click. Can you hear the fan turn on? The switch is in the door jamb. The fan is behind the vent holes in the compartment.
:o).
Jun 04, 2011 | Daewoo Refrigerators
Frsu201ai side by side , freezer is freezing ,but the refrigerator is not getting cold and both fans are working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Daewoo Refrigerators
Freezer ok fridge not cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Daewoo FRSU20IA Freezer
Dear Sirs, My FR-291 has trouble: freezer chamber does not work well on the upper shelve. What to do?
Your model doesn't have a defrost function, I'd check to see if ice is building up on your walls of the freezer chamber, if so, carefully scrape away the ice. Another possibility is that your seals on the door are torn or are wearing out, a simple replacement can do wonders there. Lastly, it's pretty rare, unless you abuse your freezer, but a hole in the chamber caused by wear or from an icepick can basically kill the freezer. If that happens, well, your out of luck, sorry.
Mar 05, 2011 | Daewoo FR-291 Refrigerator
Too, too cold in both freezer(upper) and lower level even with ther. at midpoint Noisy at times.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 11, 2010 | Refrigerators
My Daewoo refrigirator's freezer is cooling but not the lower com
sounds like you need to replace the ptc overload on the compressor as this component supplies start and run power to the compressor and its getting weak and short cycling the compressor,they just unplug and plug into the side of the compressor and when you remove it shake it by hand and if you hear it rattle thats a good sign its bad
May 31, 2010 | Refrigerators
Kenmore 106.536323000 S/S: Not Cooling Enough
YOU HAVE A DEFROST PROBLEM. FROST HAS BUILT UP SOMEWHERE AND THE FAN CAN'T BLOW PAST THE BLOCKAGE. OR ONLY A SMALL SECTION OF YOUR COILS IN THE FREEZER ARE COOLING DUE TO A CLOGGED FILTER OR BAD COMPRESSOR. PULL THE BACK COVER FROM INSIDE THE FREEZER AND LOOK AT THE COILS. THEY SHOULD HAVE A LIGHT FROST AVER THE ENTIRE COIL.IF IT IS A BIG BLOCK OF ICE YOU HAVE A DEFROST PROBLEM.
Oct 28, 2009 | Kenmore 53642 / 53644 Side by Side...
Not cooling,lower part of the frig and freezer gets cold
You may need to set the Fridge side thermostat cooler or there may be a slide switch that allows ou to set the "bias" more toward the fridge side.
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
171 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
