Question about Janome 8080 Computerized Sewing Machine
I have been teaching a sewing class to some young girls. I believe one of them adjusted the thread tension. I am doing a zig zag stitich and the bobbin thread is showing on the top stitch.
  • 20 Answers
Check tensions again, review the manual. Could be threaded wrong or bobbin not correctly wound. These are common solutions to this problem.
Posted on Jan 27, 2012
4 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: zig zag stitch is skipping sporatically
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 30, 2009
  • 96 Answers
SOURCE: tension underside looks good, but top side the bobbin thread show
sometimes when you reset the top tension dont forget to reset the bobbin tension so try to tighten the bobbin tension
Posted on Dec 13, 2009
  • 1116 Answers
SOURCE: Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
Posted on May 15, 2010
This Kenmore 158.480's stitch selector is stuck and will not adjust to zig-zag. Need advice or a free service manual. I will gift this machine to a young girl just starting to learn how to sew. Thanks
These old Kenmores are great machines (wish I'd kept mine). But they do love to be oiled and cleaned regularly. The old oil has probably dried and causing it to seize. Treat the machine well and it will serve you, or the lucky young lady, for years to come.
Wheel on right side that controls the needle up and down is very tight...
FWIW, you may want to show the young lady how to clean and oil her machine to keep it in running condition. If she is going to own a machine, she should know how to maintain it.
Be sure to stress that the presser foot should ALWAYS be RAISED when threading the top thread. This will prevent those dreaded thread nests under the fabric when she first begins to sew.
Check with Sears. They carry manuals for a lot of their machines--sometimes even free download. However, the manual will not provide instructions for a thorough oiling (as described above), because at the time companies thought the machines would be brought in to their facility for service. Evenso, a manual is a definite "must have."
Aug 30, 2017 | Kenmore Sewing Machines
Need to now where to put tentions to sew sweat pants.
use a couple of pieces of waste material the same as the sweat pants material and sew about an inch long
adjust the needle tension and do it again
repeat the exercise until the top and bottom thread joint at the middle of the two pieces of the material
tension settings on the machine are a loose guide as the thread thickness, material thickness and needle size all have a bearing in the tensions of the thread
so practice and adjust prior to sewing is the way to go
Nov 07, 2015 | Sewing Machines
Loose underthread and no zig zag
Lower thread tension can be adjusted by tightening (clockwise) the small screw in the bobbin case. The specifications call for 12-20 g resistance when pulling the thread slowly. I suggest tightening in increments of 1/8 turn and trying the machine each time. Also, mark the position of the screw in its original position should you need to return to the original setting and start over (use a piece of tape and place a mark where the slot in the screw is). I don't understand what you're saying about the zig zag problem.
Mar 12, 2014 | Husqvarna Sewing Machines
Sews straight when on zigzag
it's possible the zig zag gear or cam could be worn or damaged
and the machine should be checked to see for sure what's happened.
Nov 29, 2012 | Sewing Machines
Fix zig zag
are you using a interfacing or stablizer with the fabric?
try replacing the needle
possible the zig zag gear is worn or damaged & needs to be repaired
Feb 08, 2012 | Baby Lock Sewing Machines
The thread underneath when sewing is too loosed
Usually thread too loose on the bottom is caused by the upper tension being too loose. The top and bottom tensions work together with the top thread making the underside of the stitch seem too taunt or too loose and the bobbin thread causing the top side of the stitch to be loopy or too tight. Select a large zig zag stick and sew a couple of inches. Then examine the stitch. It should look identical on both sides. Look to see which side is drawn too tight, the zig zag being smaller on that side with threads from the bottom threads pulled through. Then adjust the two tensions so that they make a uniform, identical stitch.
Also, when the bobbin tension is right you can hold the bobbin dangling by the thread and it won't spool out to the floor but will let loose a bit with a slight flick of the wrist. Too loose it will just spool out. Too tight and it won't drop at all. When you get that set right then do the above zig zag test to see where the top tension should be set.
Mar 02, 2011 | Sewing Machines
I'm sewing a zig zag stitch and the underside is a perfect zig zag and the upper side looks like it should be the underside....how can I fix this so that the beautiful zig zag is on the top?
FIRST > Make sure your bobbin case is threaded correctly...
NEXT
For normal straight sewing the top tension should be around 5, for zigzag or satin stitch you need to lower your upper thread tension a bit. Try it at 4, if it still pulls your bottom thread to the top try it at 3 etc...
Jan 15, 2011 | Euro-Pro Deluxe 7130 Mechanical Sewing...
I tried to use a double needle on my Bernina 160. The top stitching looked ok, but underneath the thread was straight and you could pull the bottom thread right out. I've heard the bottom is supposed to...
When you thread the top thread, ALWAYS RAISE the presser foot so the thread will seat completely in the tension disk. If this doesn't improve the stitch, try tightening the top tension. If it is too loose, the bobbin thread will lay on the surface of the fabric. When the top tension is tightened, it will pull the bobbin thread up into the fabric.
Feb 03, 2018 | Bernina Virtuosa 160
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Janome 8080 Computerized Sewing Machine Logo
87 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
