Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
I have a portable Spa Tub with an AMPAC pulsar series micro spa controller 2081spx. Both Pump and Air buttons are flashing RED and Green and unit is not working. I have hooked both Pump and Blower up to power and both units are operating individually, but Controller does not switch these units on.
    Top Expert:
  • Qca Spas Master
  • 7,217 Answers
If recirculation pump is ok and heating element possible bad control board
Posted on Oct 12, 2017
adamh294
  • 310 Answers
SOURCE: We have a brand new
The dr error code is for "dry". Meaning that the control system is not sensing that water is flowing through the heating element.
With a new spa, and you just having drained it , it is probably an air locked pump.
What this means is that you have a small constant circulation pump with not much power, that got ait trapped in it when you drained. When you went to start back up, this "air lock" prevented the pump from fully priming.
Power down the spa at the breaker. Remove the filter element.Stick a garden hose with lots of pressure into the skimmer hole and open the hose valve to let water inject into the skimmer.
Restore power to the spa and check operation.
If after attempting this a few times you still get the code, there is an issue with your flowswitch, or with your circulation pump.
With a brand new spa, id like to hope that you just have an air lock.
Good luck
Posted on Mar 17, 2011
  • 8404 Answers
SOURCE: have a hot spring spa,i notice a layer of oil in
You caused it, MOST likely
Possibly, it came out of your well or out of your city water supply.
Don't be alarmed and don't be mad. I maintain a hot tub in a resort and in the summer we change the water weekly to get rid of this stuff. We have this trouble to a lesser extent in our other bodies of water at the resort.
What can you do? Go to the pool place and get some of the blue stuff. (comes under several names) The blue stuff works best when the chlorine is low. Put one ounce in a bucket of water to mix then put it into the tub - run the blower and the jets for 15 minutes wait 15 minutes and do it again. Let it run on maintenance speed all night. (never add water to chemical ... always add chemical to water)
What is happening is the blue stuff makes the disolved solids in your water (oil, etc) bind together and either float or sink depending on their specific density. This gunk will be mostly removed by the filter. Clean any you find from the tub (ring around the tub)
Treat your tub weekly (not weakly) with the blue stuff. And also, be very particular about your water balance; pH, Total Alkalinity, chlorine. Calcium is unconsequental in your case unless it is extremely high (above 800 ppm) I presume you know you should have about 7.4 pH, 3 - 10 ppm CL, 80-100 TA or 100-120 depending on whether you use liquid or dry CL.
And lastly, Take a good shower before you get into your tub and insist others who use your tub do the same. I presume swim suits might be optional in your spa (they are in my home spa) if not - make sure they are CLEAN CLEAN CLEAN - after a trip through the washer, rinse them again and let them dry.
This is what I call a 75 cent answer for a 50 cent question. I'm sorry if I overwhelmed you. If I missed your question, please re-ask
Above all else, enjoy your spa.
a
Posted on Oct 20, 2009
Testimonial: "thanks for your answer, very helpful"
SOURCE: I have the ball bearings showing up in my lounger
You can use the spa as usual. The missing ball bearings are only going to affect the jet that they fell out of, and since the bearing is already falling appart it is not going to hurt a thing. Most jets have non replacable bearings, so you will need a whole new jet anyways.
Posted on Mar 06, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Qca Spa pumps and blower will not come on, water down to 35º f
Ken,
You need to contact a hot tub technician/engineer as you clearly have issues.
'ICE' means that the water temperature is too low and therefore the pumps will be turned on to prevent freezing within the plumbing. Depending upon the spec and settings, the heater maybe disabled during 'ICE' condition.
'ECON' is Economy Mode. If you have a mode button, keep pressing it until you see 'Stan' on the display. This will put the system back into the standard mode.
'FLO' means that there's insufficient flow of water through the heater, or non at all. 1) Check the water level - top up if low. 2) Ensure that all jets are open and flow water - if they don't you may have a pump issue. 3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
'COOL' is displaying because the set temperature is much higher than the current water temperature.
As I mentioned at the start, you really should get someone to take a look at your hot tub. You may have a few issues that need resolving.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 17, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Calcium build up in my Arctic Spa Hot Tub
The worst calcium build-up I have seen on an Acrylic shell was actually caused by incorrect use of chemicals by the owner. The owner was dosing in very large quantities which was the cause of their issues. Little and often is the best way to go when adding any chemicals to a hot tub.
I don't rate Aqua Finesse at all. I have seen cirulation lines partially blocked due to similar products, I wont recommend it to any of my customers or use it myself.
If you were my customer, I'd be running through your chemical routine and the quantities that you add at any one time. It's possible that you are over-dosing and causing the problem to get worse.
Kind Regards,
Ian Kime.
Posted on May 15, 2010
How do you set up the timer for heating a ampac pulsar series spa?
http://waterheatertimer.org/How-to-set-timers.html
Link above has instruction resources for analog and digital timer modules.
Repost question and describe timer in detail
Gene
Water Heater Timers Save Money
Jan 04, 2015 | Hardware & Accessories
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
Lanark spa bath
Not really sure but it sounds like there is a sensor that may not be reading properly preventing the pump to turn on.
Rod @ US Parts Center
May 12, 2013 | Pool & Spa
I have a comfort spa portable hot tub with the pump housed within I am hearing a clicking noise and the dispaly shows the temperature readings ascending and the error code sn - what is the problem
This indicates a sensor failure. Either the temperature sensor has failed, or it has become disconnected from the control unit. If you find that it is still in place, replace the sensor.
Jul 11, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
We have a brand new Oasis Mohave spa and we wanted to run through a full cycle so we ran the tub for a week, no problems. then we drained and refilled the tub. Now we get dr or dy as error codes on the...
Good luck
Mar 16, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
Spa n a box 6 person portable hot tub pump cl250-c pump stops working error message OH on display
If the water pump is not circulating water you will want to do a simple procedure called "turning the impeller" You can call 888-997-6366 to be walked through this procedure over the phone.
Feb 26, 2011 | Comfort Line Spa 2 Go Portable Spa with...
Blower works and jets do not?
Water jets will not work?? Is your pump on? I would expect to open ports on the top to introduce air to the water stream. Is this the case with your unit?
May 02, 2010 | Comfort Line Spa 2 Go Portable Spa with...
How to set timer on my hottub
Hi, we have an ampac pulsar series timer on our spa. We are not sure how to set it, as we bought it second hand and have no booklets. Can you help?
Mar 21, 2010 | Hayward H Series Pool & Spa Heater 400k...
AquaLink RS 4 top lights flashing red bottom lights flash yellow
I don't have the "one-touch", but on the "all-button" there's a hole on the left side of the unit. A paperclip inserted in this hole will reset the unit. I had a problem with the display on mine and this fixed it.
Apr 19, 2009 | Jandy Aqualink Rs4 One Touch Control...
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
2,186 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
