Question about GPS
I have a 2011 Jeep Grand Cherokee that has a bad key fob, The fob will remote start, lock and unlock doors. When I want to use the push button to start the vehicle, the Jeep does not recognize the key fob. However, if I pop the push button cover off and insert the key it will start the Jeep. My Jeep Service Tech. has no idea what the problem might be. Any ideas?
SOURCE: i have a grand voyager
dont go through all the hassles of removing the door trim just take the terminal off the battery for about a minute then reconect again worked on mine good luck
Posted on Dec 20, 2008
SOURCE: can't unlock doors without alarm going off
If you lock the car from the outside with the key your alarm will not go off this happened to me too
good luck with buying a new keypad they're over 150 each
Posted on Feb 20, 2009
  • 3 Answers
SOURCE: Power windows inop
a brake in ur wires in the door,on a 04 grand i had the same problem,in the wire harness were the junction box is rust had broken one of the male prongs
Posted on May 05, 2009
  • 412 Answers
SOURCE: How do you program a 2002 Jeep Grand Cherokee FOB?
if you have an original working fob and your owner's manual,it will explain procedure,otherwise will have to go to dealer to be programmed
Posted on May 17, 2009
Shorty1_wt
  • 324 Answers
SOURCE: my keyless remote for my 2000 jeep grand cherokee wont unlock the
go to autozone and use the remote tester on the counter to make sure that the remote itself is functioning or not, could be a dead battery. On some vehicles it is possible to reset the keyless entry by turning the ignition switch from off to run (right before the starter activates) 3 times or so, if you try this and the door locks activate then press the lock button on your remotes. good luck
Posted on Jun 03, 2009
How do I disarm my 2011 jeep grand cherokee alarm? It keeps going off randomly and my remote doesn't shut it off
GOT OPTION "ENTER AND GO"???????????????
did you use both FOBS. car came with 2, try using both , one at a time and not both near car as SAME time. ever.
mines turned off for ever,
i never armed it.
so page what.
wow 6 owners manuals, 4 for Uconnect, wow. pain.
page 22. read that?
sure.
is this not clear ,quoted
The Vehicle Security Alarm is designed to protect your
vehicle; however, you can create conditions where the
Vehicle Security Alarm will arm unexpectedly. If you
remain in the vehicle and lock the doors with the RKE
transmitter, once the Vehicle Security Alarm is armed
(after 16 seconds), when you pull the door handle to exit,
the alarm will sound. If this occurs, press the UNLOCK
button on the RKE transmitter to disarm the Vehicle
Security Alarm. You may also accidentally sound the
Vehicle Security Alarm by unlocking the driver's door
with the key and then opening the door
good luck deciphering this page, wow.!
page 23 is NO ENTER AND GO', OPTION.
Either press the UNLOCK button on the RKE transmitter,
pull on the front driver or passenger door handle (refer to
"Keyless Enter-N-Go" in "Things To Know Before Starting
Your Vehicle" for further information) with a valid
key fob in range, or press the Keyless Enter-N-Go Start/
Stop button (requires at least one valid Key Fob in the
vehicle), or insert a valid Key Fob into the ignition switch
(if the Start/Stop button is removed) and rotate it to the
ON/RUN position.
END QUOTES FROM YOUR GUIDE.
if all this fails get jeep to fix it. (the magic is broken so...)
or ask them to explain, page 23 , in non GREEK..
Feb 27, 2015 | 2011 Jeep Grand Cherokee Laredo
Driver side door lock jammed on 2004 jeep grand cherokee
the key dont work or just the fob?????????????
did you try both fobs?
car came with 2 fobs try both. ?
if both fobs fail, bad solenoid, if metal key works.
if metal dont work, the lock is frozen with ICE, got ICE?(hair dryer fixes it)
no ice ?,then lube the lock with graphite,lube. if key fails.
if key dont fail and you get 12v to solenoid, then the solenoid is bad
I just replaced one that had 1/2 power (the guts inside sol were bad)
$100 part. too.
Feb 06, 2014 | Jeep Cars & Trucks
Keyless remote 1996 jeep grand cherokee laredo programing
Instructions
  1. Programming the First Transmitter
    • 1
      Unlock all of the Jeepicon1.png Grand Cherokee's doors and open the driver's side door. Keeping the door open, lock it using the manual lock on the door itself.
    • 2
      Put the manual key into the ignition and switch it to the "On" or "Run" position, whichever applicable, without starting the engine.
    • Sponsored Links
    • 3
      Point the remote at the receiver (located by the little bulb on the caricon1.png ceiling) and hold down the "Lock" button for up to 5 seconds.
    • 4
      When the driver's side door unlocks, you know the remote has been programmed correctly. If you are only programming one remote, jump to the next step. If not, manually re-lock the driver's side door and repeat steps 5 and 6 using each remote you would like to program and then continue.
    • 5
      Turn the key to the "Off" position and turn the ignition on immediately. This must be done within 20 seconds of programming the last remote. You're finished!
Sponsored Links
Read more: How to Program the Remote on a 1996 Jeep Grand Cherokee ' eHow.com http://www.ehow.com/how_7433787_program-1996-jeep-grand-cherokee.html#ixzz2KdCc5PQq
Feb 11, 2013 | 1996 Jeep Grand Cherokee
Peugeot 206 key fob
Try with brand new key fob battery and see.If that helps.
Otherwise May be keyfob needs to be reprogrammed.
KEYFOB PROGRAMMING
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There are few much related troubleshooting links mentioned below for remote key fob reprogramming. I suggest you to go through the list and click the link below to go through its details and procedure: -------
2009 Toyota Highlander: Smart Key Not getting Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.
Thanks.
Nov 28, 2012 | Peugeot Cars & Trucks
How do I disconnect the security system? My truck won't disengage & I can't start it.
The security module is located in the dash behind the glove compartment. You cannot disconnect the security module without bypassing the starter wire. The system disarms by unlocking the front doors or tailgate with the key or using the remote key fob. The switches on the door latches are notorious for going bad on the grand cherokees. These switches are inside the doors attached to the lock cylinders and cost about 40 bucks at the chrysler dealership. You can also get a replacement remote fob on ebay but they are around 50 bucks and you will need the owners manual for the Jeep to program it.
Oct 02, 2010 | 1994 Jeep Grand Cherokee
I have a 1999 jeep grand cherokee. the alarm goes off whenever i open the door if the vehicle has been locked the alarm stops when i start the vehicle i only have a key, no remote any ideas on how to fix...
If ithe alarm is factory when they will have to reset the alarm module with a scanner. If the alarm if aftermarket go to the control module and see if it has a reset button. FOBs (remote) can reset alarm. You Jeep is always set for break-in mode. The FOB sets this when ever the FOB is used to lock the doors. May be bad alarm module - Sorry - Good luck
Oct 17, 2009 | 1995 Jeep Grand Cherokee
Remote door locks don't work with both keyfobs unless it is in the car
Replace the battery in the key fob and try again. That's the number 1 problem solver for this.
May 02, 2009 | 2002 Jeep Grand Cherokee
2000 Jeep grand cherokee limited remote start
higher end starters will have the lock/unlock/panic buttons built onto their fob. as for the seats... I dont know why it would interfere with your settings, but who knows... better to ask the seller of the remote start system.
Mar 18, 2009 | 2000 Jeep Grand Cherokee
Jeep alarm will not turn off
The ignition security on/off is located at the trunk lock. unlock and lock rear gate and the alarm will turn off. My jeep sat in my drive for a month before a jeep tech told me this. It still triggers the security sometimes when I unlock the passenger door with the key and I go straight to the rear gate lock and it shuts off instantly.
Jun 27, 2008 | 1994 Jeep Grand Cherokee
GPS Logo
216 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
