Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cant find the idle screw - Husqvarna "Chain Saw - 16" Bar, 3 Hp
    Novelist:
  • 144 Answers
Hi allenplum,
There are 2 mixture screws, 1) the idle speed screw, 2) is the idle speed mixture screw. The idle speed screw is located on the carburetor, nar the throttle arm where your throttle cable is connected. There is a screw that you will find there that you screw in or out to speed up, or slow down the engine idle. The idle speed mixture screw is located lower down on carb and has a spring on it. There should be 2 screws side by side, one is the idle speed and the other is the high speed mixture screw. They are marked on the carb body, with the letter H or L . To adjust, remember the screw position before you do any adjustments. Start by turning the screw in (clockwise) all the way in until lightly seated, so no damage is done to the seat or needle. Turn out (counterclockwise) 11/4 inch, this should be OK to start the engine. Along with the idle speed screw, you should be able to get the correct idle required. With all the modernization happening, there might not be a high or low adjust as they are ported inside the carb. You might get just the high or just the low adjust needles. I hope this is helpful to you. All the best and good luck. Denis.
Posted on Mar 19, 2011
Idle set 750 double pumper
thee should be 4 sets of mixture screws on the carby
turn them all in till stop and then screw each one out 2 full turns
you may have use a bit of throttle to keep it idling but it is idles the screw one mixture screw in until the engine prms goes down turn it back out slowly until the engine again starts to die
count the screw turns and turn it back in 1/2 that number of turns
do that for all the mixture screws
have you set the float level correctly
iare there any vacuum leaks
Sep 19, 2015 | Cars & Trucks
Homelite d725cd
not sure what you're trying to accomplish but the idle screw and low speed mixture screw work together. most 2 cycle trimmers idle happy at 3k rpm's... just before clutch engagement
Aug 28, 2014 | Homelite Mighty Lite Lawn Trimmer
What are the air and gas settings for a poulan micro XXV chain saw
adjust the L screw in fully till right in,then out 1.5 turns,same with H screw.Then start saw,adjust L screw in or out slowly till you get max revs.You may need to lower idle via idle screw if revs too high.When screw cant acheive better revs,reset idle.Then,rev saw to max revs,adjusting H screw to get max revs,then when max revs acheived,turn screw anti clockwise 1/4 turn out.That gives it enough petrol to cool the tip of the plug
Aug 12, 2014 | Garden
Idle screw location
Its right under the float bowl
Jan 25, 2014 | Quad Cycling
86 gmc k1500 5.7L just replaced carb and now cant get engine to idle
Check that you have replaced the vacuum line for the distributor to the base of the carby block. Turn the 2 idle mixture screws all the way in till they touck the bottom. Then turn both out about 2 full turns . Get the engine running and hold at fast idle and adjust screws until a steady idle is achieved . Allow to idle and screw each screw in or out slightly until even idle is achieved. You will hear the engine revs increase or decrease when you have gone too far so adjust to about the middle of turns
Feb 17, 2013 | Cars & Trucks
Idles on low speed only. i cant increase the speed.
There is two ways only to increase rpm (speed) first of all make sure that when you push throttle cable up, there is no obstructions or kink in cable. Number two is on carb area , there should be a idle screw as well as smaller ones for richness and leanness, leave those two alone, just go to the bigger screw (idle screw) use a small flat head screw driver and turn it clock wise to turn up idle(rpms) if still does not go up, check air filter to make sure is not clogged as well as fuel filter. Hope this helps, Mike from fixya
Jul 07, 2011 | Mtd Garden
Cant find the idle screw on my 2010 sportsman 500
theres a wire comming out of throttle. it goes down the right handle bar. on wire there are two rubber pieces. slide highest one up. and slide lowest one down.turn screw up for more tension. turn idle screw down for more play in throttle.
Oct 16, 2010 | Polaris ATV
Engine idle too high
no, there is no idle screw on them if it is fuel injected. although you could try changing the idle air speed sensor
Apr 26, 2009 | 1987 Chevrolet S-10 Pickup
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
539 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
